Toymods » Tech & Conversions » Penrite Limslip 90 or limslip 140, what should I use?
Jag7799
Penrite Limslip 90 or limslip 140, what should I use? Wed, 24 November 2004 07:15 Go to next message
Replacing my LSD oil tomorrow.. manufacturer states 90 should be used but ive been imformed that 140 is thicker and tougher.
Ive got an ma61 LSD
Which would be best for my car?
ae95
Re: Penrite Limslip 90 or limslip 140, what should I use? Wed, 24 November 2004 07:45 Go to previous messageGo to next message
i use 140
its good for australian conditions
ae95
Re: Penrite Limslip 90 or limslip 140, what should I use? Wed, 24 November 2004 07:53 Go to previous messageGo to next message
LIMSLIP 140
Heavy limited slip gear oil with the same performance as Limslip SAE 90. Suitable for units in some heavy commercial vehicles.
LIMSLIP 90
Limited slip differential oil for vehicles in standard on-road use in ambient temperatures of below 30ºC. Surpasses API GL-5 requirements and the obsolete API GL-6. Contains an initial fill level of limited slip additive
and since we live in australia where the temp gets to over 30 degrees i went for the 140
Jag7799
Re: Penrite Limslip 90 or limslip 140, what should I use? Wed, 24 November 2004 08:35 Go to previous messageGo to next message
point made, what am i looking at cost wise?.. only need 1.2 litres
ae95
Re: Penrite Limslip 90 or limslip 140, what should I use? Wed, 24 November 2004 08:42 Go to previous messageGo to next message
aroudn 20bucks i think
improvedae86
Re: Penrite Limslip 90 or limslip 140, what should I use? Wed, 24 November 2004 09:22 Go to previous messageGo to next message
I would second the 140 , have been using it for along time .
It sure is thick stuff i normally hear one click due the the sticking of the pinion and ring gear when moving the car after a cold night .
But once underway 5mins late the diff is nice and quite , has also been apart for a inspection and all is fine . Remember the F series diff carrier is not that large so will heat up much faster than my 4.5 litre diff .
There is a 90-140 Shell special transaxle / diff oil which is also good , but very hard to get , and costs like $50 a litre .
TE72_Turbo
Re: Penrite Limslip 90 or limslip 140, what should I use? Wed, 24 November 2004 12:09 Go to previous messageGo to next message
Hmm, maybe I should reconsider the Castrol LSX90 that I've been using in my F series LSD, considering Canberra's summer temps.
feral4mr2
Bundaberg, Qld.
Re: Penrite Limslip 90 or limslip 140, what should I use? Wed, 24 November 2004 12:14 Go to previous messageGo to next message
Penrite Limslip 90 seems to be working well in the feral's LSD tansaxle.
and it's a funky blue colour..... Razz
TE72_Turbo
Re: Penrite Limslip 90 or limslip 140, what should I use? Wed, 24 November 2004 12:19 Go to previous messageGo to next message
Always a bonus! Gotta go get some now! Laughing
ae95
Re: Penrite Limslip 90 or limslip 140, what should I use? Wed, 24 November 2004 12:20 Go to previous messageGo to next message
heh
so's the 140
nice and blue
Jag7799
Re: Penrite Limslip 90 or limslip 140, what should I use? Wed, 24 November 2004 12:35 Go to previous messageGo to next message
getting it tomorrow from mate at repco
ae86trueno
Re: Penrite Limslip 90 or limslip 140, what should I use? Wed, 24 November 2004 21:26 Go to previous messageGo to next message
Penrite 10/10th syn gear oil has kept my LSD and geardbox working great for the last 2 years, but it aint cheap !
Ben.
takai
Re: Penrite Limslip 90 or limslip 140, what should I use? Wed, 24 November 2004 21:48 Go to previous messageGo to next message
Especially at the rate which you crazy rally guys cnage your oils..,.
bbaacchhyy
Re: Penrite Limslip 90 or limslip 140, what should I use? Wed, 24 November 2004 22:47 Go to previous messageGo to next message
Castrol SA-FX - fully synthetic, and I used it in my cct car and never had an issue. It is 140 weight as well, and is recommended for JZA80 Supras too.
Jag7799
Re: Penrite Limslip 90 or limslip 140, what should I use? Wed, 24 November 2004 23:41 Go to previous messageGo to next message
ive already got my mate at repco to get me limslip 140.. so ill see how it goes Smile
hopefully this runs smoother than 20 y/o oil
Toobs
Re: Penrite Limslip 90 or limslip 140, what should I use? Thu, 25 November 2004 03:50 Go to previous messageGo to next message
DO NOT USE 140 weight oil in a gearbox designed for 90 weight oil!
Unless you want your diff to overheat from oil cavitation that is!
75W/90 API GL5 suits most toyota diffs and it would be best to stick to it!
Go the full synthetic gearbox oil if you want to put better oil in your gearbox.
Toobs
Re: Penrite Limslip 90 or limslip 140, what should I use? Thu, 25 November 2004 04:08 Go to previous messageGo to next message
Even the Hiace, Liteace, Dyna, Hilux, Landcruiser, Bundera and almost all of the Hino trucks use 75W/90 gearbox oil. Even the bloody forklifts use 75W/90!
Even most Mack truck gearboxes recommend 75W/90 or 85W/90
Examples of vehicles which recommend 140 weight oil are:
Western Star:
-Eaton
-Meritor
-Dana
-Sizu
some use TC50
Scania
-Almost all models some use TC50
Isuzu
Kenworth
-Several models, most use TC50
M.A.N.
-Several models, some use 85W/90 others use TC50
So unless your "5pr!n74h iz f00ly w3rked" and you have done a Western Star gearbox and diff conversion you shouldn't be running 140 weight gearbox oils!
bbaacchhyy
Re: Penrite Limslip 90 or limslip 140, what should I use? Thu, 25 November 2004 04:12 Go to previous messageGo to next message
Toobs,
He is talking about the diff, but your point is taken.
The stuff that I mentioned is suitable/recommended for the DIFF in a JZA80, and that has a Torsen centre, and from my past experience, will definitely use it myself.
The same point that Toobs makes IS important for engines as well.
Toobs
Re: Penrite Limslip 90 or limslip 140, what should I use? Thu, 25 November 2004 04:36 Go to previous messageGo to next message
bbaacchhyy wrote on Thu, 25 November 2004 15:12
Toobs,
I can't find anything on what the manufacturers specs on the mark 4 diff are but the mark 3 uses LS90 in the diff and 75W/90 in the gearbox.
Toobs
Re: Penrite Limslip 90 or limslip 140, what should I use? Thu, 25 November 2004 04:41 Go to previous messageGo to next message
This is where we normally get our manufacturers data from:
http://www.datateck.com.au/lube/shell_au/
http://www.datateck.com.au/lube/mobil_au/
http://www.datateck.com.au/lube/bp_au/
170bhp
Re: Penrite Limslip 90 or limslip 140, what should I use? Fri, 26 November 2004 07:53 Go to previous messageGo to next message
I have been using castrol saf-xa synthetic for years, works good.
Jag7799
Re: Penrite Limslip 90 or limslip 140, what should I use? Fri, 26 November 2004 08:49 Go to previous messageGo to next message
They didnt end up having limslip 140 from penrite.. so I got castrol limited slip oil thats still 140 grade.. so its all good
feels heaps nicer and tighter especially when wheel spinning is involved
V8_MA61
Re: Penrite Limslip 90 or limslip 140, what should I use? Sat, 27 November 2004 06:29 Go to previous message
penrite limslip 85w140 is the right oil to use. I use it in the ma61, ma70 and fairmont ghia's LSD's and they all work beautiful on it.
Previous Topic:Thermo Fans Wont Clear 3SGTE Engine!!!!!!!!
Next Topic:Cressida mx62 Efi Enquiry
Current Time: Sat Oct 24 12:38:22 UTC 2026
Total time taken to generate the page: 0.0074350833892822 seconds
