Toymods » Tech & Conversions » Mounting bonnet scoop permanently
GT4BOOSTD
Mounting bonnet scoop permanently Wed, 24 November 2004 09:45 Go to next message
Hey guys i just wanted to know what other options i have to secure my scoop to my bonnet. i bought the scoop today and the guy said that use the double sided tape provided and or urethane stuff but i think i will need something more permanent like epoxy resin or something. If you could assist me in any way i would appreciate it.
feral4mr2
Bundaberg, Qld.
Re: Mounting bonnet scoop permanently Wed, 24 November 2004 12:25 Go to previous messageGo to next message
a lot of universal bonnet scoops have little metal tabs that a screw can be put from underneathe into the tab once holes are drilled through the bonnet to fix the scoop more securely than double sided tape.
if you are planning on cutting out the bonnet under the scoop to make it more functional (only the sheet metal not the underside bracing) you could use fibreglass to permantly bond the scoop to the bonnet. make sure you scuff the scoop and the paint thouroghly around the area you might fibreglass to ensure a good bond from the scoop to the bonnet. (this goes for the top side as well (if you wanna glass the seam to the top side of the bonnet, which i recomend).
GT4BOOSTD
Re: Mounting bonnet scoop permanently Wed, 24 November 2004 21:08 Go to previous messageGo to next message
Cheers feral4mr2 thats what i was thinking but the guy at SSV who sold it to me said that the bond will most likely crack. But i am going to do it anyway and mould it into the bonnet so that u cannot see the seam.
1gt48u
newcastle
Re: Mounting bonnet scoop permanently Wed, 24 November 2004 21:12 Go to previous messageGo to next message
how about getting it fiberglassed ??
feral4mr2
Bundaberg, Qld.
Re: Mounting bonnet scoop permanently Thu, 25 November 2004 08:37 Go to previous message
glass it properly, underside where it meets the metal from the bonnet (if you can get to it) as well as the top and it shouldnt crack at all.
use some weave cloth or thin chopped strand, bit of bog, primer filler and paint it. then post some pics. Smile
Previous Topic:7M-GTE ECU's
Next Topic:RA28 fuel sender unit
Current Time: Fri Nov 20 15:02:32 UTC 2026
Total time taken to generate the page: 0.0099010467529297 seconds
