Classifieds » Miscellaneous » plug'n'play ECU for supra 2jzgte-Haltech E6K
MAZMAN
plug'n'play ECU for supra 2jzgte-Haltech E6K Thu, 10 October 2002 14:11
would like to know if any1 out there is keen on a haltech e6k that is made to be a plug'n'play for the supra tt? 6speed.
you get the E6k(latest firmware)
software
3bar MAP
adapter to suite
manual
wiring diagram of all the connections
fuel pump relays
2step control
haltech boost control valve(so you can use electronic boost)
plate to bolt on the haltech ecu in the original position
486 laptop in carry bag
cable
so everything you need to run the supra.
what you do is,
take out the standard ecu,plug in this adapter(its called "field") to the original supra's loom and then plug the haltech ecu to this adapter.cant get much easier then that!
no cutting of looms and you use the original sensors that are on the supra.
there are a few things that you'll have to do ,but it only takes around an hour or so.
1.you'll have to make your fuel pump run constant 12V
2.place the MAP sensor in the engine bay.
3.run a wire from your IGN- to the ecu.
4.and run your turbos in TTC(true twin conversion),you can run them sequential but i havent configured them out.
5.O2 is not connected as i never wanted it(you can if you want to)
there is no modifications to do for the cam or crank sensors,coils ect...,runs everything as is
If some1 is to buy it,i can show you all these things and explane to you how to do it,ill even leave the ecu running for ya in the car until you buy it(so you can hear and see it running),and then ill take everything out infront of you and explane along the way.
so it will be a piece of cake for you to fit it.
there is way too much to write in here so ill just see if any1 is interested first.
I do have the original loom if some1 wants to run it on a different engine...but this is a one of a kind deal for the supra guys out there
Ill will give you also a starting map for you to use,but you'll have to tune it for your spec engine on a dyno/road
I am in Sydney
To get all this that i have you would be looking at paying $3K
the FIELD adapter alone cost me $600.
anyway,im looking at $2K for all this.
if interested please email me at: mazman808@hotmail.com
or PM me in here,or leave a reply and ill get back to ya within a day.
P.S. sorry for the long post
Previous Topic:3tgte turbo
Next Topic:Free 4AC
Current Time: Sat Oct 24 06:39:52 UTC 2026
Total time taken to generate the page: 0.0040748119354248 seconds
