Toymods » Tech & Conversions » 1zj AFM limit
Silver_r33
1zj AFM limit Thu, 25 November 2004 05:17 Go to next message
Hey guys,
I've tried to search both here and google, but to no avail, so does anyone know of the limit or near limit of the 1JZ-GTE (late model, VVTi) AFM? I know injectors are 380cc...
Thanks!!
Soarer
Wollongong
Re: 1zj AFM limit Thu, 25 November 2004 07:15 Go to previous messageGo to next message
Injectors are actually 430cc... the old 1JZ twin turbo uses 380cc.
Not sure about the AFM limitations. If you upgrade to a PowerFC ECU, you buy an additional wiring kit to turn it into a MAP instead from memory.
stark
Re: 1zj AFM limit Thu, 25 November 2004 10:11 Go to previous messageGo to next message
Soarer wrote on Thu, 25 November 2004 18:15
A Common Miconception mate... Yes toyota did change the injectors from the TT to the VVTi one... They changes from yellow top side feed injectors to Denso Grey top Top feed injectors.
Because of the angle the injectors are on the injectors are extremely narrow... However the VVTi items are indeed 380cc and not 430cc as stated on many sites... I have confirmed this with Denso..
Soarer
Wollongong
Re: 1zj AFM limit Thu, 25 November 2004 22:36 Go to previous messageGo to next message
Hmm... fair enough then. I got the info from a guy with a Soarer with the VVTi engine.
stark
Re: 1zj AFM limit Fri, 26 November 2004 04:27 Go to previous messageGo to next message
Soarer wrote on Fri, 26 November 2004 09:36
Yeah its one of the favourite rumours surrounding these engines... When I bought mine however it didnt come with injectors so on my hunt for factory injectors I found out from denso that they are in fact 380cc just like the TT ones
E30-323ti
Re: 1zj AFM limit Fri, 26 November 2004 05:04 Go to previous messageGo to next message
My friends JZX100 MKII Tourer V hits boost cut around 18psi on the stock turbo.
If that is what you wanted to know??
pannelvan_screema
Campbelltown, NSW
Re: 1zj AFM limit Fri, 26 November 2004 15:08 Go to previous messageGo to next message
Hey guys a bit off topic but do all TT 1J's come with yellow plug 380cc injectors
Richard
stark
Re: 1zj AFM limit Sat, 27 November 2004 00:03 Go to previous message
pannelvan_screema wrote on Sat, 27 November 2004 02:08
Richard
Yep all the TT 1JZ's are 380cc Side Feed Yellow top injectors
The later single vvti motor had 380cc Top Feed Denso Grey injectors
Previous Topic:1jz oil catch can or other?
Next Topic:How to adapt 4AGZE CAS to 20v head...
Current Time: Wed Oct 14 23:53:22 UTC 2026
Total time taken to generate the page: 0.03960394859314 seconds
