Toymods » Tech & Conversions » 4age cams
General_Bupkiss
Penrith, Sydney
4age cams Thu, 25 November 2004 07:25 Go to next message
I have a spare 4age big port in my backyard and i driver an sx corolla with a small port 4age, my questiion is are the cams the same from the big to small port. i would like to know as soon as how I have the big port out back I can pull the cams off that and have them ground down or modified and then just switch them when i get them back, instead of having the sx off the road waiting for cams. If this can be done, how much or what degree should i get them done at so i get more power, but don't have to modify any other aspect of the engine yet.
FKN16V
NSW, East Coast
Re: 4age cams Thu, 25 November 2004 09:08 Go to previous messageGo to next message
To put it simply yes, big port cams fit small port motors, power/torque isnt all that noticeable thou, not really worth the effort.
If you gonna geta set of cams ground down you might as well do it properly with a new set of cams from "Wade cams". Sell any cams you have to help $$$$.
There not expensive and you can choose whatever duration and lift you need.
Dont goo too wild with the standard ecu, it wont work.
Search the forums, its been covered heaps already.
Steve
Re: 4age cams Thu, 25 November 2004 10:13 Go to previous messageGo to next message
I ordered some cams from Wade on Monday - I'll letcha know how long they take to get done!
General_Bupkiss
Penrith, Sydney
Re: 4age cams Fri, 26 November 2004 04:14 Go to previous messageGo to next message
cool thanx guys
Re: 4age cams Fri, 26 November 2004 08:52 Go to previous messageGo to next message
Must say I was impressed actually, I rang Wade today, and the cams were done, so I went and picked them up. Oddly enough, they look like cams! Not much else I can say by just staring at them...
Rallystanza
Re: 4age cams Fri, 26 November 2004 23:43 Go to previous messageGo to next message
Shinny did ya get these cams for the 4AGTE? If so what are the specs??
Jezza
General_Bupkiss
Penrith, Sydney
Re: 4age cams Sat, 27 November 2004 00:53 Go to previous messageGo to next message
how much did they set you back if you don't mind me asking.
and do you guys think 256* with 8, maybe 8.5 mm lift would work fine on the standard ecu?
ae86drift
sydney.au
Re: 4age cams Sat, 27 November 2004 03:34 Go to previous messageGo to next message
General_Bupkiss wrote on Sat, 27 November 2004 11:53
not sure about that lift but the duration is ok
pepsicola
Re: 4age cams Sat, 27 November 2004 04:04 Go to previous messageGo to next message
from what i read, 8 or 8.5mm is too much for the stock spring.
General_Bupkiss
Penrith, Sydney
Re: 4age cams Sat, 27 November 2004 06:16 Go to previous messageGo to next message
so what 7.5mm, I thought the standard was 7.4 so i was thinking 8 would be ok, but i really don't know
Re: 4age cams Sat, 27 November 2004 10:39 Go to previous messageGo to next message
Cost is $200 each + GST, so $440 for the pair.
I got 280 deg. duration and 8.6mm lift in basic terms
General_Bupkiss
Penrith, Sydney
Re: 4age cams Sat, 27 November 2004 12:45 Go to previous messageGo to next message
ok now my question is does anyone know a good place in the sydney area that sells them, cause isn't wade's in melbourn.
and mrshin is that on a standard ecu????
SPRINTAH!
Re: 4age cams Sun, 28 November 2004 02:33 Go to previous messageGo to next message
wade is the cheapest you will get them i think, even including postage to Sydney.
postage is about $15
TE72_Turbo
Re: 4age cams Sun, 28 November 2004 03:21 Go to previous messageGo to next message
MrShin, i'll be real keen to hear how they go, I have been looking at the same set of cams from Wade. Are you using the stock springs?
Re: 4age cams Sun, 28 November 2004 07:07 Go to previous messageGo to next message
Call Wade, they'll be happy to post them to you.
I'll also be quite interested to see how they go Evil or Very Mad Sometime in the next few weeks I should be able to tell everyone exactly the difference they make.
I'm going to be changing springs, although some suggest you could probably get away without it... I guess everyone's got their own little bit to say!
Standard ECU? I sort of took a bit of a guess that the poor old stocker wouldn't take too well to the cams, multi throttles, a turbo, LPG, and a moderate number of other select mods, so bought an M800 instead...
TE72_Turbo
Re: 4age cams Sun, 28 November 2004 09:42 Go to previous messageGo to next message
showoff Razz Cool
Re: 4age cams Sun, 28 November 2004 11:33 Go to previous messageGo to next message
Hey, I mounted it today, all tucked away behind the dash, have to pull the glovebox out to even catch a glimpse of it...
TE72_Turbo
Re: 4age cams Sun, 28 November 2004 12:46 Go to previous messageGo to next message
Do you plan to run gas injection or something? Tell us more!
Re: 4age cams Sun, 28 November 2004 13:07 Go to previous message
Something like that...
PM/ICQ me if you want to hear a little bit more
Previous Topic:ae92 levin--> trueno conversion
Next Topic:Urgent, please help 2 LT diesel water pumps
Current Time: Tue Oct 27 02:17:28 UTC 2026
Total time taken to generate the page: 0.0057239532470703 seconds
