Toymods » Tech & Conversions » 1G Head bolt Torque tension figures??
BLK1GGTE
South Eastern Subs
icon5.gif  1G Head bolt Torque tension figures?? Thu, 25 November 2004 07:56 Go to next message
Does anyone know the torque bolt setting for the head. I am replacing the head gasket and I need to know what torques setting to tighten them to. Also the setting for the cam cup holders… or how ever you call them (I think cam shaft bearings) I need those torque settings. Anybody be able to help me at all. I know others have replaced heads before me on this tread so this is my best hope of finding this out.
Also any other torques setting i might need when pulling the head off, that someone knows off and i might have missed??
BLK1GGTE
South Eastern Subs
Re: 1G Head bolt Torque tension figures?? Thu, 25 November 2004 14:38 Go to previous messageGo to next message
Anybody can offer some good advice or?? Please?? I need these Head bolt torque figures in order to do it right?? Any advice would be great??
gold28
Madrid - Spain
Re: 1G Head bolt Torque tension figures?? Thu, 25 November 2004 23:10 Go to previous messageGo to next message
If you talk to your local Toyota dealer, preforably one that has an import parts division, they can get the info for you, but they may charge a small amount for the service.
If you get stuck, Call James at Castle Hill Toyota (Sydney), He is really good with import parts, and knows what he is talking about. Sorry I can't help you out with a closer dealer.
BLK1GGTE
South Eastern Subs
Re: 1G Head bolt Torque tension figures?? Sat, 27 November 2004 03:48 Go to previous messageGo to next message
Thanks for that i'try Castle Hill Toyota cause nobody around here knows anything about it...
Jake001
B risbane
Re: 1G Head bolt Torque tension figures?? Tue, 30 November 2004 22:04 Go to previous messageGo to next message
Following are Torque values for 1GGTE.
Cylinder Head = 48ftlbs / 64nm
Camshaft Retaining Caps = 14ftlbs / 19mn
Cam Gears = 29-39ftlbs / 40-53mn
Main BRG Caps = 43ftlbs / 59nm
Con Rods = 36ftlbs / 49nm
Harmonic Balancer = 130ftlbs / 177nm
Flywheel Bolts = 54ftlbs / 74nm
Exhaust manifold 2 Head = 19ftlbs / 25nm
Inlet manifold 2 Head = 17ftlbs / 23nm
I have more if anyone needs them.
These values were given to me while building my engine and are what i have used. If anyone has conflicting info let me know cause i'm relying on these too.
BLK1GGTE
South Eastern Subs
Re: 1G Head bolt Torque tension figures?? Wed, 01 December 2004 23:36 Go to previous messageGo to next message
These were faxed to me:
Do they match;
Big end bearing: 500 kg.cm
Cam shaft bearing cap: 150 kg.cm
Camshatf Pulley Exaust:475 kg.cm
Camshaft Pulley Intake:475 kg.cm
Cylinder head bolt: 650 kg.cm
Cylinder Head Distortion: 0.2mm (Clearance)
Front camshaft pulley Bolt: 2200 kg.cm
Main bearing bolt torque: 600 kg.cm
Timing Belt tensioner bolt and nut: 220 kg.cm
Timing Belt idler 370 kg.cm
When converted??
HyDrA
Adelaide, SA
Re: 1G Head bolt Torque tension figures?? Thu, 02 December 2004 00:38 Go to previous message
They match (roughly, i'm talking 0.3nm out Razz)
I was talking to a BMW owner, apparently they torque head bolts up to around 90nm!!! I'd be afraid of breaking something Razz
Previous Topic:22RE Engine Compression Rates
Next Topic:exactly what do you need to make brakes work?
Current Time: Mon Oct 26 18:34:21 UTC 2026
Total time taken to generate the page: 0.0053479671478271 seconds
