Toymods » Tech & Conversions » AE92 question, Searching for Fuel Pump Wires . . . .
4A-GTE
Rockhampton, Queensland
AE92 question, Searching for Fuel Pump Wires . . . . Thu, 25 November 2004 22:05 Go to next message
Hello,
I am having a bit of a problem. I own an AE92 Corolla that i have installed a 4a-GZE into, instead of the 4a-FE. I need to locate my fuel pump wires but i have not been able to do so as of yet. Does anybody know where they are located? besides running a new wire to the tank myself. there is one ecu connector that runs from the back of the car up under the carpet to the ecu under the center dash, is it on there?
Daniel
EvilJack
Sutho/Hills NSW
Re: AE92 question, Searching for Fuel Pump Wires . . . . Fri, 26 November 2004 00:32 Go to previous messageGo to next message
lift up the rear seat
adavy84
Perth, WA
Re: AE92 question, Searching for Fuel Pump Wires . . . . Fri, 26 November 2004 06:35 Go to previous messageGo to next message
When i did my gze conversion and using the loop from the half cut, the fuel pump wire ran down the drivers side of the car to the rear.. im not to sure but it was a thinker Blue wire.. but u should be able to find a wiring diagram in the Tec section
hope this helps.
4A-GTE
Re: AE92 question, Searching for Fuel Pump Wires . . . . Fri, 26 November 2004 08:20 Go to previous messageGo to next message
thanks mate i will try to look for the wiring diagrams now in the tech section
jasonp1977
Re: AE92 question, Searching for Fuel Pump Wires . . . . Fri, 26 November 2004 10:03 Go to previous messageGo to next message
thick blue wire with black stripe from the drivers kick panel to the pump.
clubagreenie
1st street on the right
Re: AE92 question, Searching for Fuel Pump Wires . . . . Fri, 26 November 2004 10:52 Go to previous messageGo to next message
Yes it's prob a blue/black wire triggered from a double acting relay. Ign and AFM switched
adavy84
Perth, WA
Re: AE92 question, Searching for Fuel Pump Wires . . . . Fri, 26 November 2004 12:48 Go to previous messageGo to next message
yes thats the one and if ur testing it with a M/Meter just make sure u turn the key to turn the engin over and then the line will stay at 12volds for a few seconds.
4A-GTE
Re: AE92 question, Searching for Fuel Pump Wires . . . . Fri, 26 November 2004 13:10 Go to previous message
thanks guys i will let you know if i have difficulties locating it.
Cheers Smile
Previous Topic:1J with Trust TD06 25G
Next Topic:JDM AW11 ECU plug capability
Current Time: Tue Nov 24 20:33:31 UTC 2026
Total time taken to generate the page: 0.061356067657471 seconds
