Toymods » Tech & Conversions » THermo Fan fuse keeps blowing
ta2272
icon2.gif  THermo Fan fuse keeps blowing Fri, 26 November 2004 07:58 Go to next message
My thermo fan is going pretty consantly and it has a 15 amp fuse, it keeps on blowing the fuse and my motor is getting pretty hot, what should i do check etc, is it safe to use a 20 amp fuse?
Jason
krayzie
Re: THermo Fan fuse keeps blowing Fri, 26 November 2004 08:03 Go to previous messageGo to next message
If you are blowing a fuse you might have a short somewhere. Check your cables going to the fan and make sure there is no stripped wires touching metal. If you know how to use a multimeter it makes the job a lot easier.
sideshow
Re: THermo Fan fuse keeps blowing Fri, 26 November 2004 08:05 Go to previous messageGo to next message
what size fan is it
some kits are shit
they supply a 15 amp fuse for 10 inch fan
then they also supply a 15 amp fuse for a 16 inch fan
thats stupid
if u have thick wiring say 30 amp stuff
then run a 30 amp fuse
it will still blow when theres a bad short but not when the fan starts
V8_MA61
Re: THermo Fan fuse keeps blowing Fri, 26 November 2004 12:11 Go to previous messageGo to next message
id run a 25A fuse...
styler
Re: THermo Fan fuse keeps blowing Mon, 29 November 2004 13:28 Go to previous message
all i can say is fuses are there for a reason...
they melt moments before the circuit does...
over rate the fuse size and the fuse wont melt
but everything else will!
multimeter is your best friend for this job (if suitable),
i agree on the short idea... and it could be possible
to have too small a fuse too - use car ammeter (30 amp) to see how much current the fan only uses, using a new circuit of course to test it.
Previous Topic:Effects of lightening driveline?
Next Topic:engine conversion in KE10 corolla
Current Time: Mon Oct 19 15:04:13 UTC 2026
Total time taken to generate the page: 0.0053970813751221 seconds
