Toymods » Tech & Conversions » Scales.... for weighin pistons n stuff
takai
Scales.... for weighin pistons n stuff Fri, 26 November 2004 10:10 Go to next message
Heya guys
Im goign to be starting my new engine build in the new year, and i want to get a good set of accurate scales for weighing things like pistons, conrods etc etc for the blueprinting.
Was just wondering what people use, and where to get them from. I was thinking a scientific equipment suppliers. As i had a quick peek at Jaycar and DSE and they only had <3kg +- 0.05 scales, or much less accurate <200kg scales.
I guess i woudl be after <10kg i guess. Anyone got some ideas on that side of things?
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: Scales.... for weighin pistons n stuff Fri, 26 November 2004 10:20 Go to previous messageGo to next message
how accurate are digital kitchen scales?
takai
Re: Scales.... for weighin pistons n stuff Fri, 26 November 2004 10:21 Go to previous messageGo to next message
+-0.01kg but max of 2kg generally
Im looking for like +-0.01g or even 0.001 if possible.
[Updated on: Fri, 26 November 2004 10:21]
spectral
Re: Scales.... for weighin pistons n stuff Fri, 26 November 2004 12:06 Go to previous messageGo to next message
i use the ones at work.. they are accurate to .1grams. They were about $500 from memory
http://www.amberaspley.com/gt4/pics/3SGTE/scales.j pg
I don't think you will get 0.01 or 0.001 unless you spend a real fortune
takai
Re: Scales.... for weighin pistons n stuff Fri, 26 November 2004 12:08 Go to previous messageGo to next message
Heh i was looking at you Paul.
I seem to remember the 0.01g accuracy ones we had at school being around 300ish. Inflation sucks.
matt_84
Ipswich
Re: Scales.... for weighin pistons n stuff Fri, 26 November 2004 12:10 Go to previous messageGo to next message
You could find the chem labs at your local university...
*whistles
matt_84
Ipswich
Re: Scales.... for weighin pistons n stuff Fri, 26 November 2004 12:13 Go to previous messageGo to next message
Also, from memory, scales I used that had a degree of accuracy down to what you're chasing were boxed to stop air movement from changing the measurement, and only weighed up to 50gms or so.
takai
Re: Scales.... for weighin pistons n stuff Fri, 26 November 2004 12:28 Go to previous messageGo to next message
Yes, these were boxed. Didnt realise only 50gm though.
matt_84
Ipswich
Re: Scales.... for weighin pistons n stuff Fri, 26 November 2004 12:44 Go to previous messageGo to next message
Not sure, may measure higher, but I'd say trying to find anything more than 500g at an affordable price would be fairly optimistic.
allencr
tallahassee FL usOFa
Re: Scales.... for weighin pistons n stuff Sat, 27 November 2004 15:32 Go to previous messageGo to next message
we're really concerned about balance & equalizing each other, and not their actual weight, right?? what difference does it make what they are.
then a simple balance beam will find the lighest pretty easy.
a stick with a hook on each end, and a string in the middle to hold it up & pivot on, will do OK for this.
SPRINTAH!
Re: Scales.... for weighin pistons n stuff Sun, 28 November 2004 02:28 Go to previous messageGo to next message
analytical balances we use in chem can measure .0001g up to 500g, they have covers around them to stop air movement etc. very expensive.
we also use 5kg ones that have a resolution of 0.01g, these would be fine for what your looking at doing. they shouldn't cost you more than a couple of hundred dollars.
but as allencr said, you are only really interested in the relative weight difference between different parts. not an absolute measurement so you could get away with using cheaper balances.
takai
Re: Scales.... for weighin pistons n stuff Sun, 28 November 2004 02:44 Go to previous messageGo to next message
In this case it does matter. Im going to the next level from just building an engine. I want to test structural stresses on conrods and stuff. For that i need to know pretty precise weights for the pistons as then i can calculate the forces etc.
Re: Scales.... for weighin pistons n stuff Sun, 28 November 2004 04:07 Go to previous message
from livingstone.com.au
http://www.livingstone.com.au/laboratory/Default.A SP?WCI=Product&WCE=18558:DIGS620G&brwsID=3 73878
http://www.livingstone.com.au/ITMimages/DIGS620G.jpg
$1550+GST
http://www.livingstone.com.au/laboratory/Default.A SP?WCI=Product&WCE=18557:DIGS1000G&brwsID= 373878
http://www.livingstone.com.au/ITMimages/DIGS1000G.jpg
$295+GST
accuracy costs Wink
also look to the manufacturer of the post office scales...
when i was looking for a 500gm 0.01gm scale i was looking at around $600-800...
[Updated on: Sun, 28 November 2004 04:08]
Previous Topic:Tailshaft shortening and swapping yokes
Next Topic:Corolla Levin 101
Current Time: Sun Nov 22 18:15:25 UTC 2026
Total time taken to generate the page: 0.0064890384674072 seconds
