Toymods » Tech & Conversions » Effects of lightening driveline?
JAZE
cronulla
Effects of lightening driveline? Fri, 26 November 2004 15:45 Go to next message
Is there anyone out there with experience or info on the effects of lightening driveline components? i was toying with the idea of getting a custom light tailshaft and flywheel and using light rims and a smaller gearbox. If the weight attached to the back of back of the engine is less, it seems logical that it would have much more pronounced effect on power delivery than if i removed the same weight from other parts of the car. The driveline is much more expensive to lighten so im wondering if its worth it. any advice/experience anyone has is much appreciated.
cheers.
Re: Effects of lightening driveline? Fri, 26 November 2004 16:28 Go to previous messageGo to next message
I doubt it would be worth it for stuff like a tailshaft. You wouldn't be able to shave off a great deal of mass, and most of the mass is close to the centre of rotation anyway. This is the sort of thing you'd do on a big-dollar race car when you're chasing the last few poofteenths; you'd never notice it on the street.
Lighter rims can be a good thing, but there's only so far you can go before they become too flimsy for regular street use (ie pothole = bent rim).
Stefan
Hobart, Tas
Re: Effects of lightening driveline? Fri, 26 November 2004 23:16 Go to previous messageGo to next message
Lightened flywheel will let the engine spin up more easilly, at the cost of making hill starts etc more difficult (AFAIK) but that's somethign different entirely.
I actually thought a lighter driveshaft would make more of a difference than that... reduce drivetrain losses.... the 350Z has a carbon fibre one IIRC.
Gazza53
Re: Effects of lightening driveline? Sat, 27 November 2004 00:16 Go to previous messageGo to next message
Yes lightening the flywheel will let the engine rev up quicker at the expense of idle smoothness.
I had a group n mini cooper s some time ago in which i reduced the flywheel from 16lb to 9. It made a huge difference in acceleration but wouldn't idle much below 1200rpm (full race cam didnt help here also).
You have to be carefull in the choice of flywheel material (ie steel & not cast) and CAMS requires that a cluth / flywheel scatter shield be installed around the bell housing to stop the bits chopping your foot off or other bits (remember where a mini clutch is positioned) should the thing decide to destroy itself at 8000 rpm.
gold28
Madrid - Spain
Re: Effects of lightening driveline? Mon, 29 November 2004 02:45 Go to previous messageGo to next message
It depends on where you want to make better acceleration. A lighter flywheel will make low speed acceleration a lot better, whereas lighter wheels/tyres and drive shaft will make high speed acceleration better. The difference being the gearing.
My guess is that there is more to be gained in tyre selection than in the driveshaft.
Hirogen
Melbourne, Australia
      WTF is a jabber?
Re: Effects of lightening driveline? Mon, 29 November 2004 12:44 Go to previous messageGo to next message
heh, poofteenths. Laughing
styler
Re: Effects of lightening driveline? Mon, 29 November 2004 13:50 Go to previous message
common to have lightened flywheel and mag wheels - not goddam huge chromies Rolling Eyes but superlites or proper "magnesium alloy" nowadays "lightweight alloy type" wheels...
and if anyone is chasing a few poofteenths of a second Laughing
then lighten the rest... else i wouldnt bother as it would weaken it most probably, nothing like having a lightweight custom $1000 driveshaft break cos it was weakened Razz
[Updated on: Mon, 29 November 2004 13:56]
Previous Topic:Help re: new/old seats for KE50 Corolla..
Next Topic:THermo Fan fuse keeps blowing
Current Time: Mon Oct 19 11:59:31 UTC 2026
Total time taken to generate the page: 0.0047299861907959 seconds
