Toymods » Tech & Conversions » sprinter diff seal
sprinter diff seal Fri, 11 October 2002 05:16 Go to next message
Hello, the sprinter has got a leaky diff around the seal between the diff and housing. How hard is this to change? I'm guessing the axles and diff needs to be removed? Sad not fun!
Any easier way? hints & tips?
Thanks!
jazae86
Re: sprinter diff seal Fri, 11 October 2002 16:11 Go to previous messageGo to next message
I was gonna replace the pinion seal on my diff, but found out the staked nut on pinion would need to come off and then outer housing off, the seal out, new seal on, put back together. Don't think shafts had to come out.
BUT
the staked nut needs to be torqued back on and the lash of the diff cheacked. I realised the diff was too cacti to bother (you could load the diff by the lash, like let clutch out little, feel the lash take up, then the wheels slowly turn), so I swapped the diff over when i got my new shell. Very Happy
Find someone with an Haynes America AE86 Manual and photocopy. It has all the info. Tho a TA22 book or anything with the same era diff will have the same info.
Jaz
Statts
Adelaide, SA
Re: sprinter diff seal Sun, 13 October 2002 13:07 Go to previous messageGo to next message
These gaskets are not available in the aftermarket, as far as I know. Everytime I have needed to take a sprinter diff apart, I have needed a new gasket, and had to get from toyota.
Chris
hiaaa
Re: sprinter diff seal Mon, 14 October 2002 07:28 Go to previous message
Use the drum to pop out the axles, remove the diff from hosing and clean both surface, apply some silicone gasket maker on both side and put back together, done.
Previous Topic:Exhaust Drone - Dumpie v's Straight pipe
Next Topic:What needs to be done to fit 1989 W58 box in RA28???
Current Time: Sat Nov 21 15:35:03 UTC 2026
Total time taken to generate the page: 0.0035829544067383 seconds
