Toymods » Tech & Conversions » anyone with a rotary?
kdogg
leumeah NSW
icon14.gif  anyone with a rotary? Sun, 28 November 2004 01:46 Go to next message
dont suppose anyone has a rotary. Im looking at how much it would cost to put a 12a into a ke20.
also anyone got any idea where to get the brackets made in sydney to adapt it into the engine bay. Question
joyride
fairfield NSW
Re: anyone with a rotary? Sun, 28 November 2004 02:25 Go to previous messageGo to next message
www.ausrotary.com
styler
Re: anyone with a rotary? Sun, 28 November 2004 07:48 Go to previous messageGo to next message
i was keen to do a rotary conversion but id check regulations
cos u may need to get it engineered $$$
qld we cant do 12a in ke20 easily cos its under weight
dunno about anywhere else tho..
ke20 around 760 kg
motor 12a x 2 rotary capacity conversion = 2.400L
motor conversion n/a 760 x 3 = 2.280L max capacity
motor conversion turbo 760 x 2.5 = 1.900L max capacity
well good luck anyways Very Happy
R-jay
Re: anyone with a rotary? Sun, 28 November 2004 13:37 Go to previous messageGo to next message
ill post some pics of ae86 13b turbo tomorrow if i can find them... car is being worked on so i wont be able to take any fresh pics for awhile.... goes like a demon, but unfortunately, nearly impossible to engineer... notice i said "nearly"... hope to have it legal early-mid '05.
will be making an appearance at the Lextreme meet in dec 5.. anyone who comes can take a peak, hehe....
R-jay
Re: anyone with a rotary? Sun, 28 November 2004 13:43 Go to previous messageGo to next message
oh forgot to answer your question....
extremely easy to convert because of it's tiny size.... only trouble would be with the trans tunnel as the rotor gearboxes normally dont fit the early yota tunnels (ours needed customisation)....
as for mounting, a 12a mounts the engine from the front, not the sides like conventional engines.... so basically, just bolt/weld in a square pipe crossmember where the engine will line up and bolt it onto that....
our 13 b conversion was done by swapping the timing cover at the front to a 12a spec (so it could be mounted from the face)... parts are interchangeable....
and if you're doing a rotor conversion, brakes and diffs need upgrading... so far, the diff has held out, but the front end has been converted to ford hubs (5 stud) and slotted disc with commodore calipers.... rear will be converted to hilux diff and will have disc brake conversion done also....
car goes harder than most cars ive come across in it, and pulls up quite nicely with the new brakes....
Re: anyone with a rotary? Sun, 28 November 2004 14:05 Go to previous messageGo to next message
styler wrote on Sun, 28 November 2004 18:48
ke20 around 760 kg
same for NSW..
MAY need to get it engineered?? if your KE20 came with a K motor, technically a 4K needs to be engineered (greater than 15% increase in capacity)
you will not be able to get a KE20 engineered with 12A in NSW.. and you do need to cut the tunnel out and fit in/make a bigger one as the crank (Wink) sits higher in a rotary...
[Updated on: Sun, 28 November 2004 23:49]
R-jay
Re: anyone with a rotary? Sun, 28 November 2004 22:08 Go to previous messageGo to next message
anything is possible.... if that was the case, how the hell do people get away with 13b turbo's in r100's, rx2's and rx3's let alone a 20b (seen enough 20b's in rx3's to think something is wrong)....
our engineer says we can get our 86 engineered if you can up the weight past 1000kg and address the chassis strength and braking issue...
braking has been sorted though he wants us to convert the rear to discs.... other than that, just pass emmisions and we're set to go....
styler
Re: anyone with a rotary? Sun, 28 November 2004 23:34 Go to previous messageGo to next message
oldcorollas wrote on Mon, 29 November 2004 01:05
as the crack sits higher in a rotary...
therefore making it fart a lot...
[Updated on: Sun, 28 November 2004 23:38]
styler
Re: anyone with a rotary? Sun, 28 November 2004 23:42 Go to previous messageGo to next message
the rota's are mad engines
brap brap brap braaaaaaap
i want 13b ke25
Re: anyone with a rotary? Sun, 28 November 2004 23:54 Go to previous messageGo to next message
R-jay wrote on Mon, 29 November 2004 09:08
thats not entirely true. it is NOT LEGAL to fit a 13B in a KE20.
the weight used for capacity changes is the ORIGINAL weight. an engineer who uses the new weight is a) dodgy, and b) acting illegally.
if you crash, kill someone, and get taken to court, you and the engineer will be rooted.
ppl have them in the light mazdas because either they were engineered before the restrictions came in (like the V8 KE30 etc), or because their engineer is dodgy. simple as that.
you know all those modern cars in magazines with turbo conversion and aftermarket computers? NONE of them are legal, simply from an emissions point of view.
it is sort of a grey area from the publics point of view, but basically there are guidelines and limits for engineer certified. if an engineer certifies past those limits and gets takemn to court, you and he/she will lose. simple as that. they can't legally engineer past the limits (unless it is an ICV)
hope that clears some thing up Wink
styler
Re: anyone with a rotary? Mon, 29 November 2004 00:19 Go to previous messageGo to next message
agreed...
a lot a cars were done before regulations changed.
when i say engineered i dont mean an approved mod code
la, lb, ld, lg, lh etc
i mean like submitting a reinforced chassis design and
upgraded driveline proposal to the transport approval
engineers $$$ ... like kit car builders have to do
goddam rotary 2x capacity rule sux
R-jay
Re: anyone with a rotary? Mon, 29 November 2004 02:17 Go to previous messageGo to next message
styler wrote on Mon, 29 November 2004 11:19
exactly what we're going to do... chassis is being reinforced and engineer is going over it with a fine tooth comb... costs all up just for engineer's repotr/cert is close to $4k....
he basically said if he can't pass it legally after we do everything he says, then there is no charge... it'd just be a massive waste of our own labour.. which costs nothing, hehe.
[TOYROTA]
A.C.T
Re: anyone with a rotary? Wed, 01 December 2004 06:43 Go to previous messageGo to next message
Like they said, all the R100's RX2's RX3's etc that have 13Bturbos have all been engineered in the period where it was legal, hence sometimes stumbling across seemingly ridiculously priced ones. They're the legal ones. All the others (like my RX3) are either illegal or dodgied up. On the rego papers my 808 sedan has a standard 13B which used to come out with a 12A. doesnt look very deadly there. The truth is it used to have a pissy little 4cylinder and now has a full RX3 conversion with a 600hp 13B bridgeport turbo good for 9's. Do you understand now why they wont make these cars legal for the street... haha
Andre
old_mr2
Re: anyone with a rotary? Thu, 02 December 2004 08:33 Go to previous messageGo to next message
R-jay wrote on Mon, 29 November 2004 00:37
DAMN that would be awesome!
Mookie
Tassie
Re: anyone with a rotary? Fri, 03 December 2004 00:48 Go to previous messageGo to next message
I'm sick of replacing the VW motor in my RV would a rotary be too powerful u guys think?
the revs are kept pretty high and it does cop a massive beating everytime it's driven .
It's Off road only to it doesn't have to be legal .
rb20det
Re: anyone with a rotary? Fri, 03 December 2004 13:15 Go to previous message
the guidelines for the rta in nsw are only guidelines. anything can get engineered but u will need to upgrade brakes chassis diff ect to cope with the new engine. im currently engineering my rb31dett powered lj torana. ive had the chassis strengthened have new lsd and 4spot ap calipers on 330mm rotors at front and 2spot brembos on back. rod hadfield got that beast of his with the mustang"aeroplane" engine regoed so a 12a na rota should be easy.
Previous Topic:Are these common problems with 1998 2.2 Camry?
Next Topic:AE82 rearbrakes, sending me around the twist.
Current Time: Sat Oct 31 19:09:16 UTC 2026
Total time taken to generate the page: 0.0066850185394287 seconds
