Toymods » Tech & Conversions » Any advantage of a front mount on a 4AGZE AE92 JDM?
NERD
Any advantage of a front mount on a 4AGZE AE92 JDM? Sun, 28 November 2004 03:22 Go to next message
Hi All,
Im wondering what advantages, if any, are there of frount mounting the intercooler of a 4AGZE AE92 JDM (2 door coupe)?
ROLLA GTi
Re: Any advantage of a front mount on a 4AGZE AE92 JDM? Sun, 28 November 2004 12:07 Go to previous messageGo to next message
On a standard 4AGZE i dont think so,
You would lose pressure due to the length of the coolor/piping even with a big pulley kit you still only get 10-11 psi with a sizeable front mount
drift86levin
brisvegas
Re: Any advantage of a front mount on a 4AGZE AE92 JDM? Mon, 29 November 2004 00:25 Go to previous messageGo to next message
huge increase in efficientcy..is that an advantage? think about it..your ic is sitting atop a really friggen hot engine..and the only air it gets is from a 2" if that high scoope..there is not much design so the air can actually flow through the cooler..just hit the top of it..using the FMIC on an ae92 has quite a significant gain..especially if its a good custom core..i have a 400x250x60 front mounted on the ae86 and it works a treat..response is fabulous....use 2" piping.. and a core similar toi that size..tube and fin..custom one..not a cut down factory type..this is where ppl go wrong..i have the stock pullys on mine and with the ice/water spray on a cold 2am morning i see about 10.5 psi at the manifold..
cold air is better than hot air at nearly everything!
Corona RT142
Campbelltown
Re: Any advantage of a front mount on a 4AGZE AE92 JDM? Mon, 29 November 2004 00:33 Go to previous messageGo to next message
cold air also has a much lower volume thus even if the psi reading is lower more air is actually going in. With a higher psi and colder air temp you will be getting shit loads more air into the engine.
NERD
Re: Any advantage of a front mount on a 4AGZE AE92 JDM? Mon, 29 November 2004 01:21 Go to previous messageGo to next message
Thanks all for the replies.
drift86levin, thats the main reason why I want to frount mount a cooler as its currently really an interheater than a cooler.
I was thinking 2" piping from the SC and 2.5" to the inlet to aid response.
My main concern was that the blower was low boost so a larger cooler would be a big pressure drop but as its giving 8-10 psi, I think I'll go ahead.
Cheers fellas.
drift86levin
brisvegas
Re: Any advantage of a front mount on a 4AGZE AE92 JDM? Mon, 29 November 2004 04:47 Go to previous messageGo to next message
NERD wrote on Mon, 29 November 2004 12:21
Cheers fellas.
not the case..a similar size aftermarket core will do the job fine..as for befor the supercharger, i recomend doing a 4age/3sge throttle body conversion..takes about 30 mins all up to do..the throat itself is about 10mm larger..slightly 'dremel' out the SC down pipe (the butterfly hits) and whack her on with you TPS switch..go for gold! 10hp..FMIC, you'll be laughing!
NERD
Re: Any advantage of a front mount on a 4AGZE AE92 JDM? Wed, 01 December 2004 05:55 Go to previous messageGo to next message
DRIFT86LEVIN - in regards to the 4age/3sge throttle body conversion, how much would i be looking at to do the conversion? is it easily do-it-yourself work?
and sorry about the ignorance, but what did u mean when you said TPS switch?
PM also sent
[Updated on: Wed, 01 December 2004 05:55]
jasonp1977
Re: Any advantage of a front mount on a 4AGZE AE92 JDM? Wed, 01 December 2004 06:49 Go to previous messageGo to next message
we had a dyno day on the weekend with a heap of 16V, 20V, GZE's and 4agte's.
Here's two graph's from the day, the first is a MAP 4agze on stock computer with stock topmount, the second is a MAP 4agze with stock TMIC moved to the front on stock computer, both are running stock crank pullies.
http://www.rollamods.com/dynoday/016.gif
http://www.rollamods.com/dynoday/019.gif
The rest of the graphs can be found here:
http://www.twincam.org/forums/index.php?showtopic= 10946&st=0&#entry132593
FWIW, my car made .6 kw more in 4th than it did in 3rd with the dyno in shootout mode
[Updated on: Fri, 03 December 2004 06:15]
TE72_Turbo
Re: Any advantage of a front mount on a 4AGZE AE92 JDM? Wed, 01 December 2004 13:30 Go to previous messageGo to next message
wow. I didn't realise they ran quite so rich up top, with stock pulley.
takai
Re: Any advantage of a front mount on a 4AGZE AE92 JDM? Wed, 01 December 2004 20:23 Go to previous messageGo to next message
You shoudl see them with a HKS or NEVO pulley. Goes rich as crap in the top end.
As for the front mount, i see a .4psi drop (according to the dyno pressure readings) from the theoretical 10psi which the HKS 164mm pulley would normally give me.
jasonp1977
Re: Any advantage of a front mount on a 4AGZE AE92 JDM? Wed, 01 December 2004 21:43 Go to previous messageGo to next message
that's interesting,
I got a solid 12psi with an unknown brand 164mm pulley and HKS GZE topmount. Before the topmount it would drop from 12psi to 10psi when hot using the stock cooler.
takai
Re: Any advantage of a front mount on a 4AGZE AE92 JDM? Thu, 02 December 2004 03:18 Go to previous messageGo to next message
Interesting, maybe i still have a boost leak after all. I thought the 164mm pulleys were 10psi rather than 12psi.
jasonp1977
Re: Any advantage of a front mount on a 4AGZE AE92 JDM? Thu, 02 December 2004 03:23 Go to previous messageGo to next message
not sure, or maybe your charger is a little tired. My MAP GZE used to make 9-10psi on the stock pulley with stock topmount.
takai
Re: Any advantage of a front mount on a 4AGZE AE92 JDM? Thu, 02 December 2004 03:26 Go to previous messageGo to next message
Hehe, quite possible its a little tired, makes this interesting whining/whistling sound, along with a few burbling ones. Laughing I have one port of call left to see if there is a leak. Ill check it out eventually, after i have finished with my 86.
NERD
Re: Any advantage of a front mount on a 4AGZE AE92 JDM? Fri, 03 December 2004 04:04 Go to previous message
ROLLA GTi wrote on Sun, 28 November 2004 23:07
Do you guys think that much of the power/pressure will be lost due to a longer lenght IC piping?
Previous Topic:Garrett GT series Compressor maps
Next Topic:1ggte ecu's - How do you know if it's a gen 3?
Current Time: Sun Nov 1 13:22:57 UTC 2026
Total time taken to generate the page: 0.008929967880249 seconds
