Toymods » Tech & Conversions » 22RE Engine Compression Rates
MaCCa
22RE Engine Compression Rates Sun, 28 November 2004 11:43 Go to next message
Evening...,
Well due to a lack of power in my 85 RA65 i did a compression test but cannot find the factory specifications to compare my results with
Any info greatly appreciated
Craig..
MaCCa
Re: 22RE Engine Compression Rates Tue, 30 November 2004 04:13 Go to previous messageGo to next message
Anyone
Re: 22RE Engine Compression Rates Tue, 30 November 2004 04:43 Go to previous messageGo to next message
Anything over 150psi warm is good
Anything varying more than 10psi is bad.
What were the results?
CLG
Perth, Western Australia
Re: 22RE Engine Compression Rates Tue, 30 November 2004 05:23 Go to previous messageGo to next message
I think you'll find it's more a variance of 10% not ten psi. I have a 22RE with 175psi cold.
12501187
Wodonga, Vic
Re: 22RE Engine Compression Rates Tue, 30 November 2004 09:41 Go to previous messageGo to next message
i was just wondering what i could do to my 85 celcia 22re engine to go a little bit harder
Johnny
Sydney, OZ
Re: 22RE Engine Compression Rates Tue, 30 November 2004 10:19 Go to previous messageGo to next message
replace it will be the most common reply here.... but you could go down the traditional means, air filter exhaust, head work, new ecu etc...
MaCCa
Re: 22RE Engine Compression Rates Wed, 01 December 2004 00:03 Go to previous messageGo to next message
1-100
2-96
3-100
4-96
What do you think of that Sad
Re: 22RE Engine Compression Rates Wed, 01 December 2004 00:24 Go to previous messageGo to next message
Sounds like the rings might be stuffed.
That was PSI wasn't it?
Test it again, but this time put a few drops of oil in the cylinder.
This will tell you if its rings not sealing, or valves not sealing.
Re: 22RE Engine Compression Rates Wed, 01 December 2004 00:26 Go to previous messageGo to next message
you remembered to do the test with WOT? (i forget sometimes Wink )
if so.. that's badd mmmkay
MaCCa
Re: 22RE Engine Compression Rates Wed, 01 December 2004 00:41 Go to previous messageGo to next message
Well iam not sure if it was PSI or KPA
But if it was KPA it doesnt seem to be correct, but iam 95% sure it was KPA (dont have access to the tester anymore, but i might have to buy one, what do fetch ?)
kPa Times 0.145 = psi
100 X .145 = 14.5
CLG
Re: 22RE Engine Compression Rates Thu, 02 December 2004 01:02 Go to previous message
Start saving for a new engine or buy my good unit, either way your engine is on it's last legs.
Previous Topic:Legality of Side-exhaust mounting?
Next Topic:1G Head bolt Torque tension figures??
Current Time: Mon Oct 26 11:39:18 UTC 2026
Total time taken to generate the page: 0.0050048828125 seconds
