Toymods » Tech & Conversions » Ta22 Suspension issue
Kermit the TA-22
Ta22 Suspension issue Sun, 28 November 2004 21:42 Go to next message
Hey guys,
My TA22 has being lowered but as the tyres r lightly wider then the gaurds they keep rubbing on the panel every time the car squats.
Wot i need to know is
A) does anybody no any quick or cheap ways to fix this problem or
B)Does anyone have a set of original TA22 springs
Also just wondering, are there any other cars with similar springs?
Thanks guys
Joel
Re: Ta22 Suspension issue Sun, 28 November 2004 22:06 Go to previous messageGo to next message
Wheels rubbing, easiest/most sensible way to fix is purchase a set of wheels with the correct offset.
Cheapest way... a hammer and some creative body work? Razz
greenta22
Dandenong Ranges, VIC
Re: Ta22 Suspension issue Sun, 28 November 2004 23:08 Go to previous messageGo to next message
just get the guards rolled, most panel shops should be able to do this for you and its not a huge expensive job.
what size tyres/wheels are you running? ive got plenty of room on the back of mine with 205/60/14's, but my 195/60/14's rub on the front.
unless they're huge,(225+) your offset is probably wrong.
i do have a set of original springs, PM me if you're interested...
styler
Re: Ta22 Suspension issue Mon, 29 November 2004 13:37 Go to previous messageGo to next message
if they are only rubbing on the flat part of the lip most people get their guards rolled ( around $50 an arch )
a different/closer offset will solve ur problem if
the wheels you hav are a different offset to factory but yeah... new wheels pricey $$$
also there are wheel machining shops that could also machine
the flange down if it is suitable to do so - only a few
mm tho..
Kermit the TA-22
Re: Ta22 Suspension issue Tue, 30 November 2004 00:00 Go to previous messageGo to next message
Yeh guys, i'd love to Hammer or fold it out of the way but my problem is i got Two Pack paint and it won't handle that sorts stretching,i am gunna buy i another set of springs, i guy up here in brissie has a set, i'll just cut a little less off em this time ( I didn't do it last time) and see if that helps
and yeah Green TA22,
I havent mesaured but they are roughly 300 wide i think definately more then 200
Thanks for the help guys
JoeL
styler
Re: Ta22 Suspension issue Tue, 30 November 2004 00:25 Go to previous message
300 Shocked fark!
rubbing on the guards is like 225, a foot past the guards
more like 300 Very Happy
when they roll ur guards, the paint is heated up so it
streaches and the rolling machine rolls them nice and
even... sometimes it will crack older paint and need touch
ups but generally not
cut springs.... shady Cool
well good luck whatever way you go... love the paintjob!
Previous Topic:what plugs NOT to use in an 18RG
Next Topic:1UZ-GTE vs 2JZ-GTE vs 3S-GTE for RA23
Current Time: Wed Oct 14 12:06:57 UTC 2026
Total time taken to generate the page: 0.2123429775238 seconds
