Classifieds » Cars For Sale & Wanted » ae82 100kw adelaide Update #3 Look inside
Hunty
ae82 100kw adelaide Update #3 Look inside Mon, 29 November 2004 03:18 Go to next message
Update $4k
** = new
White ae82 pic in avatar
100kw 4age done approx 40,000k's
car has done 178,000 k's
its a 1986 CS-X model, its got the ae82 twin cam taco in the dash
got a recaro front drivers seat on custom made rails. You get the original drivers seat as well
**Top gun ignition leads, you get 3 new spare ones as well (7 in total) one of the new ones broke and top gun gave me a brand new set as a replacement but they took back the broken one, hence the 3 spares.
autotechnica steering wheel
2" exhaust and stainless cannon muffler, incl 2 resonators
lightened flywheel
front ae82 sway bar fitted with noalthane bushes
ae82 twin cam strut brace
brand new left hand drive shaft was put in when engine went in approx 6-8 months ago. driver side one is o.k for now but i have a spare recond'd one ready to go in.
lowered 2" at rear and aprox 1.5" at front although this was done approx 12 months ago and so there is some sag, its probably just on the legal limit. springs are heavy duty items made by industrial springs on port road.
pod filter
central locking via alarm for keyless entry
alarm has two ultra sonic sensors for detecting movement inside the car.
tinted rear windows and rear windscreen, front windows were tinted but i got defected 12 months ago and had to pull it off, never got round to putting tint back
painted interior plastics white to match car colour
has got ae92 GTZ levin front brakes, these are bigger 258mm dia rotors, with ferodo zeros pads in them at the mo, have also got some japanese competition pads with about 85% of pad left, these work well after about 3 stops from over 100km/h Smile
have got rear disc brake setup from ae82 twin cam, not fitted as i havent had a spare weekend to do it, also have master cylinder from ae92 SX, this is to go in when the rear discs go in to fix up the brake bias.
has got 14"x6" mags, they are linea sport things, italian made apparantly, they are pretty light weight. will also sell car with ae82 factory alloys 5x incl one with tyre (is the spare)
**3" stainless steel intake pipe/sillicon hose connector to throttle body with custom aluminium cool air box with hose pick up from under front bar.
http://forums.toymods.org.au/index.php?t=getfile&id=8635
http://forums.toymods.org.au/index.php?t=getfile&id=8636
has rego until april 05
Tyres are pirelli P 6000, rear two are needing replacement soon, front two are probaly ok for 5-6 months, depending on your driving style.
pretty tidy little car, goes well takes out most v6 commodores Smile
*** Compression test done today 195psi in all 4 cylinders. compression test done with throttle closed coz im a clown, so it would be a better result with it open, ill do it again when i get a chance.
edit: always serviced at 5k intervals, have had timing belt replaced only 8,000k's ago along with a new water pump which was fitted at the same time. Clutch is also 8-9,000k's old and has not been abused so shuld have 95% or more wear left in it, its a standard duty exedy item.
also located here at my105.com
http://my105.com/29266
Attachment: intake1.jpg
(Size: 37.29KB, Downloaded 1410 time(s))
Attachment: intake2.jpg
(Size: 33.61KB, Downloaded 1387 time(s))
[Updated on: Mon, 17 January 2005 08:27]
Adam_Rolla
Sydney, NSW
Re: ae82 100kw adelaide Mon, 29 November 2004 04:26 Go to previous messageGo to next message
did u do the engine change urself?
or previous owner?
Hunty
Re: ae82 100kw adelaide Mon, 29 November 2004 04:31 Go to previous messageGo to next message
I did it myself with the help of a mate who is an apprentice mechanic
doityourself
Hackham South Australia
Re: ae82 100kw adelaide Tue, 30 November 2004 09:05 Go to previous messageGo to next message
In 5 mins u will have a PM
Hunty
Re: ae82 100kw adelaide Sun, 05 December 2004 10:01 Go to previous messageGo to next message
update pics
http://forums.toymods.org.au/index.php?t=getfile&id=8352
Attachment: car full back-small.jpg
(Size: 35.08KB, Downloaded 407 time(s))
Attachment: engine-small.jpg
(Size: 40.63KB, Downloaded 386 time(s))
Attachment: car full front-small.jpg
(Size: 38.27KB, Downloaded 1715 time(s))
[Updated on: Sun, 19 December 2004 08:57]
Hunty
Re: ae82 100kw adelaide Sun, 05 December 2004 10:06 Go to previous messageGo to next message
more pics
http://forums.toymods.org.au/index.php?t=getfile&id=8353
Attachment: interior1-small.jpg
(Size: 32.23KB, Downloaded 1681 time(s))
Attachment: recaro-small.jpg
(Size: 41.74KB, Downloaded 377 time(s))
Attachment: interior2-small.jpg
(Size: 30.69KB, Downloaded 372 time(s))
[Updated on: Sun, 19 December 2004 08:58]
[S.T.A.R.S]
ADELAIDE - Lenswood
Re: ae82 100kw adelaide Wed, 08 December 2004 08:52 Go to previous messageGo to next message
man asiff ure selling the twinky Nooooooooooooooooooooooo!
frank_grimes
Re: ae82 100kw adelaide Wed, 08 December 2004 22:30 Go to previous messageGo to next message
free bump...
does it have air con?
Hunty
Re: ae82 100kw adelaide Fri, 10 December 2004 02:18 Go to previous messageGo to next message
S.T.A.R.S lol i know i know but i need a more powerful, stock looking car Sad preferably one that i can hang the arse end out on Razz
Frank -> A/C yes and no, no its not connected, but yes i have all the bits you need to have it put in. the 4AC motor that was in the car originally had aircon, so all the bits are there including the electrics which i beleive have been hooked up the ECU allowing you to just plug in the compressor and it should be hooked up. Alex at InjectMaz did the wiring on the car. If its not wired up then it is only a small job to plug the right wire into the ecu, i also have a big bag of wiring loom, lots of 4age bits and 4ac bits as well.
Note:- Stainless steel air intake with heat sheild going in on the weekend, come on guys you know you want to buy it Wink
Hunty
Re: ae82 100kw adelaide update n price drop Thu, 16 December 2004 05:51 Go to previous messageGo to next message
bump
deegs
Re: ae82 100kw adelaide update n price drop Thu, 16 December 2004 12:14 Go to previous messageGo to next message
can you say yummmmmmm haha thats so so nice, im looking for one like that up in the brisbane area
rex47
Re: ae82 100kw adelaide update n price drop Sun, 19 December 2004 01:32 Go to previous messageGo to next message
Hay i was looking at this post for a long time is the car still selling? if so Very Happy wish to buy it
Hunty
Re: ae82 100kw adelaide update n price drop Sun, 19 December 2004 03:53 Go to previous messageGo to next message
yeh still for sale, have had a few ppl interested tho, havent put it in the trader yet tho just a few forums n my105.com
i think transport interstate is about 500 beans
Hunty
Re: ae82 100kw adelaide Update #3 Look inside Thu, 23 December 2004 10:03 Go to previous messageGo to next message
still 4 sale
[Updated on: Tue, 04 January 2005 01:55]
Hunty
Re: ae82 100kw adelaide Update #3 Look inside Tue, 04 January 2005 01:56 Go to previous messageGo to next message
bump
Hunty
Re: ae82 100kw adelaide Update #3 Look inside Mon, 17 January 2005 08:29 Go to previous messageGo to next message
bumpidy bump bump
deegs
Re: ae82 100kw adelaide Update #3 Look inside Mon, 17 January 2005 10:38 Go to previous messageGo to next message
cant believe u havent sold this yet wats wrong with the ppl in adelaide!!!!!
Hunty
Re: ae82 100kw adelaide Update #3 Look inside Tue, 18 January 2005 05:16 Go to previous messageGo to next message
wish i knew deegs, i didnt think it would be so hard to sell, damn all these cheap imports Razz
deegs
Re: ae82 100kw adelaide Update #3 Look inside Tue, 18 January 2005 06:58 Go to previous messageGo to next message
if you were in brisbane, i would be there tomorrow looking at it!!!! if your ever driving up this way let us know Very Happy haha good luck with sale!
Hunty
Re: ae82 100kw adelaide Update #3 Look inside Tue, 18 January 2005 08:50 Go to previous messageGo to next message
excuse for bump
this engine actually came from brisbane lol
chrisma70
no where
Re: ae82 100kw adelaide Update #3 Look inside Tue, 18 January 2005 09:28 Go to previous messageGo to next message
what happens if i buy this and it get defected ? do i have anychance of gettin it on the road ?
again
chrisma70
no where
Re: ae82 100kw adelaide Update #3 Look inside Tue, 18 January 2005 09:43 Go to previous messageGo to next message
are u willing to take around the 3000 mark cause thats all i have let me know thanx man i live down south
Hunty
Re: ae82 100kw adelaide Update #3 Look inside Tue, 18 January 2005 23:51 Go to previous messageGo to next message
if 3 is the best offer i can get then i'll keep it as a backup/track car.
i got defected once in it when i was still on P's but i was being a dickhead, so it was to be expected.
i dunno how hard it would be to get off defect i guess you'd just have to put everything back to stock, but thats the chance you take with any modified car isnt it??
basically dont do anything to attract cop attention and they wont bother you, cops are like bees
deegs
Re: ae82 100kw adelaide Update #3 Look inside Wed, 19 January 2005 00:25 Go to previous messageGo to next message
what did you get defected for? bump
Adam_Rolla
Sydney, NSW
Re: ae82 100kw adelaide Update #3 Look inside Wed, 19 January 2005 02:11 Go to previous messageGo to next message
yeh mate what was the defect?? Confused
[Updated on: Wed, 19 January 2005 02:11]
Hunty
Re: ae82 100kw adelaide Update #3 Look inside Wed, 19 January 2005 04:32 Go to previous messageGo to next message
ummm well i kinda slowed down to about 25k/hr when going past a cop laser gunning people in a 60 zone and some how my hand flew out the window and gave the cop the finger. The cop was not too happy about this and proceeded to follow me pull me over and defect me for
1) windscreen wipers were painted white, aparantly they have to be painted MATT BLACK - bollocks if you ask me
2) exhaust sounds too loud, even tho it was never measure not did i even rev it for him, he just took a look at it and said thats gonna be too loud sunshine.
3) Steering wheel was not "standard"
4) metallic foot pedals were not "standard"
and finally it was lowered, no matter how much i told him that it was lowered 25mm which is the legal amount, nope he just looked, again no measurements, and said nope its lower than that.
so anyway i had to go to regency park to get the car cleared, this involved a total car inspection everything was checked and made sure it was roadworthy before they would clear it.
anyways that was about 2 years ago, and i havent had any problems with cops since, that could be coz my attitude changed slightly towards them and also the P plates came down. Hence no big red target n e more.
deegs
Re: ae82 100kw adelaide Update #3 Look inside Wed, 19 January 2005 05:46 Go to previous messageGo to next message
Hunty wrote on Wed, 19 January 2005 15:32
haha bet you learnt after that! anyway good luck with the sale, once again pity your not in brisbane! neat looking car hope you get what you want!
Hunty
Re: ae82 100kw adelaide Update #3 Look inside Thu, 27 January 2005 11:50 Go to previous messageGo to next message
bump, come on buy it someone......pleassseeee
carsanactra
melbourne
Re: ae82 100kw adelaide Update #3 Look inside Fri, 28 January 2005 02:15 Go to previous messageGo to next message
im in melburne and im very interested in it.
anychance of getting it down here for sum weird and wonderful reason?
also, does it have a rwc?
blindinglight
Re: ae82 100kw adelaide Update #3 Look inside Sun, 30 January 2005 07:10 Go to previous messageGo to next message
Hey
Very interested in this car. Is it registered with current engine? (engine numbers matching on rego sticker) When you went through regency was that after the conversion?
Hunty
Re: ae82 100kw adelaide Update #3 Look inside Sun, 30 January 2005 22:46 Go to previous messageGo to next message
nah got defected well before the conversion, i havent been able to find the engine number and so i havent filled out the change of engine form at transportSA but thats all ya have to do, regency dont have to see it. Rego is the same they still see it as a 4cyl 1.6litre N/A engine.
Let me know if you wanna come round and have a look. Mob 0423 096 869
INSANE82
Adelaide, SA
January 2005
Re: ae82 100kw adelaide Update #3 Look inside Mon, 31 January 2005 04:48 Go to previous messageGo to next message
where in adelaide are u?
Hunty
Re: ae82 100kw adelaide Update #3 Look inside Mon, 07 February 2005 07:35 Go to previous messageGo to next message
bump
Danish
Re: ae82 100kw adelaide Update #3 Look inside Mon, 07 February 2005 08:31 Go to previous messageGo to next message
Are you sure regency don't have to see it if you change the engine/number?
INSANE82
Adelaide, SA
January 2005
Re: ae82 100kw adelaide Update #3 Look inside Tue, 08 February 2005 01:45 Go to previous messageGo to next message
haha dont you hate those pedals? i have the same ones and i couldnt get the accelerator one on either!
Hunty
Re: ae82 100kw adelaide Update #3 Look inside Tue, 08 February 2005 05:54 Go to previous messageGo to next message
Danish wrote on Mon, 07 February 2005 19:01
Yep, because engine size ie 1.6litre has not changed. nor has the amount of cylinders ie 4.
A change of engine number form is all that is needed, can get from TransportSA.
edit: yeh those pedals are a bitch but ya get that when you only pay $16 for em lol
[Updated on: Tue, 08 February 2005 05:55]
Hunty
Re: ae82 100kw adelaide Update #3 Look inside Thu, 17 February 2005 02:03 Go to previous messageGo to next message
bump still for sale
$4k
blackRA28
adelaide
Re: ae82 100kw adelaide Update #3 Look inside Thu, 17 February 2005 06:19 Go to previous messageGo to next message
Just to back up regency dont need to inspect the car if you only changing engine numbers.
ie 4A-c -> 4A-g
2/3t - 2/3t-g
18R-c -> 18R-g
i did this when swapping from 18Rc to 18Rgeu and no worries. I even told them the motor was EFI now and ran on unleaded. took about 30seconds at the rego office. Cool
looks tidy mate, good luck with the sale
Hunty
Re: ae82 100kw adelaide Update #3 Look inside Mon, 21 February 2005 23:06 Go to previous messageGo to next message
ok guys last chance as it might be sold, i'm considering taking an offer i got that is way under what i wanted but seeing as there has been bugger all interest i may have to take it Sad
so make me an offer over 3500 and its yours
nick2b
Re: ae82 100kw adelaide Update #3 Look inside Tue, 22 February 2005 07:52 Go to previous messageGo to next message
pmd
Enrage
Darwin, NT
Re: ae82 100kw adelaide Update #3 Look inside Wed, 23 February 2005 02:10 Go to previous messageGo to next message
any chance you could hook me up with one of those sick 3" stainless pipes?
Hunty
Re: ae82 100kw adelaide Update #3 Look inside Wed, 23 February 2005 23:54 Go to previous messageGo to next message
tell ya what, you can have mine for $3500, and i'll throw in a free 100kw corolla Smile
Enrage
Darwin, NT
Re: ae82 100kw adelaide Update #3 Look inside Thu, 24 February 2005 04:38 Go to previous messageGo to next message
na seriously, whered u get it? custom made?
Hunty
Re: ae82 100kw adelaide Update #3 Look inside Thu, 24 February 2005 04:40 Go to previous messageGo to next message
pm'd
PooJou
Melbourne, Australia
Re: ae82 100kw adelaide Update #3 Look inside Mon, 11 April 2005 11:56 Go to previous message
Want to sell me just the wheel Smile (it's worth a shot)
Previous Topic:wanted gt starlet
Next Topic:mazda 929 turbo $2000 urgent has rego
Current Time: Sun Oct 18 05:21:13 UTC 2026
Total time taken to generate the page: 0.019520044326782 seconds
