Toymods » Tech & Conversions » Cressida 5M-E won't go into overdrive when warm?
superrb
icon9.gif  Cressida 5M-E won't go into overdrive when warm? Mon, 29 November 2004 07:02 Go to next message
My grandparents have an 84 Cressida which is having overdrive issues.
When starting the car from cold the box seems to change 'OK' (albeit won't change into overdrive till about 3,200rpm at 80 clicks). Drive it around for a few minutes and stop (eg at traffic lights) and after that it refuses to go into overdrive.
Fluid levels have been checked (when warm) and are OK. Any suggestions would be appreciated.
Cheers.
Re: Cressida 5M-E won't go into overdrive when warm? Mon, 29 November 2004 07:45 Go to previous messageGo to next message
Fluid levels were checked when car was running?
Is the kickdown cable too slack?
The tranny you have doesn't have any/much sensor input, so it sounds like the tranny might just be fcuked/on its way out.
sideshow
Re: Cressida 5M-E won't go into overdrive when warm? Mon, 29 November 2004 09:36 Go to previous messageGo to next message
theres a temp sender that when it gets over about 60 degrees water temp it allows the overdrive to work
either faulty sensor
or faulty wiring
indian
south east - melbourne
Re: Cressida 5M-E won't go into overdrive when warm? Mon, 29 November 2004 21:41 Go to previous messageGo to next message
check if the thermostat is stuck open happened to mine didnt go into overdrive for like even after 30-40 min of driving changed thermo and its running sweet
wilbo666
Re: Cressida 5M-E won't go into overdrive when warm? Mon, 29 November 2004 23:18 Go to previous messageGo to next message
sideshow wrote on Mon, 29 November 2004 20:36
or faulty wiring
in an 84 Rolling Eyes pretty sure that ain't the case....mine would jump into overdrive straight away all the time...(i might be wrong tho... Smile)
superrb
Re: Cressida 5M-E won't go into overdrive when warm? Tue, 30 November 2004 01:40 Go to previous message
The auto DOES changed into overdrive - but it seems only when cold.
Apparently if you start the car from cold and drive up the road, it WILL go into overdrive.
Changes 1st to 2nd at approx 2,000 rpm
2nd to 3rd at approx 2,800 rpm
3rd to overdrive at approx 3,200 rpm
The car will downchange OK if you accelarate hard, and then changes bac into overdrive OK. You can drive for 10+ kays and it's still OK.
However..... bring the car to a standstill - then try to take off again and it REFUSES to change up into overdrive.
The fluid levels were checked warm and when the car was running in 'PARK'. He has already changed the box once and this box does the exact same thing.
Freak'n weird!
Previous Topic:Error 21 on GZE
Next Topic:what plugs NOT to use in an 18RG
Current Time: Sun Oct 18 05:22:43 UTC 2026
Total time taken to generate the page: 0.0044291019439697 seconds
