Toymods » Tech & Conversions » Celica - CD PLAYER??
RA63 lad
icon5.gif  Celica - CD PLAYER?? Mon, 29 November 2004 10:01 Go to next message
Hey all... can anyone shed some light on this subject.
I have just installed a new cd player in my st184 celica.
Everythink works fine except for... the electronic ariel
doesn't work. Does anyone know how to rig up the wiring
so that the ariel will function correctly.... Somebody has to
know, please help!!! Confused
Dust
Re: Celica - CD PLAYER?? Mon, 29 November 2004 10:03 Go to previous messageGo to next message
your cd player that you just put in should have a wire labelled ant. find which wire your old stero used to make the aerial go up and connect this wire to it.
river
Land of Oz
Re: Celica - CD PLAYER?? Mon, 29 November 2004 10:48 Go to previous messageGo to next message
What he said.
If that doesn't work then you've got an aerial with a switched earth and you'll need to throw in a couple of relays to allow the antenna to go up and down - assuming it's a proper power aeriel and not the type that simply "pops up" when you turn the radio on (and have to manually push it down yourself).
seeyuzz
river
matt86sx
Gold Coast, QLD
Re: Celica - CD PLAYER?? Mon, 29 November 2004 23:14 Go to previous messageGo to next message
OK if your wiring is anything like my ST162 then this should work for you.
In your car's wiring behind the head unit area you should find a black wire with a red stripe, and a pink wire with a blue stripe. The black one connects to the blue "antenna" wire on the HU, and the pink one needs to be connected to the blue/white "remote" wire (the one that is used for turning amps on and off, etc).
When I first installed my HU I connected the black one to the HU antenna wire only, (not knowing about the pink one) and the antenna would raise when the HU was turned on, but wouldn't retract again until you switched the car off and turned the key on again. When I found out about the pink wire from a Celica forum, I hooked it up and everything worked perfectly.
Let me know how that goes, and if you have any other questions.
Matt
RA63 lad
Re: Celica - CD PLAYER?? Wed, 01 December 2004 07:41 Go to previous message
Thanks a heap "Dust", "river" & " matt86sx".
I will try and do what you have all suggested, on the weekend.
I will let you know how I go - or If I need more help Very Happy
Previous Topic:Ouch my head. I dropped it.
Next Topic:Soarer Rear Suspension
Current Time: Sat Nov 21 06:46:09 UTC 2026
Total time taken to generate the page: 0.0051350593566895 seconds
