Toymods » Tech & Conversions » FATT blitz timer
93soarerTT
FATT blitz timer Mon, 29 November 2004 22:36 Go to next message
i have a blitz fully auto turbo timer right, came with the car when i got it, every time i turn in on the screen goes red beeps and a "batt" symbol comes up, any ideas whats wrong here, and how involved is it to hook it up with my alarm?
cheers, going in a 93 soarer
Toobs
Re: FATT blitz timer Mon, 29 November 2004 23:11 Go to previous message
93soarerTT wrote on Tue, 30 November 2004 09:36
If it says "Batt" then your battery voltage is above or below whatever level you set it to... if you set it to say 13V high voltage warning then it would probably beep at you everytime you start the car.
Turn on the ignition and press the power button to cycle through the modes / menu and press the second and minute buttons to change the settings.
Re: Alarms and turbo timers... it is quite involved... you need to either use a relay or big chunky diode to stop the alarm from seeing 12V at the ignition when the key is set to off but the turbo timer is keeping the car running.
Previous Topic:1UZ-GTE vs 2JZ-GTE vs 3S-GTE for RA23
Next Topic:brass button clutch
Current Time: Sat Oct 17 13:33:46 UTC 2026
Total time taken to generate the page: 0.0047891139984131 seconds
