Toymods » General Car Talk » cressida mags
TassieCressida
cressida mags Tue, 30 November 2004 03:15 Go to next message
I have a 1989 toyota cressida and would like to know what size mags go on my car also do other mags from other model cars fit a if so which ones?
SIMDOG
Bayside Melbourne.
Re: cressida mags Tue, 30 November 2004 14:39 Go to previous messageGo to next message
Go 17"... They look sweet. Wink
Mitsubishi Magna wheels are a good bet... 114.3mm PCD and the correct offset (I think it is +45)... The Cressida uses a FWD offset. For example, the stud pattern of a Ford may be the same but the offset will be wrong.
The hub of the Cressida is 60.1mm diameter... The wheels I bought from a magna have a 73mm hole. You will need to buy the appropriate locating ring (60.1mm internal diameter and a 73mm external diameter) so the wheel is held concentric to the hub.
[Updated on: Tue, 30 November 2004 14:40]
SIMDOG
Bayside Melbourne.
Re: cressida mags Tue, 30 November 2004 15:24 Go to previous message
hmmm... I just reread your question and realised that I answered it in a really screwed up way... The basic info you need is this:
PCD: 114.3mm x 5 stud.
Offset: +45 (you should double check this)
Hub diameter: 60.1mm
If you need to know the basics, click
Previous Topic:86 and 18rg at pick a part!!!
Next Topic:great site for toyota engine bits
Current Time: Mon Oct 12 07:43:21 UTC 2026
Total time taken to generate the page: 0.12020802497864 seconds
