Toymods » Tech & Conversions » Low & High beam?
M.W.P.
Rocky Mountains, Canada
Low & High beam? Sat, 12 October 2002 03:39 Go to next message
Hi all...
Is there any reason why in a dual filament headlight globe, that the low *and* high beam filaments cant be turned on together?
On nearly every car ive seen, when you flick from low beam to high beam, the low beam turns off and the high beam turns on.
Im just wondering if they do this to stop the globes from overheating from both filaments being turned on.
Thanks.
Corvid
Re: Low & High beam? Sat, 12 October 2002 04:04 Go to previous messageGo to next message
Yeh.. The globes will get extremely hot.. also it would be too much of a current strain on your electrical wiring.. Definate burn out... Dont do it man. Unless you wanna be cruising through town with flames bellowing out from your engine bay/interior etc..
Laughing
M.W.P.
Re: Low & High beam? Sat, 12 October 2002 04:09 Go to previous messageGo to next message
Well electrical isnt a problem as its currently being changed anyway.
The headlights are halogen replacements for ther original sealed beams.
Re: Low & High beam? Sat, 12 October 2002 08:33 Go to previous messageGo to next message
You'll get no gain by doing this so I wouldn't bother!
ZZT231
melbourne.vic.au
Re: Low & High beam? Sat, 12 October 2002 11:28 Go to previous messageGo to next message
Hey All...
If you want depth in driving with the highlights on why don't you invest yourself in Driving lights for brighter depth of field with the highlights on or Fog lights for depth of field for low lights?
I changed my Headlight bulbs and added Driving lights so if anyone highlights me... I highlight back and they get the picture and they drop the lights, though night turns into day...
That is my 2 cents Rolling Eyes
M.W.P.
Re: Low & High beam? Sun, 13 October 2002 08:20 Go to previous messageGo to next message
Well we want to do this becuase at the moment the high beam filament of the low/high globe is never being used. Its always just on low beam.
Re: Low & High beam? Sun, 13 October 2002 08:29 Go to previous messageGo to next message
So why are the high beam filaments not being used?
LordEd
Re: Low & High beam? Mon, 14 October 2002 06:21 Go to previous messageGo to next message
M.W.P. wrote on Sat, 12 October 2002 13:39
The car in question is actually mine. The car originally had 4 single filament sealed beam headlights.. I have since replaced all four with Hella units, the centre pair are sealed beam single filament high beam units, the outers are now dual filament with built in parker globes.
The parker is wired up on the outer pair, as is the dipped beam filament.
What MWP and I are looking for is some information regarding setting up something so that on switching to high beam, the outer's use the high beam filament. The switch on the column is not designed as such so another system needs to be devised.
Thanks for your help guys.
Re: Low & High beam? Mon, 14 October 2002 06:26 Go to previous messageGo to next message
Use the wire from the switch to trigger relays to turn on the high beams. Use thick wire directly from the battery and a heavy duty relay.
Blacki
Re: Low & High beam? Mon, 14 October 2002 06:41 Go to previous message
Something like this should do the trick.
http://www.autooptiks.com/relay.2.gif
wiring diagram courtesy of www.autooptiks.com
Previous Topic:diff size measurement
Next Topic:tyre pressure
Current Time: Mon Oct 26 09:21:58 UTC 2026
Total time taken to generate the page: 0.0060861110687256 seconds
