Toymods » Tech & Conversions » 1ggte question
Dust
1ggte question Tue, 30 November 2004 08:57 Go to next message
On the drivers side of the 1ggte, there is a pipe coming out of the block down near the sump and it splits into 2 and those pipes go to the turbos. Is this an oil return? and if I needed to modify this pipe do I just have to kep it so that gravity takes the oil to the end of the pipe?
Forgive my lack of understanding and mechanical terms, I need to modify it so I can fit my engine mounts on.
If anyone has done this before, a pic would be greatly appreciated.
Hope I was clear enough
Dust
Jake001
B risbane
Re: 1ggte question Tue, 30 November 2004 21:27 Go to previous message
Yes I believe this be the return. You possibly could make the return lines out of braided hose, just make sure that you use the same diameter or larger hose and make sure the hose is always running down & not up and over things (gravity feed).
Previous Topic:4age 86kw or 4age 100kw
Next Topic:Ra23 & 18rgeu question for new person that has just started out.
Current Time: Sat Oct 24 20:02:33 UTC 2026
Total time taken to generate the page: 0.0049369335174561 seconds
