Toymods » Tech & Conversions » Ignition Coil Question
pituala
Ft.Lauderdale, FL, USA
Ignition Coil Question Tue, 30 November 2004 22:18 Go to next message
Does anyone know why the coil on the 1G-GTE has 3 wires? I've always seen 2 wire coils, and I just checked my buddy's 7M non turbo motor, and his is 2 wire also. I don't know if the 3 wire coil is from the 5M or the 1G, but I want to upgrade my coil to a high output such as an MSD, but the whole 3 wire thing is making it hard to determine which coil to get. Any help would be appreciated.
Thanks- Armin
Re: Ignition Coil Question Tue, 30 November 2004 22:24 Go to previous messageGo to next message
A wild guess, but could it be tacho?
pituala
Re: Ignition Coil Question Tue, 30 November 2004 22:46 Go to previous messageGo to next message
TurboRA28 wrote on Tue, 30 November 2004 18:24
That's what I'm thinking too, but I haven't been able to confirm it. I wish I could find a schematic. BTW, for whatever reason, with the 1G motor, my tach and speedo do not work. If it is a tach wire, and my tach dosn't work anyways, then a MSD TFI coil for a 5.0 mustang would work, I believe.
Re: Ignition Coil Question Tue, 30 November 2004 23:03 Go to previous messageGo to next message
What colour is the wire?
Re: Ignition Coil Question Tue, 30 November 2004 23:20 Go to previous messageGo to next message
pituala wrote on Wed, 01 December 2004 09:18
Thanks- Armin
how about.. internal resistor.
when starting the coil is powered by the non-resistor terminal, and when running is powered by the resistor terminal.
measure the resistance with a multimeter between the three terminals and tell us what you find.
Grant
Newcastle, NSW, Australia
Re: Ignition Coil Question Wed, 01 December 2004 05:29 Go to previous messageGo to next message
The 1GGTE coil is unique as it has a split primary winding. Looking at the circuit diagram, the igniter has the ability to power either side of the primary coil independantly. I assume it does this to fire another spark shortly after the first, probably in an attempt to ignite unburnt vapour and improve emissions (a similar idea to the 3TGTE's twin plug set-up).
As part of this process the igniter send two signals back to the ecu to tell it the coil has fired correctly. Unfortunately you are going to run into problems fitting an aftermarket coil or ignition unit as the factory ecu still needs to get these signals or injection will stop.
[Updated on: Wed, 01 December 2004 20:35]
pituala
Re: Ignition Coil Question Wed, 01 December 2004 15:00 Go to previous messageGo to next message
Grant wrote on Wed, 01 December 2004 01:29
The 1GGTE coil is unique as it has a split primary winding. Looking at the circuit diagram, the igniter has the ability to power either side of the primary coil independantly. I assume it does this to fire another spark shortly after the first, probably in an attempt to ignite unburnt vapour and improve emissions.
Hmm, just what I needed to hear, but not what I wanted to hear. So both a coil or something like an MSD 6AL or a MSD 6BTM will not work? I'm wondering if both of the 2 coil fire wires from the oem coil can be wired into the 1 side of the aftermarket coil? I'm not sure about the logistics of this, but I wonder if that would at least get signal to the ecu.
Grant
Re: Ignition Coil Question Wed, 01 December 2004 20:40 Go to previous messageGo to next message
Difficult to know what the igniter would do in that instance. Maybe talk to MSD and explain the problem; they might have a solution.
pituala
Re: Ignition Coil Question Wed, 01 December 2004 20:46 Go to previous message
Grant wrote on Wed, 01 December 2004 16:40
Thanks, you've been a great help.
Previous Topic:Rust on Disc Breaks
Next Topic:3tgte plenum on a 3tc question
Current Time: Fri Oct 23 02:57:53 UTC 2026
Total time taken to generate the page: 0.0054390430450439 seconds
