Toymods » Tech & Conversions » Rust on Disc Breaks
ST162GT-R
QLD, Gold Coast
Rust on Disc Breaks Wed, 01 December 2004 05:38 Go to next message
If theres rust on my disc breaks will this be a problem for me??(the car hasn't been driven in awhile 2 months) or will they just kind of brush away after awhile?
Toobs
Re: Rust on Disc Breaks Wed, 01 December 2004 05:58 Go to previous messageGo to next message
Surface rust will just wipe off once you use the brakes a little... it won't cause much harm other than a slight increase in pad usage for the first couple of kms.
Kyosho
Wollongong
Re: Rust on Disc Breaks Wed, 01 December 2004 07:52 Go to previous messageGo to next message
What ^^^ said...
terrykoun
Re: Rust on Disc Breaks Wed, 01 December 2004 10:48 Go to previous messageGo to next message
yes i second that, i had the same problem but ignored it and now it has no surface rust
jesseT18
Castle Hill, Sydney
Re: Rust on Disc Breaks Wed, 01 December 2004 10:55 Go to previous messageGo to next message
my rotors were covered in rust when i put the new beakes on my car, didnt like the idea of clogging up the pads and spreading around all that rust, i chose to rub it off with steel wool.
which took next to no effort at all, i suggest you do the same
[Updated on: Wed, 01 December 2004 10:56]
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Rust on Disc Breaks Wed, 01 December 2004 11:32 Go to previous messageGo to next message
Disc brakes are bare, exposed metal pieces that will rust at the drop of a hat. Water + metal + (given period of time) = ferrous oxide (rust), and the most obvious place to find rust is the centre hub or the outer circumference of the disc face (the vented surface). Prevention is the best cure here. Wink
takai
Re: Rust on Disc Breaks Wed, 01 December 2004 11:40 Go to previous messageGo to next message
Always remember kiddies that brakes get hot, and that normal paint will blister and burn. Use high temp enamels.
ST162GT-R
QLD, Gold Coast
Re: Rust on Disc Breaks Wed, 01 December 2004 21:25 Go to previous message
Ok thanks heaps for that guys, much appreciated.
Previous Topic:Ta22 Ra40 + Upgrade
Next Topic:Ignition Coil Question
Current Time: Sat Oct 24 02:26:27 UTC 2026
Total time taken to generate the page: 0.0055341720581055 seconds
