Toymods » Tech & Conversions » Timing belt change, 1ggte
doobs
Geelong.Vic.AU
Timing belt change, 1ggte Thu, 02 December 2004 09:49 Go to next message
Ey all,
Me and a mate willbe changing a timing belt on a 1ggte tomorrow in a soarer.
Im wondering if you have any infomation that we may need to do this? We dont have any documentation for the car or the engine so any tips or common problems would be handy.
cheers fellas
Re: Timing belt change, 1ggte Thu, 02 December 2004 10:00 Go to previous messageGo to next message
i can't help out here - but can you take some pics as you go?
at a guess, it's probably a similar excercise to 4AGE or 1J engines. differences will be in how the tensioner works and the right way of re-installing the tensioner.
having bore/after pics will help if you stuff it up and come back asking help? an i mean that in the nicest possible way.
good luck.
doobs
Geelong.Vic.AU
Re: Timing belt change, 1ggte Thu, 02 December 2004 10:59 Go to previous messageGo to next message
Yer ill try and get some picys, id say we will be right, just needed some info on the setting the timing.
Thanx for the reply any other info would be great
Re: Timing belt change, 1ggte Thu, 02 December 2004 11:01 Go to previous messageGo to next message
There are notches on both the cam gears and the plate behind them. These need to be lined up. Of course the engine has to be at TDC.
BLK1GGTE
South Eastern Subs
Re: Timing belt change, 1ggte Thu, 02 December 2004 15:38 Go to previous messageGo to next message
Like frank said... Your fly wheel has to be at 0 on the flywheel (Top Dead Centre)... and both your cam gears should line up...by that I mean there are little dots on the cam gears...if you look you will see them they are little dots with a letter on the cam gears...when your fly wheel is at 0 (TDC) your cam gear dots should align with the lines on the cam cover..(the metal behind your cam gears) You will see two straight lines behind your cam gears)Your cam gear dots should align with the two lines behind them when on Top Dead Centre...Thats all...When you check your timing make sure its on 10 degrees with the TE1 and E1 pin shorted with a wire in your diagnostic plug. Also make sure your rotor button is on number one cylinder.... when you do this...ezy to tell by the dizzy cap numbers...just my 2c worth.
BLK1GGTE
South Eastern Subs
Re: Timing belt change, 1ggte Thu, 02 December 2004 15:40 Go to previous messageGo to next message
If you need torque figure for the cam gears they are on this tread or just ask me.....
doobs
Geelong.Vic.AU
Re: Timing belt change, 1ggte Thu, 02 December 2004 22:35 Go to previous messageGo to next message
Thanx for the help fellas, now off to do the job
cressTT
Re: Timing belt change, 1ggte Fri, 03 December 2004 03:27 Go to previous messageGo to next message
the only problem i had while doing t-belt job on a 1G-GTE was the harmonic dampner pulley,it was stuck to do crankshaft, i had to use a puller. Just make sure you have a puller availabe.
Dust
Re: Timing belt change, 1ggte Fri, 03 December 2004 04:46 Go to previous messageGo to next message
And a big breaker bar or rattle gun for the crankpulley bolt Smile
Siktoy ra23
Plumpton/sydney
Re: Timing belt change, 1ggte Fri, 03 December 2004 07:29 Go to previous messageGo to next message
Dust wrote on Fri, 03 December 2004 15:46
Yeah it tok me hours to get mine off
doobs
Geelong.Vic.AU
Re: Timing belt change, 1ggte Fri, 03 December 2004 14:04 Go to previous message
Ey all,
Well its almost done, took us hours to get the pully off, the bolt wouldent move, but we got it, then the pully wouldent come off, but we got it off too Razz.
BIGGEST problem was getting the belt on, we couldent manage to get the cams lined up and the engine at TDC while putting the belt on, but we did it.
We called it a day there as we spent 5 hours doing that. Work on it on monday and finish it off. We have decided to do a full service too.
Thanx for the help fellas, since this was my first timing belt im DAMN scared of doing mine (FWD 3SGE) but thats next years prob.
P.s. Ignore gramma or spelling errors, we decided we needed a good drink after the job....
Previous Topic:Brake Upgrade for AE112
Next Topic:Are these common problems with 1998 2.2 Camry?
Current Time: Fri Oct 30 21:55:39 UTC 2026
Total time taken to generate the page: 0.0057699680328369 seconds
