Toymods » Tech & Conversions » 1jz cressida help
i2obert
1jz cressida help Thu, 02 December 2004 20:11 Go to next message
i got a 1jz from a jzx81 very cheap but it didt come with loom and ecu it just a engine with turbos and so on the engine is running fine and so on now im just wondering what do i need to drop it into my cressida m83 it a 1990 modle glx i know i will need engine mounts a loom and a ecu (can i run a aftermarket ecu like gready emanage or somthing ??) what other parts will i need from a jzx81 to be able to place this into my car ???
nudes
Sydney/Wollongong
Re: 1jz cressida help Thu, 02 December 2004 21:02 Go to previous messageGo to next message
hey mate there is a complete list of ALL ze parts needed for the mx83 1J conversions in the tech docs..
i was thinking of doing this conversion also but instead bought the KE70.. i'm a cheapskate Laughing
Re: 1jz cressida help Fri, 03 December 2004 00:26 Go to previous messageGo to next message
What mounts do you currently have? (on the mx83)
The cast alloy ones? or pressed steel?
If you have cast alloy ones, then it should bolt straight in
If you have pressed steel ones, then you will need a jzx81 crossmember, or contact bonnyville auto's for a set of mounts that by all rights should make it bolt in.
Chris Davey
sunny coast, qld
Re: 1jz cressida help Fri, 03 December 2004 02:15 Go to previous messageGo to next message
I am not sure if this is possible if you have no wiring at all. But if it is, I would go for an aftermarket ECU straight up. If you plan on upgrading stuff in the future which most people are you may as well do it now.
I know I should have Sad
sideshow
Re: 1jz cressida help Fri, 03 December 2004 07:41 Go to previous messageGo to next message
if you want to run the electronic automatic transmission u need to run std ecu
or buy a 4000 dollar motec
i2obert
Re: 1jz cressida help Sat, 04 December 2004 02:22 Go to previous messageGo to next message
i plan on running and manual box and modding the engine it was just this engine was cheap and im thinkin about it but it seems all i will need to bolt it up is engine mounts loom new cross member maybe and a ecu of some sort so buying this engine for 660 might be worth it if i can sorce the parts
thanks for you replys guys realy helpful
nudes where is the tech doc ?? i was looking for it but couldt find it
[Updated on: Sat, 04 December 2004 02:40]
sideshow
Re: 1jz cressida help Sat, 04 December 2004 02:53 Go to previous messageGo to next message
well you have to try find a loom to suit the engine
i dont htink it matters what ecu/loom you get
theres 2 style of plugs/loom
just get a matching set
might set you back a couple of hundred bucks
or you can go buy a microtech for about 1000 to 1300
i think if you want all sequential fire you need lt12
so there abit more
i2obert
Re: 1jz cressida help Sat, 04 December 2004 06:42 Go to previous messageGo to next message
yeah i think im going to spend the extra money getting a aftermarket computer better in the long run also how hard whould it be to find the engine mounts ??? and loom ? can i use a loom from a ma70 supra mz21 and so on or must it be a jzx81
Re: 1jz cressida help Sat, 04 December 2004 07:12 Go to previous messageGo to next message
just hoomk up the microtech - they come with custom looms for the 1jz. then there's just a few other wires you need to hook up, which you can d oyourself/get someone to do.
I removed *all* of my original 1jz loom apart from a few wires!
sideshow
Re: 1jz cressida help Sat, 04 December 2004 08:50 Go to previous messageGo to next message
depends what you want
if you go aftermarket u just need plugs for
injectors
crank sensor
cam sensor
coolant temp
ignitor
coils
i2obert
Re: 1jz cressida help Sat, 04 December 2004 23:55 Go to previous messageGo to next message
well with this info i guess it means hello 1jz for my car lol thanks for your help guys just 1 more question any one know where i can get some engine mounts now and a cross member if i need one just in case also
what tranny should i use a r154 from a 1jz supra or one from a soarer ?? as there both not the same i have herd any help with this
[Updated on: Sun, 05 December 2004 00:25]
nudes
Sydney/Wollongong
Re: 1jz cressida help Sun, 05 December 2004 07:50 Go to previous messageGo to next message
i think i may have been tripping on acid.. Sad
i cant find it now.. but could've swore it was in the tech docs.. maybe i just spotted the heading during a search.. it's around..
goodluck with the conversion mate Very Happy
Re: 1jz cressida help Sun, 05 December 2004 14:38 Go to previous messageGo to next message
CrUZsida wrote on Fri, 03 December 2004 08:26
manmx83
Re: 1jz cressida help Sun, 05 December 2004 15:39 Go to previous messageGo to next message
The R154 from a jza70 has the gear stick position good for mx83.The trans tunnel needs opening up a little at the front.Nothing extreme.Just make a cardboard template of the wide section of the box and bash the shit out of your car until it fits.Works a treat! [I am not joking].Pete.r154 1jz cressida.
ps.i have no knowledge of boxes from other cars relating to gearstick position.I just know jza70 box fits as I used it. Very Happy
i2obert
Re: 1jz cressida help Mon, 06 December 2004 21:30 Go to previous message
yeppiii bashing of the car lol thanks for your help at the moment im trying to find a decent set of rims so i can trow on a brake upgrade i will soon make a website detailing all the info i got from yous and things i came across
Previous Topic:tyre wear problems
Next Topic:turbo questions
Current Time: Fri Nov 20 13:35:22 UTC 2026
Total time taken to generate the page: 0.0099000930786133 seconds
