Toymods » Tech & Conversions » ke70 4kc 5 speed into a ke20 3k
wazzar
ke70 4kc 5 speed into a ke20 3k Thu, 02 December 2004 22:22 Go to next message
hey i can get my hands on a 5 speed out of a ke70 4kc will it bolt into my ke20 with a 3k will i need to chnge any thig eg, tail sharft?
bassy
Re: ke70 4kc 5 speed into a ke20 3k Fri, 03 December 2004 05:18 Go to previous messageGo to next message
nope
alex_ta22
Newcastle, Hunter Valley
Re: ke70 4kc 5 speed into a ke20 3k Fri, 03 December 2004 05:46 Go to previous messageGo to next message
shifter is in the wrong position
Re: ke70 4kc 5 speed into a ke20 3k Fri, 03 December 2004 09:23 Go to previous messageGo to next message
if you swap the extension housign with a KE55 5speed one, it will bolt in. you may want to check that the input and output splines are the same tho..
rlevo
Ballarat
Re: ke70 4kc 5 speed into a ke20 3k Sat, 04 December 2004 10:07 Go to previous messageGo to next message
Just put a KE70 5 speed in my car, a KE55. All I needed to do was put the extension housing on from a '55 box, and all is sweet, gearshift in same spot! Very easy to change extension housings. Both the 5 speed boxes I had were 19 spline, same as the 4 speed.
Rob
wazzar
Re: ke70 4kc 5 speed into a ke20 3k Sun, 05 December 2004 21:01 Go to previous messageGo to next message
thanks done that and it all fits next question is my speedo is out can i change the gear with the one from my 4 speed?
Re: ke70 4kc 5 speed into a ke20 3k Sun, 05 December 2004 23:15 Go to previous messageGo to next message
yes, but you may need to pull off the extension housing and change the drive gear Wink
how many teeth on your KE20 driven gear (the plastic one) if it is 20/21, the it will go stright into the KE70 box. if it is 19, then you need to change both the drive and driven gear.
rlevo
Ballarat
Re: ke70 4kc 5 speed into a ke20 3k Mon, 06 December 2004 10:47 Go to previous messageGo to next message
My speedo gear is 19 teeth, I think that should be the same as your 4 speed.Count the teeth and see how you go. Did the '20 have 12" or 13" wheels? That may make a difference too.
Re: ke70 4kc 5 speed into a ke20 3k Mon, 06 December 2004 14:23 Go to previous message
as i understand it,
KE10 had 5/19 teeth, early KE20 had 5/19 theeth. late had 6/20, and that continued up to later models,. with some having 6/21 teeth also (i think just the KE70's)
5tooth is different diameter to 6 tooth, but 20/21 can be swapped with no probs.
ymmv
Previous Topic:4age and 4agze high pressure power steering line.
Next Topic:ST185 floor pan
Current Time: Fri Nov 20 16:16:08 UTC 2026
Total time taken to generate the page: 0.007044792175293 seconds
