Toymods » Tech & Conversions » 1JZ Sounding like bubbles NOW THE FARKIN TURBO IS GONE
KOFFEE-BLACK
1JZ Sounding like bubbles NOW THE FARKIN TURBO IS GONE Fri, 03 December 2004 00:46 Go to next message
Hey guys, when I first got my car back, the engine ran very smooth, even though, it has not been tuned yet, idles nice and all. Now and then though, (Its actually almost always now) it sounds like there is air bubbles or something in the exhaust. You know that sound, where you have hi pressure hosed the engine bay, and water has gone inside the spark leads? Exact same sound, but I have never used water in the engine bay. What could it be?? I seem to have loss consider amount of power because of this also.
[Updated on: Sat, 04 December 2004 08:37]
indian
south east - melbourne
Re: 1JZ Sounding like bubbles Fri, 03 December 2004 01:21 Go to previous messageGo to next message
head gasket --- is the sound exactly like the wrx with modified exhaust then most likely thats what it is dont quote me on it though
check for oil and water mixing in the radiator/coolant reservouir if its been happenin for some time there will be rust brown water in the radiator/reservouir due to the head being corroded hope thats not the case chek it out asap
it could also be a stuffed up injector / injector connector
Skip
Re: 1JZ Sounding like bubbles Fri, 03 December 2004 01:48 Go to previous messageGo to next message
Perhaps someone put bubble bath in your sump instead of oil?
But seriously I have nothing useful to offer Sad
Chris Davey
sunny coast, qld
Re: 1JZ Sounding like bubbles Fri, 03 December 2004 02:14 Go to previous messageGo to next message
do you mean little popping noises every so often from the exhaust?
if so, that is what my old 1g used to do. Unfortunately, I never found out why, but it didn't seem to lose any power so...?
KOFFEE-BLACK
Re: 1JZ Sounding like bubbles Fri, 03 December 2004 02:40 Go to previous messageGo to next message
HEADGASKET??? Dont say that!! Please! Thats a big job right? But thing is, sometimes, it works perfectly! Yep, sounds like a WRX when you accelerate, but goes like a Lada. Hop it is the injector problem!
Silver_r33
Re: 1JZ Sounding like bubbles Fri, 03 December 2004 04:31 Go to previous messageGo to next message
Are you running rich? Could be fouled plugs....
The Count
Re: 1JZ Sounding like bubbles Fri, 03 December 2004 04:40 Go to previous messageGo to next message
its fouled plugs
when adam tuned my car had the same problem
have u cold tuned it yet ..
check ur plugs
Dust
Re: 1JZ Sounding like bubbles Fri, 03 December 2004 04:44 Go to previous messageGo to next message
could be a bad lead too, check your sparkplug leads, best way to do it is look in the engine bay while the car is running and it is dark, like night time Smile, if u see sparks then that is why, this is what it sounds like to me, as u said, sometimes it runs fine. Also u can check them for cracks etc.
indian
yeah if the plugs are fcuked they will do the same thing take them out and clean them with kerosene nicely put them back and if no difference then chek the oil as i said before if its milky colour / als chek colan for same milky residue on the reservouir cover /bottle if theres any take it to the mechanic straight away
is the car running rich as well can be a temp sensor fcuk up but i doubt it that wouldn make the car sound like the wrx
can be clogged injectors as well
do not drive the carin this state as it can do more damage
hope its ur injector or eveb better fouled spark plugs
BTW DID U RECENTLY CHANGE ENGINE OIL FOR THE CAR
if u put in too much of oil it will foul the spark plugs causing the car to sound exactly how u described it so chek the spark plugs first
KOFFEE-BLACK
Re: 1JZ Sounding like bubbles Fri, 03 December 2004 04:56 Go to previous messageGo to next message
Thanks guys, sounds like the plugs!
Yeah, we did put new oil in, i dont have that damn tool, to take the plugs out, All I have is a philips head screw driver and wire cutters lol!
indian
Re: 1JZ Sounding like bubbles Fri, 03 December 2004 06:06 Go to previous messageGo to next message
YAH looks like the sparkies are gone maybe even the cable is fcuked and u cant get a spark chem both of em , looks like its not the hg thank god
supra1jz
Launceston, Tasmania
Re: 1JZ Sounding like bubbles Fri, 03 December 2004 06:33 Go to previous messageGo to next message
I had the identical thing happen to me in my 1jz with Haltech! The cause is the tuning being to rich and then fouling plugs and they appear to be very sensitive to temperature. For example, my car was tuned by Matthew Spry formerly of Chiptorque, in summer in Qld bring it to Tas. and car "blows bubbles" in winter when it is cold-cause is too rich!!!! Don't ask me how their can be that much difference between summer and winter and Qld and Tas. because I don;t know. All I know is that it was a waste of money getting a tune that I can only use three months of the year in this climate. Hope this helps.
Rich
KOFFEE-BLACK
Re: 1JZ Sounding like bubbles Fri, 03 December 2004 06:38 Go to previous messageGo to next message
ooo, Thats a good point, as Im running E6X, and JEM have not tuned the car yet, just adjusted the idle, and set the rev limit to 5k, so I can use up my old fuel.
SilverGhost
Re: 1JZ Sounding like bubbles Fri, 03 December 2004 06:46 Go to previous messageGo to next message
hey dude, if you can drive, come round my place....ive got tools that should be able to get your plugs out etc....
we can also run a compression test, and pressure test your cooling system if you want...buzz me, should be free tonight around 9
Chris Davey
sunny coast, qld
Re: 1JZ Sounding like bubbles Sat, 04 December 2004 00:10 Go to previous messageGo to next message
what do you mean you don't have the tools? Razz Just buy one of those $15 sets from super cheap. It is nothing special just a 16mm (i think) long socket.
also, my earlier comment probably won't be right as I thought you were talking about a different noise.
Does it sound like that idling as well? if so, you can just pull the plugs off the coil packs until the noise doesn't change. Then you have worked out that it is that cylinder. Then you can check the plugs, coil packs for any weird looking shit like cracks etc. Then try removing the plug from coil pack and cranking the car over. Then pull the spark plug out and see if there is fuel all over it. If there is, then the injector should be fine. If there isn't then start looking at injectors.
Just think of it that to combust, it need fuel, spark and air. Has to be one of those things so it is a process to work it out which one.
good luck! Razz
Jag7799
Re: 1JZ Sounding like bubbles Sat, 04 December 2004 00:13 Go to previous messageGo to next message
I thought u did your whole conversion?
how do u not have tools?
Kyosho
Wollongong
Re: 1JZ Sounding like bubbles Sat, 04 December 2004 05:37 Go to previous messageGo to next message
Chris Davey wrote on Fri, 03 December 2004 13:14
Was what you were hearing mainly when you backed off, especially from higher revs, or using gears to hold you on a hill?
If it was, that was teh exhaust cackling...
It is cause by the exhaust scavenging out half burned mixtures... It happens in every single car, just some you can notice it in, others you can not...
My ute does it ocasionaly, our old chev does it on hills, and our Camaro just rumbles and cackles when backed off on hills...
Jag7799
Re: 1JZ Sounding like bubbles Sat, 04 December 2004 06:19 Go to previous messageGo to next message
Kyosho wrote on Sat, 04 December 2004 16:37
yah, mine does that
its just normal
KOFFEE-BLACK
Re: 1JZ Sounding like bubbles NOW THE FARKIN TURBO IS GONE Sat, 04 December 2004 08:41 Go to previous messageGo to next message
Jag, I did not do the conversion, I do IT, thats it hahah.
WELL! I fixed the problem, its one of the coils, when unplugging it, the engine note was the same, plugging it in and out a few times, brught it back to life! BUT (Always a fucking but) This morning, I started her up, 50 m down the street, I hear a jingling type noise, like a rattle, I though ohh no, then the car stalled, I think one of the turbines went through the exhaust! Unbelivable, Had the car for a wekk, never got to give it any hits whatsover, and now this happens! There is no boost now, whatsover! Fucking pissed man!
pr1nce
NSW, Sydney
Re: 1JZ Sounding like bubbles NOW THE FARKIN TURBO IS GONE Sat, 04 December 2004 09:26 Go to previous messageGo to next message
fuck man
DODGY
Skip
Re: 1JZ Sounding like bubbles NOW THE FARKIN TURBO IS GONE Sat, 04 December 2004 11:09 Go to previous messageGo to next message
If you have Haltech, sounds like big single turbo time to me Smile
ae86drift
sydney.au
Re: 1JZ Sounding like bubbles NOW THE FARKIN TURBO IS GONE Sat, 04 December 2004 12:01 Go to previous messageGo to next message
time for the steel impeller
Jag7799
Re: 1JZ Sounding like bubbles NOW THE FARKIN TURBO IS GONE Sat, 04 December 2004 13:33 Go to previous messageGo to next message
time for the mental break down (just to go with everyone elses "time for's")
Chris Davey
sunny coast, qld
Re: 1JZ Sounding like bubbles NOW THE FARKIN TURBO IS GONE Sun, 05 December 2004 01:11 Go to previous messageGo to next message
bloody hell man you have the same bad luck as me!
Personally, as the piping and everything is all done, I would go steel wheel turbos and while you are at it, some twin dumps if you don't have any.
Probably easier in your car than mine, but going single is going to be harder than just fitting steel wheels into stock turbos.
KOFFEE-BLACK
Re: 1JZ Sounding like bubbles NOW THE FARKIN TURBO IS GONE Sun, 05 December 2004 01:12 Go to previous messageGo to next message
I think im just going to buy a set of steel wheels, got one lined up already. What are the benefits? Run more/safer boost?
Chris Davey
sunny coast, qld
Re: 1JZ Sounding like bubbles NOW THE FARKIN TURBO IS GONE Sun, 05 December 2004 01:41 Go to previous messageGo to next message
yep, more boost safer. You can get them hiflowed as well if you wanted. There is a tiny bit more lag but it is shit all I reckon. My mates jzz30 hits boost around 2600rpm with steel wheel turbos.
supra1jz
Re: 1JZ Sounding like bubbles NOW THE FARKIN TURBO IS GONE Sun, 05 December 2004 02:12 Go to previous messageGo to next message
Just check your cat converter first as thought I had the same problem. My exhaust rattled and couldn't make more than 5 psi boost because the innards of the converter collapsed and was choking the engine so it couldn't make anymore boost. Everyone told me it was the turbos as well bbut when I pulled it all apart they were fine! Yours probably are gone but it would pay to check the cat anyway......might save you a lot of hassle. My cat was only a year old too!!!!
Rich
joorsh
Re: 1JZ Sounding like bubbles NOW THE FARKIN TURBO IS GONE Sun, 05 December 2004 03:19 Go to previous messageGo to next message
And you'll probably find your old turbine wheel in the cat too Smile
bubbles
Banned user
Liverpool NSW
Re: 1JZ Sounding like bubbles NOW THE FARKIN TURBO IS GONE Mon, 06 December 2004 03:36 Go to previous messageGo to next message
a friends vr4 had the same problem
he tuned it with haltech, the next day he replaced the spark plugs with another brand and the car sounded like a ej20.
If its not that check the exhaust sensor
Mr DOHC
Re: 1JZ Sounding like bubbles Mon, 06 December 2004 10:12 Go to previous messageGo to next message
Jag7799 wrote on Sat, 04 December 2004 16:19
yah, mine does that
its just normal
mine too Surprised , cept mine blows 2 ft long blue flames Evil or Very Mad
AE86slut
Baulko Hillo
Re: 1JZ Sounding like bubbles NOW THE FARKIN TURBO IS GONE Mon, 06 December 2004 10:32 Go to previous messageGo to next message
supra1jz wrote on Sun, 05 December 2004 13:12
Rich
Had exactly the same prob with my R32 - no boost, pulled the cat out and it had collapsed inside. I'm guessing you would have all new exhaust bits though?
And Shane if you're changing the turbine wheels, you'd be silly not to high-flow at the same time IMO.
KOFFEE-BLACK
Re: 1JZ Sounding like bubbles NOW THE FARKIN TURBO IS GONE Mon, 06 December 2004 11:54 Go to previous message
Im actually buying a set of steel wheeled turbos.
Its definatley the turbo, as the other is whining like a bitch, (trying to spin the other turbo the wrong way??)
Previous Topic:MA61 spec
Next Topic:any point of puttin a k&n on my carbie
Current Time: Fri Nov 20 17:33:10 UTC 2026
Total time taken to generate the page: 0.014799118041992 seconds
