Toymods » Tech & Conversions » Valve float: What does it feel like when driving? NOW FIXED!!!
TE72_Turbo
Valve float: What does it feel like when driving? NOW FIXED!!! Fri, 03 December 2004 07:46 Go to next message
I have an issue with my 4AGTE missing over 6000rpm. I've isolated any electrical faults or ignition/fuel inadequacies. The miss causes a significant hesitation, and a popping sound that you can hear from the tailpipe, and sometimes from the engine bay also.
This only happens over 14psi of boost, and gets worse from there as the boost is increased further (normally runs 19psi).
I'm starting to think that this problem is mechanical, and may even be caused by valve float, particularly since it only happens over 6k, with a lot of boost pressure behind the valve. It is an old bigport head that has probably done a lot of km's after all.
I've never experienced valve float & its associated effects, does the above sound like this?? I don't know heaps about valvetrain issues, so please throw your ideas/advice my way! Smile
[Updated on: Sun, 05 December 2004 02:39]
Re: Valve float: What does it feel like when driving? Fri, 03 December 2004 07:52 Go to previous messageGo to next message
What's your ignition system consist of, what's it like, and what plug gaps you using?
TE72_Turbo
Re: Valve float: What does it feel like when driving? Fri, 03 December 2004 07:57 Go to previous messageGo to next message
GZE coilpacks (have tried 2 sets), factory brand new leads (tried another set of these too), two types of plugs, Denso PK20R8 platinums (0.8mm), and NGK steel BKR7E-11, gapped down to both 0.8 & 0.7mm for no improvement Mad
Re: Valve float: What does it feel like when driving? Fri, 03 December 2004 11:59 Go to previous messageGo to next message
Have you checked out earthing, as well as the voltage at the coil at the critical time?
Also, what ECU you using again? I had similiar issues with my Haltech a while back, only much worse, and am also trying to think up a solution to another similiar problem with a mates car, also with a Haltech.
Mr DOHC
Re: Valve float: What does it feel like when driving? Fri, 03 December 2004 13:20 Go to previous messageGo to next message
are u supposed to be running resisted plugs??
TE72_Turbo
Re: Valve float: What does it feel like when driving? Fri, 03 December 2004 13:31 Go to previous messageGo to next message
Checked resistance of all earths, ran additional earths direct to the battery, added extra earth straps from the block to chassis etc, no difference.
Havn't had a multimeter on the coilpack whilst driving, I'm not sure how fast the readout would react, and I don't like keeping the foot buried for long at 6500rpm with it missing like crazy Confused I have however temporarily hard-wired the coil power (with a fused 6mm wire) direct to the positive battery cable, to be sure that there is no voltage drop issues.
I'm using Haltech E6K. Had issues earlier with trigger noise/interference, fitted an external ignition reluctor adapter (RA8) which fixed that problem, and now this pops up Mad
What's going on with your mate's car & haltech?
[edit] MR DOHC: Yes, I am supposed to be running resistor plugs. Without them, ignition inteference with the ECU is even more likely.
Phil
[Updated on: Fri, 03 December 2004 13:39]
Re: Valve float: What does it feel like when driving? Fri, 03 December 2004 14:23 Go to previous messageGo to next message
I haven't had a chance to have another look at it for weeks, but it's a 7MGTE, fairly standard, with an E6S-8. Apparently at first the problem was intermittent, but then became pretty much constant - constant crossfiring. It's got the 3 double ended coilpacks, just like yours. With persistance, you can get it to start (amid backfiring etc.), and sort of run, but it alternates between 2 and 6 cylinders, won't idle properly, etc. I suspect it's a triggering problem. Whoever installed it made a bit of a butchery of the wiring, and also decided to mount a single hall switch down next to the crank pulley.
When 'running' (I use the term loosely!) it appears to be fuelling alright, and the laptop shows the correct RPM.
I'm thinking a rewire won't hurt the car myself...
TE72_Turbo
Re: Valve float: What does it feel like when driving? Sat, 04 December 2004 00:51 Go to previous messageGo to next message
Sounds like a hairy one! Its a horrible job to sort through someone else's wiring abortion Mad
I have 3 spare 4ag heads, I think i'll just pick the best inlet valve springs to swap over tonight & see if it fixes the problem.
I'll be real keen to see how your new cams go now, cause if I have to upgrade springs, then I may as well fit some flash cams at the same time Very Happy
CelicaRA45
nth ringwood, Victoria
Re: Valve float: What does it feel like when driving? Sat, 04 December 2004 03:04 Go to previous messageGo to next message
sounds like a ref or sinc problem ,etc the motor doesnt know when to fire and that is causing it to sound rough at high revs check your wiring from the disy and make sure it is sheilded cable ,i had the same problem with my motec a broken wire that was fine around town but put heaps of load on it and it started jumping around ,and its not the valve springs
TE72_Turbo
Re: Valve float: What does it feel like when driving? Sat, 04 December 2004 05:16 Go to previous messageGo to next message
Been there, rewired with shielded cable from the CAS to ECU, earthed at the ECU end only, checked all for continuity, etc etc, still can't fix it.
I have swapped the CAS for another one too, just incase the reluctor pickups were not perfect, but that wasn't a problem.
NVD05X
parra
Re: Valve float: What does it feel like when driving? Sat, 04 December 2004 07:41 Go to previous messageGo to next message
a similar thing happened to me fo a while...
it turned out to be interferance from the cas cables...
so they were replaced with sheilded ones then it was a problem with the temp compensation values in the ecu... they were sorted and it ran ok for a while...
about 3 weeks later the whole ecu shat itself and stopped pulsing the ignition output and it cooked my coil...
i was then forced to buy a new ecu...
i hope yours is nothing like that...
TE72_Turbo
Re: Valve float: What does it feel like when driving? Sat, 04 December 2004 11:45 Go to previous messageGo to next message
So do I! Smile
I have changed the inlet valve springs tonight, and will take it for a test run tomorrow. I'm not confident that it will make any difference, but at least it will put my mind at ease. Cool
Thanks all.
allencr
tallahassee FL usOFa
Re: Valve float: What does it feel like when driving? Sat, 04 December 2004 20:37 Go to previous messageGo to next message
what's the compression???
don't bother with the springs.
you've got an ignition and/or fuel problem.
the rpm is nowhere close to max with even the wildest/strangest grind, and while you might have a single spring fail, it's beyond probability that all would fail or weaken up.
Re: Valve float: What does it feel like when driving? Sat, 04 December 2004 22:59 Go to previous messageGo to next message
is the CAS hooked up the right way? ECU will either trigger on up or downslope of the AC wave, and i remember people having 4AG missing at higher rpm issues before when the CAS was hooked up backwards.
is worth a shot to try, even for one run Wink
as for valve float, i don't know about a boosted car, but in my K/3K/4K it was like hitting a brickwall. basically accelerating hard then it just stops gaining revs....
YelloRolla
On your mum!
Re: Valve float: What does it feel like when driving? Sat, 04 December 2004 23:27 Go to previous messageGo to next message
TE72turbo,
I have been having the same issues recently and I have bought a heavier set of springs to fit (I thought similarly to you). As yet I have not fitted the new springs as I have been too busy.
I did have a similar problem a long time back (before I joined Toymods car club) and I did everything trying to track it down (this is how I wound up with the Wolf 3D, because in desperation I ditched the ECU). It ended up being the coils - I don't think that my current problem is coil related as the work is now shared amongst 4 of them - but I really don't know.
Re: Valve float: What does it feel like when driving? Sun, 05 December 2004 01:33 Go to previous messageGo to next message
so what coil cahrging time are you both running? if the charging time is not enough to just saturate the coils, you may not be getting a big enough spark to bridge the spark plugs gap under boost conditions.. you did say you'd tried smaller gaps to no avail tho....
at 8000rpm, an engine cycle is 16ms? so between each firing event is 4ms, and coil discharge time shouldn't be more than about 1ms.... so coil charging time of 3ms?
Re: Valve float: What does it feel like when driving? Sun, 05 December 2004 02:31 Go to previous messageGo to next message
If you want to change valve springs, just buy some aftermarket ones, they're not particularly expensive!
TE72_Turbo
Re: Valve float: What does it feel like when driving? Sun, 05 December 2004 02:39 Go to previous messageGo to next message
I cant stress enough to you all, that I have isolated all possibilities of an ignition or fuel issue Razz I have spent the last 2 months systematically working my way through all of the things you have each mentioned. Shocked
anyways.......
ITS NOW FIXED!!!!
I replaced the inlet valve springs last night with a good condition set from a spare head, and it now revs cleanly with 20psi boost to 7500rpm. The springs that I removed from the head had sagged between 0.8 & 1.1mm from the specified free length.
Yellorolla: There's a good chance that heavier springs may fix yours also, like I said earlier, I had little confidence (but all hope) that valve springs really would be the issue, but this confirms it, and i'm a happy man Very Happy Very Happy Very Happy
[Updated on: Sun, 05 December 2004 02:40]
Re: Valve float: What does it feel like when driving? NOW FIXED!!! Sun, 05 December 2004 14:44 Go to previous messageGo to next message
How'd you go replacing the springs with the head still on? I want to give this a go on mine (temporary thing until I take the head off and do it fully), but even though people say it's OK, I'm slightly concerned with accidently turning the valve a bit while the pressure is off and upsetting the seal. I was also going to throw in a new set of valve seals at the same time because I figure it can only be a good thing...
TE72_Turbo
Re: Valve float: What does it feel like when driving? NOW FIXED!!! Sun, 05 December 2004 21:37 Go to previous messageGo to next message
Its no drama, its the second time I've done it, last time was to change all 16 valve stem seals.
I just use a threaded fitting in the spark plug hole, hooked up to the air compressor at 100psi to hold the valves up, and then use a section of aluminium pipe (similar diameter to the spring), and get a mate to lean on it to compress the valve spring to remove the two retainers. Its a bit fiddly, but works fine.
YelloRolla
On your mum!
Re: Valve float: What does it feel like when driving? Sun, 05 December 2004 23:38 Go to previous messageGo to next message
oldcorollas- I am running 3.5ms; it used to have 5ms but we found more power keeping the charge time down
YelloRolla
On your mum!
Re: Valve float: What does it feel like when driving? Mon, 06 December 2004 04:50 Go to previous messageGo to next message
TE72_Turbo wrote on Sun, 05 December 2004 13:39
anyways.......
ITS NOW FIXED!!!!
Thanks Phil - I too have hope.
Youngy
Eskilstuna, Sweden
Re: Valve float: What does it feel like when driving? NOW FIXED!!! Mon, 06 December 2004 09:00 Go to previous messageGo to next message
TE72_Turbo wrote on Mon, 06 December 2004 08:37
I just use a threaded fitting in the spark plug hole, hooked up to the air compressor at 100psi to hold the valves up, and then use a section of aluminium pipe.......
This is a great thread. And what a cool idea above!!
Thanks gents
Re: Valve float: What does it feel like when driving? NOW FIXED!!! Mon, 06 December 2004 09:47 Go to previous messageGo to next message
I was thinking pretty much of using the compressed air trick, thing is if I'm going to pull the head off and do it up not long after anyway, I might not even bother. Guess I'll just see how it goes!..
Mr DOHC
Re: Valve float: What does it feel like when driving? NOW FIXED!!! Mon, 06 December 2004 10:06 Go to previous messageGo to next message
there is a special tool u can buy to compress the springs in the head, looks kinds like a 2 jaw pulley remover, just smaller, and once the collets are removed, the compressor and spring comes out in one piece and doesnt need to be re-compressed
Re: Valve float: What does it feel like when driving? NOW FIXED!!! Mon, 06 December 2004 10:09 Go to previous messageGo to next message
I'm pretty sure said tool comes with a special price too Evil or Very Mad
TE72_Turbo
Re: Valve float: What does it feel like when driving? NOW FIXED!!! Mon, 06 December 2004 12:37 Go to previous messageGo to next message
This is the cheap version, as used in my prestige workshop Razz Laughing Very Happy Very Happy
http://img73.exs.cx/img73/8071/t2xvalvesst.jpg
Fortunately the 4AG springs are pretty soft, so its not hard to compress them just by leaning down on the "special service tool." A magnet makes it easy to capture the 2 retainers/locks when they are free from the valve stem. This may not be so easy on some other heavier sprung toyota heads.
[Updated on: Mon, 06 December 2004 12:39]
takai
Re: Valve float: What does it feel like when driving? NOW FIXED!!! Mon, 06 December 2004 20:25 Go to previous message
The two jaw things arnt expensive, but they only work on finned heads like the big inline 6 Ford heads. They tend not to work on the dohc heads because there is nothing to grip on. They certainly do not work on 4AGs.
The other thing is that replacing HKS valve springs that way is very perilous, or for that matter any heavier valve springs. I gave it a go once, and never again.
Previous Topic:turbo questions
Next Topic:4age and 4agze high pressure power steering line.
Current Time: Fri Nov 20 13:14:28 UTC 2026
Total time taken to generate the page: 0.016658782958984 seconds
