Toymods » Tech & Conversions » JZA80 Tacho signal voltage?
RA23_Sean
Western Sydney
JZA80 Tacho signal voltage? Fri, 03 December 2004 11:10 Go to next message
Does anyone know the tacho signal voltage on the JZA80? Trying to make the tacho work on one powered by a 1J, a Haltech E6K and twin M&W ignitors.
sideshow
Re: JZA80 Tacho signal voltage? Fri, 03 December 2004 11:52 Go to previous messageGo to next message
does the halteck have a tacho output if so u need a booster
if not then u need something like an autronic tacho adapter
u can run 2 signals in from each coil then it adds them together then has one output
i can supply both if you need them
Re: JZA80 Tacho signal voltage? Fri, 03 December 2004 14:27 Go to previous messageGo to next message
Or you can just join the coil -ve wires together with diodes, if you're handy with a soldering iron.
RA23_Sean
Western Sydney
Re: JZA80 Tacho signal voltage? Sat, 04 December 2004 10:53 Go to previous messageGo to next message
There isn't a tacho output as such on the Haltech. You have to configure the auxillary output to run the tacho. It's a 0-12 volt signal. It's probably best to leave that for something a bit more useful.
I got the tach adaptor diagram from Haltech, so I think I'll just run that and see how it goes.
Grant
Newcastle, NSW, Australia
Re: JZA80 Tacho signal voltage? Sat, 04 December 2004 11:28 Go to previous message
The RA23 tacho will work on a 0-12 signal so you should be right if you follow haltech's instructions.
Previous Topic:wheel studs too short
Next Topic:gz20 seats into ra28
Current Time: Sun Oct 25 03:04:50 UTC 2026
Total time taken to generate the page: 0.0084829330444336 seconds
