Toymods » Tech & Conversions » 1ggte turbo upgrade
1ggte89
1ggte turbo upgrade Fri, 03 December 2004 15:22 Go to next message
what size turbo would you recommend for a 1ggte
single turbo that is i was thinking a t04 Twisted Evil
also wat sort of boost could i run safely on standard internals?
what sort of boost should i be able to run before i would need bigger injectors and need to upgrade the fuel system? Very Happy Very Happy
Mookie
Tassie
Re: 1ggte turbo upgrade Sat, 04 December 2004 02:01 Go to previous messageGo to next message
What model 1G is it ?
do a search beacuse i KNOW there is a thread that this is disscused on .
1ggte89
Re: 1ggte turbo upgrade Sat, 04 December 2004 09:42 Go to previous messageGo to next message
its a gen 3 1g i have a rebic Lc and hks multi valve controller already
Fattony
Re: 1ggte turbo upgrade Sat, 04 December 2004 10:54 Go to previous message
I dont think much of sleeve bearing turbos, even though a lot of ppl used them but on 1gs. If you have the money do yourself a favour and use a bb turbo. If you want to find the limits of what package you want to buy, ask yourself how much horsepower you want to attain out of the motor and more relivant answers can be given to your questions of limits of wheather you would need to rebuild the motor and upgrade fuel system components. Though to give you an answer to your questions as they are:
I really doubt you will see the limits of the std internals if your setup is properly tunned ect. If you take into account that these motors in early celicas have seen to run a lowest et of a 10.08 with claimed standard internals on 25psi.
Though this was done with a LOW KM motor in apparent good condition.
Well this all depends on whether your running a stock fuel pressure regulator or an adjustable item and what fuel pump you use and genaral condition of it. For your car you could only find this out on a dyno to know exactly how much you can run, though if you want to play it on the safe side, i wouldnt suggest you let it see more than 15psi without some equipment measuring to see if your leaning out or not.
Hope that helps
Cheers Adam
Previous Topic:gz20 seats into ra28
Next Topic:Annoying Sqeek from rear end.
Current Time: Sun Oct 25 10:35:45 UTC 2026
Total time taken to generate the page: 0.0061068534851074 seconds
