Toymods » Tech & Conversions » 4ag 86kw v 100kw pistons
chrisss
melb
4ag 86kw v 100kw pistons Sun, 13 October 2002 01:46 Go to next message
can anyone explain the differences between the two in terms of compression.
I want to use a 100kw block/pistons under a 86kw head and are wondering if I will get the same compression(10.3 - 1) as a 100kw gets.
or is there a differnece in capacity between the bigport and small port head.
._T_.
Re: 4ag 86kw v 100kw pistons Mon, 14 October 2002 22:38 Go to previous messageGo to next message
chris,
firstly, the 100kw motor is not actually 10.3:1 cr, it is actually about 9.8:1. we put a 100kw bottom end under a big port head on a aw11 - it ran much better than it should have!!
the port sizes are different (obviously) - the combustion chambers are the same
T
barbel
Re: 4ag 86kw v 100kw pistons Mon, 14 October 2002 22:41 Go to previous messageGo to next message
toby,
when you did this was it just a straight swap, leaving all else the same... i have a 100kw bottom end sittin out back and was thinkin of doin this, do you recommend it?
ae86trueno
Re: 4ag 86kw v 100kw pistons Tue, 15 October 2002 04:37 Go to previous messageGo to next message
I currently run this configuration at the moment,
and my understanding so far that it is higher compression to run the 100 KW bottom end due to the shape of the piston.
ill take some photos taday but there is distinct differences between the pistons, and there may even be a third piston which is a really high compression piston similar to that of TODA racing pistons which have a compression of 11:1 (which i just fractured one of in my engine Nope )
http://www.todaracing.com/images/product_toyota_pistonkit.jpg
the centre of these pistons raises a little more .The ACL replacement 100KW does not raise up that far, and the 86KW pistons do not raise up at all and in fact are recessed completely. I would be interested in a pick of someone elses 100KW factory pistons to see if there is any difference.
But basically it is a straight bottom end swap and everything lines up.
Ben
AE86 Trueno 4AGE
Grega
melbourne.victoria.austra...
Re: 4ag 86kw v 100kw pistons Tue, 15 October 2002 05:03 Go to previous message
barbel - T's motor was one grouse little motor heaps of torque and went very very well - i would recommend it!
[Updated on: Tue, 15 October 2002 05:03]
Previous Topic:questions about watanabe wheels
Next Topic:4age 20v powerchip
Current Time: Fri Oct 23 11:10:28 UTC 2026
Total time taken to generate the page: 0.0049088001251221 seconds
