Toymods » Tech & Conversions » How do you measure shim clearances??
BlackSupra
How do you measure shim clearances?? Sat, 04 December 2004 23:01 Go to next message
I have searched but can't seem to come up with any solid info on the topic.
I was just wondering how one goes about measuring up shim clearance for a shim over bucket on a 2jzge.
What tools do i need? how do i go about? What are the tolerances?
and what happens if a shim is under spec or over spec?
thanks guys.
BlackSupra
Re: How do you measure shim clearances?? Sat, 04 December 2004 23:14 Go to previous messageGo to next message
I found this after searching supra forums, looks like it will apply just fine.
http://www.jblmk3.com/id92.htm
EVOSTi
cambo
      no
Re: How do you measure shim clearances?? Sun, 05 December 2004 10:51 Go to previous message
in short, its a cunt of a job, give it to a head place Confused
but if you insist, you use feeler gauges like you would do tappet clearances, work out the extra thickness you need, measure the shim thats in it with a GOOD micrometer, add that to the extra you need then thats the thickness of shim you need. then you go to the toyota shim listing and see if they have one that size.
Previous Topic:Polished Alloy
Next Topic:Turbo 1970 Corona?
Current Time: Sat Oct 17 21:10:49 UTC 2026
Total time taken to generate the page: 0.004662036895752 seconds
