Toymods » Tech & Conversions » Where is the fuel pump wire...
biased99
Where is the fuel pump wire... Sun, 13 October 2002 02:02 Go to next message
...on an '89 MX83 Cressida? I need to find the "end" of this, so that I can connect it to the Autronic ECU.
Anyone?
BTW. I've had a look under the car near the tank and can only locate feed and return fuel lines and brake lines... Embarassed (Gives some idea of my "hands-on" ability - ie. None).
SUPRAGTE
North Sydney
Re: Where is the fuel pump wire... Sun, 13 October 2002 04:35 Go to previous messageGo to next message
Its probably an intank pump, so you'll have to go through the boot to get to the pump.
SUPRAGTE
North Sydney
Re: Where is the fuel pump wire... Sun, 13 October 2002 04:39 Go to previous message
But i wouldn't be hooking it straight up to the Autronic when you find the pump power.
Most aftermarket ecu's will only allow you to sink the load side of a relay's contacts which is a much smaller current than a fuel pump which can be a few amps. It will blow your autronic if it isn't meant to be hooked up like that.
Previous Topic:Coil Packs
Next Topic:4A-GE 16v/20v Valve Springs...
Current Time: Fri Nov 20 19:23:42 UTC 2026
Total time taken to generate the page: 0.00724196434021 seconds
