Toymods » Tech & Conversions » What cars come with front sump 1JZGTE's?
woofa347
Whyalla
What cars come with front sump 1JZGTE's? Sun, 05 December 2004 04:56 Go to next message
Ever since I ordered my 1JZ engine package they told me it was a front sump from a JZA70 Supra. I thought all front sump 1JZ's were from CHasers, because when I went to order the engine I specifically asked for a CHaser JZX81 Front cut, but ended up with just the 1JZ engine package Sad
Weve had wiring troubles from day one, and have found out that the original ECU and wiring loom must be off either a Soarer or Chaser as the plugs were 4 pins high but the Supra ones were only 3 pins high (found this out by a stroke of luck because my Apexi turbo timer came with ECU pinoutrs for lots of cars.).
Instead of trying to wire the loom up that he we are stuck with now, a guy in Sydney said if we can tell him what car and what engine it is, he can send me a complete loom with wiring diagrams. The possibilities are narowed down to either the T8-a, T8-b, or T8-c ECU's. Reason why we cant tell which one it is, is because the original loom that came with the engine had 2 ECU plugs that were completely smashed, thats why we sent it back, then sent us back a completely different loom Sad And each of those 3 ECU mentioned above have the ground and OS Sensor wires in a different spot.
Sorry for the long post, I hope someone can make sense of it all lol
[Updated on: Sun, 05 December 2004 04:58]
Celia-Sue
Re: What cars come with front sump 1JZGTE's? Sun, 05 December 2004 06:10 Go to previous messageGo to next message
1JZ's with front sumps: JZX80, JZX90, JZX100/110.
Now, unless you've noticed a second (TCCS)throttle or VVTi, AFM and single turbo, I'd say you've got a JZX80 Chaser (or something else with a Chaser sump). 4 pin sounds vaguely familiar - maybe JZX90.
JZX80 wiring looks a little like this ( Cool ):
http://www.1jz-gte.us/documents/SubDocs4/chaser.pd f
Good luck! I'm taking some photos of my half-cut letf-overs in the next week or two - let me know if you want pics of JZX90 ecu and loom.
woofa347
Whyalla
Re: What cars come with front sump 1JZGTE's? Sun, 05 December 2004 08:35 Go to previous messageGo to next message
I got the twin turbo non-vvti 1JZGTE, it has the second throttle body (traction control), but we will wire it up then diconnect it as my Cressida doesnt have ABS brakes. If only the connectors on the original loom wernt smashed the car would have been done in about 5 weeks, but were now into the 7th month of the swap Sad.
That would be great if you could send me some pics!!
My email is eptrophy@ozemail.com.au
Were pretty sure its from a Chaser, but its just hard to know which ECU it is. Once I know for sure which one it is, I can let this guy know and he can send me a complete loom with ECU and wiring diagram, then it shouldnt take long to get it all wired up and on the road Very Happy
Celia-Sue
Re: What cars come with front sump 1JZGTE's? Sun, 05 December 2004 09:19 Go to previous messageGo to next message
Hey, if it's any colsolation - my swap took about 11 months.
And that certainly sounds like a JZX90 Chaser to me (same as I used - though I ended up going aftermarket ECU).
Won't be for a week or two, but I'll send you pics of my 1995 auto JZX90 (MkII) ECU and loom.
Justin
woofa347
Whyalla
Re: What cars come with front sump 1JZGTE's? Sun, 05 December 2004 09:37 Go to previous messageGo to next message
Are you happy with the swap? Ive never driven a turbo car before Embarassed What sort of numbers can I expect to see when the swap is done?
Cool, thats what we were thinking, because I think the JZX81 ECUs were 2 row pins, so I think it narrows the ECU search down a bit. Im not too sure at the moment because the turbo timer ECU pinouts are at the mechanics, but I'll go have a look tomorrow and check it out again.
Just out of interest, what aftermarket ECU did you choose, are there any that you would recommend?
Chris Davey
sunny coast, qld
Re: What cars come with front sump 1JZGTE's? Sun, 05 December 2004 09:54 Go to previous messageGo to next message
I seem to remember someone saying that the jzx81 Chaser's had the seperate ECU to control the auto. Then they went to the single computer controlling engine and auto. That is what mine has which is a jzx90 engine. I agree with Celia-Sue though Smile
oh yeah, with the mods in your sig you should be looking at around 225rwkw in shootout mode. remember dynos are for tuning not showing off Razz
[Updated on: Sun, 05 December 2004 09:55]
woofa347
Whyalla
Re: What cars come with front sump 1JZGTE's? Sun, 05 December 2004 12:35 Go to previous messageGo to next message
So its more than likely the JZX90? Now all it leaves it to work out which ECU it is, should narrow done to a chocie of two...I'll get more details tomorrow.
Excellent, 200kw at the wheels + sounds good Smile
They are??? What is this "tuning" you speak of? Razz
sideshow
Re: What cars come with front sump 1JZGTE's? Sun, 05 December 2004 12:47 Go to previous messageGo to next message
the loom has to match the ecu
and the loom has to match the gbox
on the engine i think the loom is similar except for lil probs like aircon which doesnt matter anyway
but the main difference is the back section of the gbox
where the looms vary
so the loom has to match the gbox and the ecu
one gbox has a 3 wire sensor the other ecu has a 2 wire sensor
there is 3 types of ecus
3 plugs each 2 rows
4 plugs each 4 rows
2 plugs one 40 pins other plug 2 lots of 40 pins
woofa347
Whyalla
Re: What cars come with front sump 1JZGTE's? Sun, 05 December 2004 13:16 Go to previous messageGo to next message
yeh thats whats happening at the moment, the wiring loom supposedly matches the ECU, all the plugs go in except the flyer wires are different, and I think its a Soarer wiring loom that weve been supplied with. The original loom we had before we sent it back, was the 4 plugs with 4 row pins ECU.
On the turbo timer pinouts it shows three different 4 plug 4 row ECUs, the T8a to the T8c, im not sure which one we need because each one has the ground sensor and OS sensors in different spots. But if I can find out which one it is, the guy can get me a complete loom with matching ECU for the engine, with matching wiring diagram.
mmm, the wires for the transmission are totally different from the first loom we had.
sideshow
Re: What cars come with front sump 1JZGTE's? Sun, 05 December 2004 21:43 Go to previous messageGo to next message
so the loom has the 4 big plugs
and the small flyer plug on the side
or the ecu has the small flyer plug comin out the side of it
i can find out what loom and ecu it if it has the flyer plug as i have done my friends cressida with that tyype of ecu and loom
Re: What cars come with front sump 1JZGTE's? Mon, 06 December 2004 01:06 Go to previous messageGo to next message
woofa347 wrote on Sun, 05 December 2004 16:35
You see by now, I would have said fuck it, bought an aftermarket ecu, and a manual transmission, and had my car on the road months ago.
woofa347
Whyalla
Re: What cars come with front sump 1JZGTE's? Mon, 06 December 2004 02:13 Go to previous messageGo to next message
Thats what is annoying us, because we are trying to get the original loom and ECU that come with the engine which was the 4 big plugs with 4 row pins, when we sent the original loom back as all the ECU plugs were smashed to bits, the replacement loom and ECU they sent back to us is meant for a Supra (Toyota T6-a ECU , 4 plugs, 2 row pins), and the flyer wire coming from the ECU is a totally different plug to the loom one (different shape, and ECU has 8 pins, loom has 10 pins).
When we ordered the engine, they didnt send us the ECU at first for warranty reasons, so I cant tell you what the flyer wire looked like sorry, but I can ask my mechanic and see if he remembers what the loom flyer wire looked like.
So yeh....lol. Im hoping to track down the loom we need so we can tell this guy what one it is, he can send the complete loom, ECU and wiring diagram, and start from scratch. With the right loom and everything it shouldnt take too long though.
I agree with you Cruzida, nut I dont exactly have the money lying around to get aftermarket ECU and swap to manual trans, have Uni to pay for aswell.... Sad
Re: What cars come with front sump 1JZGTE's? Mon, 06 December 2004 02:17 Go to previous messageGo to next message
woofa347 wrote on Mon, 06 December 2004 10:13
I didn't have the money to begin with either, but after 4 months of fucking around with wiring, I suddenly had the money for an ecu
woofa347
Whyalla
Re: What cars come with front sump 1JZGTE's? Mon, 06 December 2004 02:35 Go to previous messageGo to next message
I have drawn up some rough diagrams of the trans wires and speed sensor diagram we were given if they can help track down what loom I need. Im just really annoyed that we were supplied the wrong loom and everything Mad
The pics are on my cardomain webpage below:
http://www.cardomain.com/memberpage/619534/3
hopefully there read-able.
Sorry for the crap diagrams, was in a bit of a hurry. The trans is 23 spline if that helps?
The other diagram is of the ECU pinouts I was talking about that come with my turbo timer. The T6-a ECU that is circled is the one that they have supplied us with now. I think the one we need is one of the T8 ECU's. From the diagram it says the T8's were used in Soarers and Chasers, but as mine is front sump it would have to be from a Chaser right?
And if we get a loom made for the Chaser with matching ECU it shouldnt really matter which one of the T8 ECU's we get ? Except that the trans wires will need to be the same of course.
woofa347
Whyalla
Re: What cars come with front sump 1JZGTE's? Mon, 06 December 2004 02:36 Go to previous messageGo to next message
nice! WHat aftermarket ECU are you using? Is there a particular one you would recommend for the 1JZ? I have heard of someone using a Haltech that had 1JZ maps included
Celia-Sue
Re: What cars come with front sump 1JZGTE's? Mon, 06 December 2004 02:55 Go to previous messageGo to next message
Yeh, I love the 1JZ! Though I'm strating to hunger for a bit more power now Rolling Eyes Trust me, when you do hit the road, it will all be worth it!
With those mods AND a programmable management, you'll probably come close to 300rwhp. I'm using the Haltech E6X (1JZ base map) with 3 bar MAP sensor and electronic boost control solenoid (gets you onto boost DAMN fast). Excellent idle and ancillery control for the money. See: http://www.tweakit.net/shop/product_info.php?cPath =&products_id=92
Chris Davey
sunny coast, qld
Re: What cars come with front sump 1JZGTE's? Mon, 06 December 2004 02:56 Go to previous messageGo to next message
yeah, that is Celia-Sue. People have used microtech LTX12's, Haltechs and Wolf 3d's. All seem to work fine so if you are going to go aftermarket you just get one that your tuner knows about.
BTW my wolf 3d doesn't come with a base map but I found one on the internet anyway.
woofa347
Whyalla
Re: What cars come with front sump 1JZGTE's? Mon, 06 December 2004 03:02 Go to previous messageGo to next message
Sounds great. Im hoping to stick with what I have for now, then do everything all at once like replace twin turbos to T28BB's , injectors, and ECU Very Happy Im so broke right now lol
So with the haltech would I still need the hiperboost system? The haltechs were fairly decent for the price wernt they
Celia-Sue
Re: What cars come with front sump 1JZGTE's? Mon, 06 December 2004 03:10 Go to previous messageGo to next message
Nah, you get the Haltech (E11 is the top-shelf model), then for an extra $120, get the wastegate soleniod for total electronic boost control. Which is better than any manual bleed valve and would set you back around $500 as a stand-alone unit.
Say, where are you getting your split dump-pipes from?
woofa347
Whyalla
Re: What cars come with front sump 1JZGTE's? Mon, 06 December 2004 03:18 Go to previous message
Cool I'll have to look into the Haltechs, I dont really know much about aftermarket ECU's.
Im getting them done at my local exhaust shop called JAGT exhaust systems. He quoted me about $350 for just the pipes not including heat proof coating. He did the custom 3" exhaust work on the Cressy and I also seen his work on a 1JZ Celica-Supra that was in his workshop once, he made up complete new manifolds for it, does very nice work.
Previous Topic:20 v into sprinter distributor problems
Next Topic:ke11 lsd rear axle?
Current Time: Sun Oct 25 02:36:13 UTC 2026
Total time taken to generate the page: 0.075930118560791 seconds
