Toymods » Tech & Conversions » Cressida (7MGE) Tacho with 1GGTE
Darkstar
Ebbw Vale, Qld
Cressida (7MGE) Tacho with 1GGTE Tue, 07 December 2004 00:10 Go to next message
Hi guys. I was wondering why the tacho on the cressida dash won't work with the 1GG?? I have the right wire from the engine and from the dash, but no signal is getting through. I did try hooking up the tacho directly to the coil, which seemed to work but only at about half of what you'd expect eg. 1500 at about 3000rpm.
Any suggestions?? Confused
HyDrA
Adelaide, SA
Re: Cressida (7MGE) Tacho with 1GGTE Tue, 07 December 2004 01:01 Go to previous messageGo to next message
Have you checked all your grounds on the 1G's loom? This HELPED mine... still doesn't work correctly imho.
Who needs a tacho anyway, when it starts bouncing off the rev limiter you should change gears Razz Razz
Darkstar
Ebbw Vale, Qld
Re: Cressida (7MGE) Tacho with 1GGTE Tue, 14 December 2004 04:26 Go to previous messageGo to next message
Hehe Laughing
Well that's true i guess...... woulda been good to get it workin though
sleepermx83
central coast nsw
Re: Cressida (7MGE) Tacho with 1GGTE Tue, 14 December 2004 11:32 Go to previous messageGo to next message
hows the 1ggte compare to the 7m. and was it an easy swap? you should get a auto sparky to look at your tach. i rekon theyd get it workin in 10min.
sideshow
Re: Cressida (7MGE) Tacho with 1GGTE Tue, 14 December 2004 11:59 Go to previous message
you need a tacho booster
i have small ones that i make that work on every cressida that i have done with 7mgtes and 1jzs
the orig engine in the cressida the signal comes from the neg coil
the proper tach signal from the 1gg is weak
[Updated on: Tue, 14 December 2004 11:59]
Previous Topic:Toyota Celsior
Next Topic:ke30 strut conversoin comparison
Current Time: Mon Oct 19 18:03:30 UTC 2026
Total time taken to generate the page: 0.0056478977203369 seconds
