Toymods » Tech & Conversions » How hard is it to remove 1j twins?
sxturbo
Central Coast
How hard is it to remove 1j twins? Tue, 07 December 2004 00:11 Go to next message
guys i have had the unfortunate luck of being one of the few ppl that have blown a 1j head gasket, i am wondering how hard it is to remove the stock turbos and inlet manifold with the engine in the car???
Re: How hard is it to remove 1j twins? Tue, 07 December 2004 00:21 Go to previous messageGo to next message
a royal pain in the arse :\
one of the bolts is a real slut to get to (well, on the turbos anyway, I haven't actually tried to remove the manifold)
it will require lots of time and swearing (and, max will tell you, the tongue thing).
Chris Davey
sunny coast, qld
Re: How hard is it to remove 1j twins? Tue, 07 December 2004 03:51 Go to previous messageGo to next message
Yeah, getting the rear turbo off is the hardest part. It was especially difficult in my Corona compared to regular 1jz powered cars.
Then you take the 12 bolts off the exhaust manifolds. You will most likely pull a fair few studs out which is also a pain in the arse to get the bolts off the studs.
Then pull the inlet manifold off and wiring that is connected. This took me and my dad about 2 hours but we had never done it before.
Then pull, the cam covers off. Undo the bolts that hold the cam down. Keep them in the correct order. Pull the fastener things off. Then you get the bolts that hold the cam gears in. And you can now take the cams out. Also you can remove the buckets and shims.
That is as far as I got. But I would imagine, you just get the main head bolts from there. Anyone know?
Manny
Re: How hard is it to remove 1j twins? Tue, 07 December 2004 09:40 Go to previous messageGo to next message
Remove the head with intake and exhaust parts intact...easy to remove turbos from head off the car where space doesn't restrict access. BIt more work but probably easier.
sxturbo
Central Coast
Re: How hard is it to remove 1j twins? Tue, 07 December 2004 09:57 Go to previous message
thanks for the reply's. is there anyone on here that has had to change a 1j head gasket? as i have only ever heard of 2. if so is there anything i should look out for or tips that anyone has?
Previous Topic:ae101 help
Next Topic:EFI setup for 18RGEU
Current Time: Wed Oct 28 05:23:25 UTC 2026
Total time taken to generate the page: 0.0049691200256348 seconds
