Toymods » Tech & Conversions » Leakdown test results
Hunty
Leakdown test results Tue, 07 December 2004 02:23 Go to next message
hey, have had a leakdown test done on a car that i am looking to buy but the results are a bit troubling
a compression test was also done here are the results
1. 155psi / 80% leak
2. 135psi / 90%
3. 135psi / 85
4. 125psi / 95%
What should i make of this?
The mechanic told me that the engine probably needs a rebuild, especially if i want to crank a bit more power out of it
the engine is a 1.8 turbo, if your wondering.
Chris Davey
sunny coast, qld
Re: Leakdown test results Tue, 07 December 2004 03:47 Go to previous messageGo to next message
I was told 10percent or less leakdown is ok.
I don't understand why the highest leak down also had the highest compression though?
Those compression numbers look a bit varied also.
Hunty
Re: Leakdown test results Tue, 07 December 2004 03:57 Go to previous messageGo to next message
highest leak was cyl 4 with 95% leak. it also had the LOWEST compression at 125psi
7mgtema71
Re: Leakdown test results Wed, 08 December 2004 05:36 Go to previous messageGo to next message
http://www.racerpartswholesale.com/long29a.htm
You may be reading that incorrectly there. According to the description of a Leakdown test on the link above, if the right guage reads 95%, then there's 95% leakdown (or 5% leakage). If you read you results again it would appear like so;
1. 20% leakage
2. 10% " "
3. 15% " "
4. 5% " "
Hunty
Re: Leakdown test results Wed, 08 December 2004 05:57 Go to previous messageGo to next message
Hmm, the guage i saw had on dial red green and yellow sections on it. it was something like 0-20% in yellow for "Good" 20-40% in green for "acceptable" 40-100% was in red.
Those percentages i put up there is the amount of air leaking out of the cylinder,ie 85% of the air being put in is leaking out. all the results were massively in the red section. i've talked to couple of mechanics since and it seems like the engine is pretty well worn out. Back to hunting for a new car Smile
It's an import and the odo says 121,000k's but they guys i've spoken to reackon that with those compression/leak its more likely to be 220,000ks or more
IRA11Y
Club Member
Re: Leakdown test results Wed, 08 December 2004 08:08 Go to previous messageGo to next message
compression is not a good indication in determining the age or lifespan of an engine.
Flem
cambo
Re: Leakdown test results Thu, 09 December 2004 08:06 Go to previous messageGo to next message
was that cold or hot how long has the engine been siting around for and not started but by the sound of it rebuild time
wilbo666
Re: Leakdown test results Thu, 09 December 2004 09:08 Go to previous message
IRA11Y wrote on Wed, 08 December 2004 19:08
Yeah? Can you elaborate more on this? I'm interested! Smile
Previous Topic:s13 brake conversion help +aus spec 86 wiring diagram
Next Topic:Throttle cable/pedal
Current Time: Thu Nov 19 08:21:31 UTC 2026
Total time taken to generate the page: 0.005850076675415 seconds
