Toymods » General Car Talk » dyno celica with turbo upgrade
dyno celica with turbo upgrade Sun, 13 October 2002 23:31 Go to next message
Hello, had the Celica tuned/dyno'd on the weekend with the new ct20b turbo/custom exhaust manifold/intercooler & 550cc injectors.
I was very happy with the results. Previously it was in the mid 80's kW at the toymods dyno day(stock turbo, no intercooler).
Now it has pretty much doubled at 167 kW.
http://www4.tpgi.com.au/helenftz/pics/dyno1.jpg
GIN51E
Berowra-Sydney
Re: dyno celica with turbo upgrade Sun, 13 October 2002 23:41 Go to previous messageGo to next message
i hate having this feeling called being jelouse Sad
thetoyman75
Club President
Re: dyno celica with turbo upgrade Sun, 13 October 2002 23:47 Go to previous messageGo to next message
Damn !
Maybe I should have just cut a hole in the bonnet ! Great result mate. Smile
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: dyno celica with turbo upgrade Mon, 14 October 2002 00:22 Go to previous messageGo to next message
Nice dude! You must be happy!
Seems a bit iffy after 4500rpm though. Any ideas what that could be?
Guest
Re: dyno celica with turbo upgrade Mon, 14 October 2002 01:03 Go to previous messageGo to next message
Dont mean to put a damper on things but please note:
"Power at: Engine Torque at: engine temp compensation: YES"
These settings on the dyno make for a significant increase compared to the way the cars were run on the dyno comp. Perhaps 30% inflated.
Still a great result though.
Matt
Nark
Cabramatta, NSW
icon4.gif  Re: dyno celica with turbo upgrade Mon, 14 October 2002 01:09 Go to previous messageGo to next message
Just noticed that it says that it was done in 3rd gear.
That'll give some torque multiplication too.
Don't know how much though.
manipulate
Re: dyno celica with turbo upgrade Mon, 14 October 2002 01:46 Go to previous messageGo to next message
TOYO3T wrote on Mon, 14 October 2002 11:03
Matt
PLS xplain ??
Nark
Cabramatta, NSW
Re: dyno celica with turbo upgrade Mon, 14 October 2002 02:21 Go to previous messageGo to next message
Power at: Engine means that the software would try to figoure out a FLYWHEEL figure...
Torque at: engine temp compensation: YES means that the software sould try to "compensate" for an engine that's hot... One trick dyno operators use is to turn this on and stick the temperature probe in something that's REALLY hot, thus more compensation for the heat.....
Dyno tricks used by dodgy dyno operators.
Re: dyno celica with turbo upgrade Mon, 14 October 2002 02:23 Go to previous messageGo to next message
The temp probe was placed on the top of the shock tower, with bonnet up. So my guess would be pretty cool temperatures there.
Nark
Cabramatta, NSW
icon10.gif  Re: dyno celica with turbo upgrade Mon, 14 October 2002 02:54 Go to previous messageGo to next message
Only way to know for sure is to go to Dyno Day 6.
Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy
Guest
Re: dyno celica with turbo upgrade Mon, 14 October 2002 03:16 Go to previous messageGo to next message
Temperature compensation if used at all I'm pretty sure is an atmospheric temp compensation.
ie. it tries to compensate for a hot day or other atmospheric conditions.
i dont know if temp compensation was switched on for dyno day 5, maybe someone could post up if it was.
Usually in dyno comps or honest power runs it is switched off.
What really counts is what car actually put down to the rollers ie. Tractive effort.
Without corrections.
temp compsation would be insignificant anyway compared to the adjustment made for drivetrain losses. I have heard figures for rwd's quoted as anything between 12 to 33 %. It depends on the motives of your tuner as to what he will apply.
it is odd in any case that he would print a engine figure rather than a RW figure anyway.
all things considered, I reckon Joels 3t is making at least 120 kw at the wheels, which is better than mine EVER ran and he should be proud of a great result.
Joel, dont miss the next dyno day !!!
Matt
Nark
Cabramatta, NSW
Re: dyno celica with turbo upgrade Mon, 14 October 2002 04:25 Go to previous messageGo to next message
I think it's switched off for our dyno days. Either that or the compensation isn't that great.
The figures from Dyno Day 4 (40 degree temps) were a few kW lower than from Dyno Day 5 on the same cars.
TurboRA28, make sure you come to Dyno Day 6!!!
Bugman
Re: dyno celica with turbo upgrade Mon, 14 October 2002 04:26 Go to previous messageGo to next message
so was your run at the creek the other week before or after this mod?
TE72_Turbo
Re: dyno celica with turbo upgrade Mon, 14 October 2002 09:53 Go to previous messageGo to next message
Joel
Nice result no matter what the factors mate, all that matters is that i'm sure it feels unreal from the drivers seat! Very Happy
how much boost are you running with the CT20B? Do you have any pictures of the new manifold and turbo setup?
GO THE 3TGTE!!!!!!!!
Phil
BTW: How the f@#k is the difference between 3rd & 4th gear supposed to be so significant when if you could have a 3.7:1 or 4.4:1 diff ratio working as a multiplication factor anyway???? Rolling Eyes
Re: dyno celica with turbo upgrade Mon, 14 October 2002 23:07 Go to previous messageGo to next message
Howdy, its running around 20psi. There are a few pics at www4.tpg.com.au/helenftz .. Need to be updated though as I think they are all pics of the setup off the car.
Eastern creek 14.2 was with this setup, but since then has been tuned for another 4psi.
SUPRAGTE
North Sydney
Re: dyno celica with turbo upgrade Tue, 15 October 2002 12:48 Go to previous messageGo to next message
How do they know what rpm the engine is doing?
Do they use an inductive pickup wired to the dyno PC?
4SFED
Melbourne, VIC
Re: dyno celica with turbo upgrade Wed, 16 October 2002 03:23 Go to previous messageGo to next message
So.... when and where is this dyno day 6 at? I will bring the celica down and strap her on the rollers if it is finished, if not i will still come down for a look (if its in the Melb area anyway!)
thetoyman75
Club President
Re: dyno celica with turbo upgrade Wed, 16 October 2002 06:39 Go to previous messageGo to next message
Phil,
Mate here is a pic of Joels Engine bay at the creek on the night.
(Hope thats ok Joel ? )
http://www.toymods.org.au/~rod/Eastern%20Creek%20Shots/Joels%20Engine%20bay%20-%20small%202-10-02.jpg
Timbo,
Mate the Dyno Day has its own thread in Cruises and Events and is held at Premier Auto in Western Sydney in January next year. Be great to see you there. There are generally a few from South of the border who cruise up including the last Dyno Days overall Winner.
Re: dyno celica with turbo upgrade Wed, 16 October 2002 06:56 Go to previous messageGo to next message
Mate that is fine. I have been wanting a nice shot of the engine bay for ages now.. Finally got one! Smile
TE72_Turbo
Re: dyno celica with turbo upgrade Wed, 16 October 2002 10:29 Go to previous message
Nice one mate! looks very tough.
Hope to see you at the creek running low 13's soon.
Phil
Previous Topic:Has anyone compared the potentials of the 20V vs the 100Kw Engines?
Next Topic:Got NOS??!
Current Time: Sat Oct 17 08:05:23 UTC 2026
Total time taken to generate the page: 0.0072498321533203 seconds
