Toymods » Tech & Conversions » Ae92 help plzzzzzzzz
DEA-L3R
bankstown syd
Ae92 help plzzzzzzzz Tue, 07 December 2004 11:39 Go to next message
My heater in my seca sx is not working good, so i changed my thermostat, when we opened it up there wasn't one in there from the previous owner, but still its not working it starts to get abit warm and then it goes cold, and my temp gauge is always next to cold, but where the thermostat is its hot and my radiator is hot to i don't get it plzzzzz someone give me same tips on what might be the problem thank you!
sideshow
Re: Ae92 help plzzzzzzzz Tue, 07 December 2004 21:49 Go to previous messageGo to next message
just buy a thermopstat and fit it
its only 20 bucks
without a thermostat yr car will take ages to warm up
it slows the water flow in yr cooling system making sure the engine warms up fast
DEA-L3R
bankstown syd
Re: Ae92 help plzzzzzzzz Wed, 08 December 2004 03:03 Go to previous messageGo to next message
I did change it and still wont work it doesnt blow much hot air and wen it does it stops and gets cold
ke382TG
Re: Ae92 help plzzzzzzzz Wed, 08 December 2004 04:46 Go to previous messageGo to next message
Check that the heater tap is opening and closing properly when you use the adjustment on the dash. It's only coolant flowing through a metal core with air passing through it from the fan. If no heat and car is warm then the coolant from the engine must not be passing through the heater core properly.
Therefore either:
Tap is not opening to let heated coolant pass
or
There is a blockage prevent the coolant from flowing through the heater core.
Pretty simple.
DEA-L3R
bankstown syd
icon7.gif  Re: Ae92 help plzzzzzzzz Wed, 08 December 2004 07:18 Go to previous message
The tap is opening and closing so it could be a blocking in the heater core thanks for dat
Previous Topic:7M-GTE Cressida
Next Topic:k50 extention housing ke70 sedan and pannel van
Current Time: Sun Oct 25 11:35:36 UTC 2026
Total time taken to generate the page: 0.0043580532073975 seconds
