Toymods » Tech & Conversions » ECU Wiring Diagram for 5M-E
Supra Saiyan
ECU Wiring Diagram for 5M-E Tue, 07 December 2004 12:46 Go to next message
I was just wondering if anyone has the ecu wiring diagrams for the 5m-e. i'm installing my new defi gauges 2moro and i need the diagrams. i;ve already searched everyhwere but i cant find it. i did find the efi wiring in the tech docs section but no ecu diagrams.
any help would be appreciated
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Tue, 07 December 2004 13:41 Go to previous messageGo to next message
umm sorry, nvm about it, i think i found it
mod, please delete thread.
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Wed, 08 December 2004 06:15 Go to previous messageGo to next message
Ok...
I still need the ecu wiring diagram cos i looked at the wrong one. If any1 has the wiring diagram for the 5m-e, could you please post it up?
Thanks in advance
Re: ECU Wiring Diagram for 5M-E Wed, 08 December 2004 06:33 Go to previous messageGo to next message
What do you need the diagram for?
The guages don't need to interface with the ecu.
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Wed, 08 December 2004 13:10 Go to previous messageGo to next message
the control unit does
Re: ECU Wiring Diagram for 5M-E Wed, 08 December 2004 13:16 Go to previous messageGo to next message
What exactly does the control unit need from the ECU?
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Wed, 08 December 2004 13:33 Go to previous messageGo to next message
for the tachometer which must be linked to the control unit, i need the engine revolution signal from teh ecu...so an ecu wiring diagram would be great Very Happy
[Updated on: Wed, 08 December 2004 13:36]
Re: ECU Wiring Diagram for 5M-E Wed, 08 December 2004 13:39 Go to previous messageGo to next message
The ECU doesn't have the RPM signal on it. The tacho gets its signal straight off the igniter.
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Wed, 08 December 2004 13:54 Go to previous messageGo to next message
speed signal maybe?
all i know is that i've got a long cable coming outta the control unit and it connects up2 something in the engine bay. My friend said he can figure it out if he has the diagrams.
anyway, time for some sleep....
Re: ECU Wiring Diagram for 5M-E Wed, 08 December 2004 14:01 Go to previous messageGo to next message
Don't think the 5ME ECU even has that. It is rather primitive.
Re: ECU Wiring Diagram for 5M-E Wed, 08 December 2004 14:20 Go to previous messageGo to next message
As Frank said, the ecu is basic.
Tell us the inputs to the 'control unit' and we'll tell you where to get the wires from, and if you're lucky, what colour they are.
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Thu, 09 December 2004 06:52 Go to previous messageGo to next message
I need to know where the speed signal wire and the tacho signal wire goes from the control unit
Re: ECU Wiring Diagram for 5M-E Thu, 09 December 2004 06:55 Go to previous messageGo to next message
Tacho signal wire is the -ve on the coil.
Speed sensor is the blue wire from the back of the dash (I think its blue)
Pulses 4 times per rev of the speedo.
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Thu, 09 December 2004 07:27 Go to previous messageGo to next message
ok thanks
I'll try it 2moro and hopefully my gauges will work. at the moment they turn on, but dont work Sad
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Fri, 10 December 2004 02:00 Go to previous messageGo to next message
thanks for the help CrUZsida!
It works now!
I'll try and post up some pics as soon as i've got everything mounted
thanks again! Very Happy
Re: ECU Wiring Diagram for 5M-E Fri, 10 December 2004 02:03 Go to previous messageGo to next message
w00t!
Get some pics up, I'm curious to see what this contraption is.
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Sat, 11 December 2004 00:32 Go to previous messageGo to next message
Is there an easier way to do the speed signal? i dont want to take apart my dash if possible.
The tachometer is working, but it doesnt light up at night. I need to know where the illumination wire goes Embarassed
Re: ECU Wiring Diagram for 5M-E Sat, 11 December 2004 06:12 Go to previous messageGo to next message
Take the illumination of the cigarette lighter light.
Find out which one gets +12v only when the lights are on, use that.
The other place to find the speed signal is at the cruise control computer.
use www.supratsrm.com and find the MKII TSRM (the MKIII is the one it links too).
Use the cruise control section to find out which wire is the speed signal wire.
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Sat, 11 December 2004 21:54 Go to previous messageGo to next message
my cig lighter doesnt work.
and i dont have cruise control. looks like i hafta take apart the dash Sad
I got the ecu wiring diagram from the tsrm site earlier but its not the right one. i think the wiring of the usdm 5m-ge ma61 is different to our australian 5m-e ma61.
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Tue, 21 December 2004 09:09 Go to previous messageGo to next message
i got the illumination wire hooked up yesterday, and it was working fine.
Then I realised my A/C wasnt working so I decided to secure the plug for it this afternoon.
As soon as I fixed the A/C, i tested the ilumination wire and the ignition wire.
the ign wire was good but the illumination wasnt working. The instrument panel doesnt even light up when i turn on my parking or headlights. So, I resoldered the illumination wire to the cig lighter wire but it had no effect.
Im completely stumped.
not only does my new gauge not light up, neither does the original tacho when i turn on the lights and teh rheostat isnt working either.
If any1 can help out that would be great. I have the whole day off work 2moro so if i can get it all fixed in the morning, i can mount the gauges in the afternoon and take some pics for every1 to see.
Re: ECU Wiring Diagram for 5M-E Tue, 21 December 2004 09:19 Go to previous messageGo to next message
Supra Saiyan wrote on Tue, 21 December 2004 17:09
You either haven't plugged something in (like the dimmer control) or a fuse has blown.
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Tue, 21 December 2004 09:24 Go to previous messageGo to next message
im pretty sure everything is plugged in
maybe it happened when i was shoving all these wires behind my head unit. do u know which fuse it would be?
I checked the cig fuse and the gauge fuse already and they are ok
btw where is teh dimmer control? the only plugs i touched were the a/c and the cig lighter
[Updated on: Tue, 21 December 2004 09:26]
Re: ECU Wiring Diagram for 5M-E Tue, 21 December 2004 09:27 Go to previous messageGo to next message
Supra Saiyan wrote on Tue, 21 December 2004 17:24
Could have happened then yes.
I think there is a 'lamp' fuse.
Re: ECU Wiring Diagram for 5M-E Tue, 21 December 2004 09:28 Go to previous messageGo to next message
Dimmer control = rheostat.
Right side of steering wheel.
If thats unplugged, it all goes down.
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Tue, 21 December 2004 09:29 Go to previous messageGo to next message
ok, i didnt touch the rheostat at all. must be a fuse.
i'll go check the lamp fuse now.
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Tue, 21 December 2004 09:42 Go to previous messageGo to next message
its in the engine bay. i'll have to do it 2moro morning. It shouldnt be anything serious? just a blown fuse?
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Wed, 22 December 2004 00:28 Go to previous messageGo to next message
yep it was as u said. my tail fuse was blown.
its all working now, just gotta mount.
thanks again for the help
I will most likely have pics up by 2night
Re: ECU Wiring Diagram for 5M-E Wed, 22 December 2004 00:30 Go to previous messageGo to next message
Supra Saiyan wrote on Wed, 22 December 2004 08:28
Hmmm, interesting that the dash lights are hooked into the taillight circuit.
Didn't know that, but it makes sense, one comes on with the other.
Supra Saiyan
Re: ECU Wiring Diagram for 5M-E Wed, 22 December 2004 09:05 Go to previous messageGo to next message
finally
2 weeks after i recieved the defis, i've finished installing them. Many thanks to CrUZsida for helping out
heres some pics Smile
http://img.photobucket.com/albums/v626/Supra_Saiyan/MySupra.bmp
http://img.photobucket.com/albums/v626/Supra_Saiyan/ce566344.jpg
http://img.photobucket.com/albums/v626/Supra_Saiyan/4dc902af.jpg
http://img.photobucket.com/albums/v626/Supra_Saiyan/d045a8c0.jpg
http://img.photobucket.com/albums/v626/Supra_Saiyan/608f544d.jpg
http://img.photobucket.com/albums/v626/Supra_Saiyan/b0b8854d.jpg
http://img.photobucket.com/albums/v626/Supra_Saiyan/952ad5ee.jpg
http://img.photobucket.com/albums/v626/Supra_Saiyan/supranite.jpg
I will post a few more pics when it gets darker
banhbao
Re: ECU Wiring Diagram for 5M-E Wed, 22 December 2004 12:51 Go to previous message
hey choi!
yeh defi is the maddest gauges...jus so kool.
ur backfire is mad hehehe Smile
v(^0^)v
Previous Topic:Celica engines...
Next Topic:18R_GU vacum advance
Current Time: Sat Nov 21 02:26:45 UTC 2026
Total time taken to generate the page: 0.0070021152496338 seconds
