Toymods » Tech & Conversions » Need help with Fan speed controller problems
Adam_Rolla
Sydney, NSW
icon4.gif  Need help with Fan speed controller problems Thu, 09 December 2004 00:37 Go to next message
hey,
my fan speed controller only works on 3 and 4. i have tried o fix the problem by swapping the controllers over, but same problems occurs
Do u recommend i put a diode or some thing in the '3' switch so i have a '2 and a 4' so it is then hi n low
If not wot else could i do
[Updated on: Thu, 09 December 2004 02:13]
wilbo666
Re: Need help with Fan speed controller problems Thu, 09 December 2004 08:37 Go to previous messageGo to next message
Have you just changed the switch? Or the resistor block module which is usually held in by two screws near the actual fan (near the passengers feet).
Changing the switch won't fix it, if its the resistor block!
people100
Rocklea qld
Re: Need help with Fan speed controller problems Thu, 09 December 2004 10:08 Go to previous messageGo to next message
id have to agree that you need a resister block
Adam_Rolla
Sydney, NSW
Re: Need help with Fan speed controller problems Fri, 10 December 2004 09:09 Go to previous messageGo to next message
ive just ripped up the floor.. is it on the opposite side of the car where passengerers fuse box is?
Adam_Rolla
Sydney, NSW
Re: Need help with Fan speed controller problems Fri, 10 December 2004 09:15 Go to previous messageGo to next message
is it this thing
http://www.twincam.org/forums/uploads/post-7-11026 70169.jpg
Re: Need help with Fan speed controller problems Fri, 10 December 2004 09:18 Go to previous messageGo to next message
yes, see on the top of it how it says "resistor block" Rolling Eyes
the 'resistor block' willmost likely be attached to or inside the fan assembly itself... remember the resistor block generates heat, and is cooled by the air the fan pushes Wink
do you actually have a manual for your car? or you just keep asking questions for the fun of it?
change your resistor block (or make a new one with appropriately sized/wattage'd resistors...)
Adam_Rolla
Sydney, NSW
Re: Need help with Fan speed controller problems Fri, 10 December 2004 10:27 Go to previous messageGo to next message
ok thx oldrolla
found the prob.. one of the coils is broken..
i'll get one from wreckers Smile
Adam_Rolla
Sydney, NSW
Re: Need help with Fan speed controller problems Sun, 12 December 2004 09:00 Go to previous message
ok i pulled this thing out, i think this is the problem aye
http://www.twincam.org/forums/uploads/post-7-11028 42026.jpg
Previous Topic:Which T04e to buy?
Next Topic:More camber & castor on left or right?
Current Time: Fri Nov 20 04:57:06 UTC 2026
Total time taken to generate the page: 0.0056288242340088 seconds
