Toymods » Tech & Conversions » 3SGE cam grinding and other powerup options
BlackMR2
3SGE cam grinding and other powerup options Thu, 09 December 2004 03:16 Go to next message
Hi Guys, I have a 1992 Aus MR2 with a 3SGE engine.
only mods being a new stainless exhaust but still uses the factory exhaust manifold and cat converter.
Also have a modified primary airbox and unifilter foam filter.
I was thinking about getting the cams ground and maybe some other internal engine stuff too.
where would you guys recommend to go for the cams and what cost and performance gain is likely etc etc
Thanks Smile
CelicaRA45
nth ringwood, Victoria
Re: 3SGE cam grinding and other powerup options Thu, 09 December 2004 05:29 Go to previous messageGo to next message
to put some real cams in you need to change to a shim under bucket ,any more lift and you could spit the shim out in the current configuration also need new retainers and new valve springs and buckets from a gen 3 and 16new shims
SilverGhost
Re: 3SGE cam grinding and other powerup options Thu, 09 December 2004 06:11 Go to previous messageGo to next message
IMO for a performance increase you should either gut the cat (illegal) or preferrably get extractors/downpipe setup with a high flow cat lower in the exhaust setup.
(this is speaking from a turbo POV but the theory is the same), this should give you a flatter power curve with a bit more up top. Next step would be either a K&N panel filter replacement, or a pod filter and snorkel.
After this the engine should be breathing about as well as it can then you will have a good baseline for internal mods
BlackMR2
Re: 3SGE cam grinding and other powerup options Thu, 09 December 2004 06:20 Go to previous messageGo to next message
already have the higher flowing filter in and i have heard extracters on an mr2 are a problem because you then have to take them off to remove the oil filter.
you could maybe relocate the oil filter but it's all a pain in the butt.....
so bottom line is... don't bother Confused
CelicaRA45
Re: 3SGE cam grinding and other powerup options Thu, 09 December 2004 09:47 Go to previous messageGo to next message
the std extractors are fine for a std motor ,why not buy a red top beams or black top caldina beams adelaide jap have a st202 and 200 hp cheap upgrade
BlackMR2
Re: 3SGE cam grinding and other powerup options Thu, 09 December 2004 14:08 Go to previous message
so you have a beams 3sge in your celica? cool
i wouldn't mind catching up to check it out because i've never seen a beams engine in the flesh. it's not far from your place to my work.
pm me i'd love to check it out
Previous Topic:RWD Celica??
Next Topic:4AGE 20V power figures
Current Time: Fri Nov 20 08:45:52 UTC 2026
Total time taken to generate the page: 0.0053119659423828 seconds
