Toymods » Tech & Conversions » 4AGTE T/B Choices
monkeymajik
4AGTE T/B Choices Thu, 09 December 2004 06:17 Go to next message
I've read the article in the tech section, so I'm sold on the differences a larger throttle body can make.
What are people out there with 4agte's running?
Has anyone run the standard TB then gone to a larger one?(looking for diffences).
My inlet manifold is about to be cut and shut, so I need to decide what to use, I've read up a bit about the 3sge which seems to be popular, but Im considering even larger, VN or XF etc...
TE72_Turbo
Re: 4AGTE T/B Choices Thu, 09 December 2004 06:26 Go to previous messageGo to next message
Do you care about throttle sensitivity? The bigger you go (XF, VN etc), the more of a pig your car will be with the throttle just cracked. Idle becomes quite sensitive to adjust, and throttle pump settings (if using throttle position as the trigger in the ECU) may have trouble recognising such a small opening, despite the significant increase in flow at that light throttle.
The factory throttle body doesn't seem to have a drama flowing enough for 200rwkw on a few applications that I know of.
feral4mr2
Bundaberg, Qld.
Re: 4AGTE T/B Choices Thu, 09 December 2004 09:43 Go to previous messageGo to next message
i like the simplicity of useing the standard 4age throttle body, you dont have to worry about electric idle down with the wax beads.
Rallystanza
Re: 4AGTE T/B Choices Thu, 09 December 2004 10:10 Go to previous messageGo to next message
When mine finally goes together, i have a 3sgee one that im using. Dont know if its any bigger than a standard 4age throttle body, but it will have to do. Thats all i got Rolling Eyes
Good luck anyways
Jezza
[Updated on: Thu, 09 December 2004 10:10]
drift86levin
brisvegas
Re: 4AGTE T/B Choices Fri, 10 December 2004 08:09 Go to previous messageGo to next message
as far as i know Keith the 3SGE and 4AGE T/B's are the same dia, the only difference is that you might have to fiddle around with the metal tabs undertneath the TPS to fit the one your using on, the 4AGE/ZE ones seem tu use a Round plug, where the 3SGE ones are mostly square plugs..i actually think they are the same part number.. the 3sge ones have a largecold start assy hangin off the bottom, i simply removed this, cut up a peice on 3mm alluminium, and made cover plate..
then i used me 'custom' 12v cold start idle solenoide.
hope this helps,
happy boosting
drift86levin
brisvegas
Re: 4AGTE T/B Choices Fri, 10 December 2004 08:15 Go to previous messageGo to next message
ohh and also..with your I/C piping, obviously your not going to go 3" piping, 2.5 will be plenty enough for 200kw, so your 3sge/4age 57-58mm TB is about 2.25" dia, so it's pretty even..
IF you wanted you can use a TB of an EFI 85ish pintara.. i saw one at the wreckers and nearly had a heart attack..they look perfect!!!at about 60ish mm that sounds good TPS is an issue though, the toyota one will simply slide on and plug in..
monkeymajik
Re: 4AGTE T/B Choices Sat, 11 December 2004 02:11 Go to previous messageGo to next message
Cheers for that Matt. At this stage we've decided to stick with the 4age TB. But what you say about this pintara setup intrigues me. I will go and check one out. The toyota tps will attach on pretty easily hey? I dont have a spare one with me to take down and test, both are at the workshop.
I want to go for a spin in your levin coupe sometime soon!
FKN16V
NSW, East Coast
Re: 4AGTE T/B Choices Sat, 11 December 2004 04:42 Go to previous messageGo to next message
TE72_Turbo wrote on Thu, 09 December 2004 17:26
I know of a 4agte pumping out 277rwkw still using standard size t/b, was going for 300rwkw but the motor shit it self, No surprise there.
But for ease and convenience i think the standard one will be fine. As mentioned before, alot of fart arsen around to make bigger t/b work, but it can be done.
I think something off a falcon or commodore might be a little to big, maybe 3sg as mentioned above is a good solution.
Steve
fatmr2
Re: 4AGTE T/B Choices Sat, 11 December 2004 06:20 Go to previous messageGo to next message
Ive got an sr20 one on mine.
ChuckLandwehr
Re: 4AGTE T/B Choices Sat, 11 December 2004 07:10 Go to previous messageGo to next message
Yeah I looked at using a throttle body fro a dead 1G-GTE, imagine my surprise when the 4AGE TB measured out quite a few mm larger! So we will be sticking with the 4AGE TB.
regards Chuck.
Necros
Re: 4AGTE T/B Choices Sat, 11 December 2004 11:26 Go to previous messageGo to next message
Im currently in the middle of a 4A-GTE build and ive got a fwd bigport maifold that has a VN T/B.
The T/B is about 75mm in diameter and is only marginally smaller than the inlet plenum it. I will be running this setup on the std ecu initially, ill be posting a thread in relation to my car setup soon....
quest
u.s.a. south
Re: 4AGTE T/B Choices Sat, 11 December 2004 12:55 Go to previous messageGo to next message
bigger TBs seem to be a waste on a turbo car. U get the 'perception' of a power gain because, for the same throttle applied u admit more air to the motor - sensitivity, thats all.
Turboford guys dyno'd before and after and gained absolutely nothing.
They have a 5h1tload of 10sec street cars. They know what they're doing
drift86levin
brisvegas
Re: 4AGTE T/B Choices Sun, 12 December 2004 00:11 Go to previous messageGo to next message
i beg to differ...my gze tb mesured around 46-47 mm..i put a GE tb on it (57-58mm) and yeh there was a sharper increase in response because of the larger dia, BUT i did notice more top end response, my 400m times show this..stock it did 13.9 @ 96 mph, after doing the tb, top speed increased to 13.78 @ 101, so i do belive that increaseing it by a small amount does help, but the 75mm idea...on a 1.6??? com-on guys thats just over 3"!!! are you running 3" IC piping? but, i can't comment, i dunno your engine build, but if you have a 75mm tb, it must be incredibly wild!! good stuff with the posts fellas little things like this often get over looked in the hunt for just that little more power..
monkeymajik
Re: 4AGTE T/B Choices Sun, 12 December 2004 03:23 Go to previous messageGo to next message
Have you got any detail on the sr20 t/b? What does it use for cold start? Do you know if the 4age tps will fit on easily?
YelloRolla
On your mum!
Re: 4AGTE T/B Choices Sun, 12 December 2004 06:31 Go to previous messageGo to next message
Regarding the tech article - if you do the maths then you wont be needing to go much bigger than tthe standard T/B.
I will echo soem of the above respinses with a couple of cars where I am familiar with the size of the T/B - my car makes around 190rwkW on a good day and has the stock 50mm T/B. I know of a Cosworth Ford making 400+rwhp with a 55mm and an FJ20ET making 420rwhp aagain with the 55mm throttle - given that the 4AGE has one around 54mm (i can't rightfully remember) then It is fair to say that you can make a shiteload af power (300kW as noted above) through it.
Necros
Re: 4AGTE T/B Choices Sun, 12 December 2004 08:49 Go to previous messageGo to next message
Well im using the VN T/B because the bigport manifold I bought already had it on there...
Such a large throttle body is somthing that would probably be more suited to a worked 3s-gte or the likes!
This is only a temporary intake anyways, as I have a custom design that includes quad throttle bodies from a 20v Smile Just need to get an aftermarket ecu to run them.
fatmr2
Re: 4AGTE T/B Choices Sun, 12 December 2004 09:22 Go to previous messageGo to next message
monkeymajik wrote on Sun, 12 December 2004 14:23
HUH??????
I dont use a standard computer, dont have any cold start stuff and i didnt use a 4age tps.
As for its size? i cant remember exactly but i know its a fair bit bigger than the standard one. if i could find the other one i have i would measure it.
quest
u.s.a. south
Re: 4AGTE T/B Choices Sun, 12 December 2004 20:41 Go to previous messageGo to next message
shift
the gze TB maybe a bit of an odd case since its not like your typical 4ag intake, I'd imagine.
7mgtema71
Re: 4AGTE T/B Choices Sun, 12 December 2004 22:53 Go to previous message
I beg to differ with YelloRolla (as much as i do agree) yes you don't really need to upsize t/b's as the standard size is suitable with the std manifold. But IMO i believe if your looking for outright power, then theres no other choice except for a larger t/b(or a better inlet design if required).
There's nothing wrong with 3in piping either. The top end will be long, high and hard, just wont be very street-able down low! But remember, there are compromises with power.
You'll have to match the cams, porting, turbo and IC system as well to suit your individual setups. Most people wouldn't need to run a larger throttle as the std one will flow adequate for what their turbo, cooler and head will allow to flow which can be a nice 250kw (that's a lots of street power).
Previous Topic:3T-GTE/3T-C
Next Topic:stupid Q on 4wheel alignment
Current Time: Thu Nov 19 19:25:45 UTC 2026
Total time taken to generate the page: 0.010364055633545 seconds
