Toymods » Tech & Conversions » 3sgte with ge manifold
berad
3sgte with ge manifold Thu, 09 December 2004 06:54 Go to next message
just thought id share .. dunno if neone has done it b4 just thought id give u a foto of wat the finished product looks like..
http://members.optushome.com.au/phynx/coolercar.jpg
http://members.optushome.com.au/phynx/cooler-engine.jpg
[Updated on: Thu, 09 December 2004 06:56]
berad
Re: 3sgte with ge manifold Thu, 09 December 2004 06:55 Go to previous messageGo to next message
lol there a bit big but yer
SilverGhost
Re: 3sgte with ge manifold Thu, 09 December 2004 07:12 Go to previous messageGo to next message
Your referring to the ge intake manifold?? If so it appears to have its advantages as it keeps bends in the intake path to a minimum.
Did you consider rotating the compressor side of the turbo down? or wasnt there enough clearance??
berad
Re: 3sgte with ge manifold Thu, 09 December 2004 07:17 Go to previous messageGo to next message
yer we tried not enuff clearance.. we were gunna run cooler pipes down next to the cold pipe but not enough room as the pod goes down there as well
SilverGhost
Re: 3sgte with ge manifold Thu, 09 December 2004 07:21 Go to previous messageGo to next message
gotcha...not an easy conversion, looks like it was done pretty well.
If you can get your hands on the exhaust manifold heat shield and wrap that section of the pipe up in thermal insulation it should be more than enough to keep the pipe cool...
all in all top work mate, all you need is a nice front bar and your laughin Cool
berad
Re: 3sgte with ge manifold Thu, 09 December 2004 07:51 Go to previous messageGo to next message
nah easy conversion.. it bolts straight on.. u dont use any of the vacum hoses block em all up that is if ur runnin after market ecu.. ill take some beter fotos wen its not rainin and show ya
SilverGhost
Re: 3sgte with ge manifold Thu, 09 December 2004 08:06 Go to previous messageGo to next message
that would be cool, as im considering a FMIC for my car, and the 2 chassis should have roughly the same dimensions....
Ive noticed many creative ways of routing the pipes...
berad
Re: 3sgte with ge manifold Sat, 11 December 2004 11:14 Go to previous messageGo to next message
if nething the 185 bay would be larger yer theres lots of ways those were just the easiest
berad
Re: 3sgte with ge manifold Tue, 14 December 2004 02:58 Go to previous message
yer just had a look all hoses are blockd up except for the brake booster of course but other than that u dont use any of the hoses that come off it.. that is of course if ur usin aftermarket ecu's....
Previous Topic:Tech Doc
Next Topic:AE82 16v wont run
Current Time: Mon Oct 26 15:13:52 UTC 2026
Total time taken to generate the page: 0.0053749084472656 seconds
