Toymods » Tech & Conversions » fuel lines in ra28 with 1g, do i need to move them??
jcmunga
adelaide
fuel lines in ra28 with 1g, do i need to move them?? Thu, 09 December 2004 10:57 Go to next message
will the fuel lines need upgrading in the ra28 running a 1g, how much can the lines handle cos the 1g wont be standard for long
EDIT:
the fuel lines go into the 1g are on a different side to the 18r, do i need to move the piping or can i just run hoses accros??
[Updated on: Sat, 11 December 2004 03:37]
people100
Rocklea qld
Re: fuel lines in ra28 with 1g Thu, 09 December 2004 12:12 Go to previous messageGo to next message
standard fuel lines will be fine....unless u are pushing upwards of 500hp i dont see any point in every upgrading the lines...most of the fuel only goes straight back down the return anyway..
blackRA28
adelaide
Re: fuel lines in ra28 with 1g Thu, 09 December 2004 12:20 Go to previous messageGo to next message
R u sure?
My mechanic thought we should upgrade to a bigger fuel line just for an 18R -> 18R-GEU swap, because of the EFI fuel system. only another 1/8" bigger than stock maybe, but he said the original lines were pretty small to handle anything EFI, especially a boosted 1G...
CrAiGzEE
south of the big smoke
Re: fuel lines in ra28 with 1g Thu, 09 December 2004 12:26 Go to previous messageGo to next message
standard are fine
Fattony
Re: fuel lines in ra28 with 1g Thu, 09 December 2004 23:16 Go to previous messageGo to next message
Then i must have fuel lines that are capable of 500+hp then. I would havt thought that using the orignal feed line as your return and run a new feed line the next size up would be the most logical way of doing it as thats what the stock 1g equipted cars came out with. Correct me if i am wrong.
Cheers Adam
dcving
newcastle nsw
Re: fuel lines in ra28 with 1g Fri, 10 December 2004 04:10 Go to previous messageGo to next message
im running half inch but thats way over kill Smile
fade-e
Re: fuel lines in ra28 with 1g Fri, 10 December 2004 08:37 Go to previous messageGo to next message
dcving wrote on Fri, 10 December 2004 15:10
DAMN thats huge... thats like 12-13mm lines... thats over kill and then alot (not just some) Laughing
well you will never have a bottle neck in your fuel feed
RA28
Re: fuel lines in ra28 with 1g Fri, 10 December 2004 08:42 Go to previous messageGo to next message
hey, a few metres of half inch lines is better than a reserve tank Wink
The standard lines should be fine, but the engine takes the next size up, so you need reducers in the lines. It can get messy. My setup was anyhow... The fuel line is pretty cheap to buy I think, it's probably better to just replace the steel lines with the size the 1ggte uses. wouldn't cost much more after the fittings and reducers needed to run the small lines.
Tim.
people100
Rocklea qld
Re: fuel lines in ra28 with 1g Fri, 10 December 2004 09:31 Go to previous messageGo to next message
i always just figured solong as you had pressure in the line and you had fuel going back down the return then its big enough lines...when u start getting to the situation where you have not much fuel going down the return as your engine is drinking it then its time to start thinking about an upgrade.
Re: fuel lines in ra28 with 1g Fri, 10 December 2004 15:09 Go to previous messageGo to next message
Upgraded fuel lines are for old-school carbies with low-pressure suck-through pumps. With a high-pressure EFI pump pushing fuel all the way from the tank, the standard lines will be more than sufficient. If you're paranoid, just hook up a fuel pressure gauge and keep an eye on it the first time you take it for a strap... if there are any fuelling problems you'll know about it straight away.
jcmunga
adelaide
Re: fuel lines in ra28 with 1g, do i need to move them?? Sat, 11 December 2004 03:41 Go to previous messageGo to next message
what about the side that the lines come out on. they are different, do i need to move the piping or can i just run hoses over
Fattony
Re: fuel lines in ra28 with 1g, do i need to move them?? Sat, 11 December 2004 05:43 Go to previous message
Well if you re run the feed line like i said that wont be an issue as it will come out on the passenger side of the bay however your original feed will need to re re routed to the other side so you can use it as a return.
Cheers Adam
Previous Topic:To rebuild the GZE or buy a 2nd hand GZE that is the question
Next Topic:W57 or W58?
Current Time: Mon Oct 26 20:22:35 UTC 2026
Total time taken to generate the page: 0.01429295539856 seconds
