Toymods » Tech & Conversions » testing Jaycar HEI tach signal for Megasquirt
testing Jaycar HEI tach signal for Megasquirt Fri, 10 December 2004 05:52 Go to next message
http://www.materials.unsw.edu.au/~sford/tach-testi ng.html
had a bit of fun today... changing the tach line resistor to different values.
MS was datalogging at around 18 points per second.
IRA11Y
Club Member
Re: testing Jaycar HEI tach signal for Megasquirt Fri, 10 December 2004 06:09 Go to previous messageGo to next message
itd be easier if you just changed the resolution to make the signal look better Razz
good stuff dude .... more self test before asking dumb questions I say!!! youve done well!
RA40Celica
Hobart
  chris_rg@jabber.org
Re: testing Jaycar HEI tach signal for Megasquirt Fri, 10 December 2004 06:15 Go to previous messageGo to next message
your triggering looks good with those high value resistors. I noticed the same effect but was happy so i didn't continue high than about 5kohm.
I originally installed mine triggering off HEI tach signal, with standard r10 resistor. Car runs fine but gets false triggers at high rpm, resulting in the occasional doubling of the rpm.
Next i tried triggering off the -ve coil terminal (still running HEI system). This cured the high rpm spikes but gave me trouble at high load/low rpm missing (cutting out all together).
So next i lifted the R10 resistor upto around 4k (can't rememebr, something like this). This seems to fix my low rpm problems and i haven't had any trouble up in high rpm.
Here's a datalog i took earlier (0-100km/hr in about 8.1seconds Laughing ), i haven't got one of my latest setup since some bastard stole my laptop. I think its smoother than this now, new points and the resistor helped a treat.
http://www.users.on.net/~csharman/0-100.jpg
The firmware version seems to have an effect on the triggering, megasquirt'n'spark-extra tends to behave differently i noticed.
Chris
[Updated on: Fri, 10 December 2004 06:17]
Re: testing Jaycar HEI tach signal for Megasquirt Fri, 10 December 2004 06:41 Go to previous messageGo to next message
cool, thanks for the feedback Chris Smile do you have a Dave cap installed? (and the other diodes/caps?)
i'm using effectively the 2.98MS code, modded to have EGO turn off at 65kpa, rqther than a TPS value.
i added the dave cap to try and filter it a bit, but it had absolutely no effect.
the difference between the points alone and the HEI shows that it is the HEI inducing a lot of noise (coil ringing?)
figured it was better to try a whole bunch of different values to see the effect (and results are interesting!!) seems that i could use anything from 10K to 50K with no issues (50K still ran to 8000rpm) i was logging using 20ms also, resulting in 18 samples per second.
i am going to swap R10 for a 15Kohm (1watt) and then fo extended datalogs and see if there are any issues...
does MSnSe have the 2.98 mod to code to prvent false triggering for 'x' time after a pulse is detected?
[Updated on: Tue, 14 December 2004 06:10]
TA-022
Glenmore Park, NSW
Re: testing Jaycar HEI tach signal for Megasquirt Fri, 10 December 2004 11:32 Go to previous messageGo to next message
ah so tach signals are prone to engine noise just like a stereo?!
might be why my tach drops signal randomly all the time.
so if i use a good shielded wire i should see better results?
would any sort of resistor help in my cause (just running std 2t) or are they more just advantagous for ecus etc?
Nathan
Re: testing Jaycar HEI tach signal for Megasquirt Fri, 10 December 2004 12:41 Go to previous messageGo to next message
well, tach signals are prone to noise from both spark plug wires and other sources of noise like alternator (but are usually far away from them)
i don't think a tachometer has as much of a problem with signal noise, but it does depend on the type of signal it gets.
i found that even running a 1K resistor caused my KE15 tacho to function intermittently and the needle dropped often.. so addign a resistor reduces the size of the signal, and the effectiveness of the tacho.
for the ECU, it depends on the type of signal it is expecting..
if it expects a clean 12V squarewave, and it gets a coil -ve input, it will likely need a bit of conditioning..
i am not running a shielded wire to my tacho, but i am to the ECU.
CYa, Stewart
gearb0x
Re: testing Jaycar HEI tach signal for Megasquirt Fri, 10 December 2004 12:52 Go to previous messageGo to next message
hey stu have a look at this
http://www1.jaycar.com.au/productView.asp?ID=ZD190 0&CATID=&keywords=ignition&SPECIAL=&am p;form=KEYWORD&ProdCodeOnly=&Keyword1=& ;Keyword2=&pageNumber=&priceMin=&price Max=&SUBCATID=
Ive been thinken about going elec on my 2tg but people want stupid money for em (see: 200$ 2tgeu dizy thread Laughing )
For 20$ i might think about using it to trigger the megasquirt so i can run MS2 with spark control Wink
Re: testing Jaycar HEI tach signal for Megasquirt Fri, 10 December 2004 12:58 Go to previous messageGo to next message
yar, i have my eye on one of those... if i didn't have a brand new elec dizzy i'd try that.
you could also use the HEI as 'coil ignitor' and rather than ground the coil, ground a pull up resistor, similar to how the hall effect ones are used... (i'm a bit fuzzy on that Wink )
many ways to skin the tach cat...
i'll test the 'tach output' with and without 15K resistor soon and get more graphs Very Happy
i'll probably end up using the VR dizzy, soem generic VR ignitor to trigger MS, then another ignitor for the MS2 spark output.
gearb0x
Re: testing Jaycar HEI tach signal for Megasquirt Fri, 10 December 2004 13:15 Go to previous messageGo to next message
if i was to get hold of a 2tg elec dizzy my plan was to use a bigport igniter&coil to do the VR shaping and advancing Wink
Looking at the toyota ignitor document and msns diagarms the 7pin GM one performs the same stuff as the bigport igniter Wink
One of the Mr2 guys has this worken on his aw11 now
RA40Celica
Hobart
  chris_rg@jabber.org
Re: testing Jaycar HEI tach signal for Megasquirt Fri, 10 December 2004 23:13 Go to previous messageGo to next message
nah i never tried dave cap, i didn't think it would help my problem since my spikes weren't higher than my highest operating rpm anyway (don't want to filter out that frequency Smile )
my hardware is standard with r10 changed. (oh and q1 mounted on case, caus' im running low-z injectors with pwm, fried q1 once)
i think there may be some slight differences between the tach filtering done in software between the diffeent firmwares. It could just be that the filtering is performed asynchronously and timing it effected by the extra features in the code (msns-e has a bucket load). I'm pretty sure msns-e has that false trigger filter. Hopefully i will get spark control going over this christmas.
in those emmebedded graphs u just posted - When running HEI, are you triggering from tach signal or -ve coil terminal? probably coil signal, because i dont think the tach signal works with those high value resistors since it is only a 12v signal. I have never run megasquirt without HEI so i can't really say.
Do you have a condenser on the coil? maybe without HEI the dwell time is smaller and therefore the primary ringing is larger and causing extra triggers. By lifting the resistor probably increases the threshold which will trigger megasquirt. Dunno, all just guesses. I would love to investigate more with an oscilloscope.
its good that you tried a bunch of values, i just stopped once it worked well, lol. I dont think higher values of resistors will effect your maximum rpm (unless your spark gets weak at high rpm with less dwell time). The dave cap will turn the input into an RC filter dropping out high frequencies depending on the value of R and C.
Oh btw how did you increase the sample rate of the data logging?
Chris
Re: testing Jaycar HEI tach signal for Megasquirt Sat, 11 December 2004 02:29 Go to previous messageGo to next message
hmm, yeah i didn't really want to try different values of Dave cap.. just stuck with 0.22 (as it was tested in V8 to whatever rpm, and was going to be implemented in the V3 PCB)
you have a flyback board? are you running TIP42? flyback with 2xTIP42's will increase the flyback capability by 3 times over a single TIP32.. ( i think Wink )
yup, from the coil -ve as it is easier.. i've put the tach output into my HEI now and will be testing with and without resistance on the tach output on monday. be interesting to see how it is affected... i'm not totally clued up on the whole tach input/output signals.. and scope would be damn handy Wink
hmm, i figured it was something like the resistor was changing the time taken for the dave cap to charge... increasing it's smoothing effect on signal.
no, i have condensor on the points... which now thinking about it, is the wrong place Wink
since both condensor and dave cap are 0.22uF i figure they are doing the same thing...
decreasing the comms speed to 20ms.
Re: testing Jaycar HEI tach signal for Megasquirt Mon, 13 December 2004 03:57 Go to previous messageGo to next message
tried the HEI tach output.
seems to be pretty good up until 6000rpm, then i get a couple of small glitches.... i think i'll do an extended datalog (like 30mins... other ECU's would love to have that option Razz) and go thru and see how stable the signal is..
otherwise, it ill be resistors coil -ve.
looking at the schematics, it doesn't make sense to change R10 IF you have the Dave cap... the Dave cap is before R10, so it absorbs noise before R10. if i put resistor before dave cap (as i was testing) then it slows the charging rate of dave cap...
since i'm using microphone cable and RCA plugs for tach input, i'll just make a short 'resistor lead' so i can swap it out easily..
ps, seems the KE15 tach is reasonably accurate.... up to 7500rpm anyway Wink
RA40Celica
Hobart
  chris_rg@jabber.org
Re: testing Jaycar HEI tach signal for Megasquirt Mon, 13 December 2004 23:31 Go to previous messageGo to next message
yeh that sounds similar to my problem using the tach signal. glitches in high rpm.
what you say about r10 is correct. it still has some effect though, a number of people have reported it helping. By putting the resister b4 dave cap you are making an RC filter and changing the value of either R or C will effect the filter cut off frequency. but r10 is probably just effecting the amplitude of the signal, which then affects when the john diode conducts??.. anyway best way is to try things like you have.
yeh i was impressed with my RA40 tacho aswell, accurate right up to a tad over 7000rpm Smile
Chris
Re: testing Jaycar HEI tach signal for Megasquirt Tue, 14 December 2004 06:09 Go to previous messageGo to next message
ok, heres the final graphs
http://www.materials.unsw.edu.au/~sford/tach-testi ng2.html
the top 3 are taken directly from the Jaycar HEI "tach output". there is a little bit of noise in there. max of about 300rpm?
the bottom two are taken directly from the coil negative terminal, but with a 15K resistor in series between the coil and the MS.
i think the bottom two are better quality and more accurately track the rpm of the motor..
so whatcha think?
Re: testing Jaycar HEI tach signal for Megasquirt Tue, 14 December 2004 06:12 Go to previous message
from this
http://www.materials.unsw.edu.au/~sford/newpics/HEI+dave+1K.jpg
to this with just a 15K resistor...
http://www.materials.unsw.edu.au/~sford/newpics/HEI-coil-15Kresistor1.jpg
compared to this (from HEI tach output)
http://www.materials.unsw.edu.au/~sford/newpics/HEItachoutput5.jpg
Previous Topic:Air-con light blinking?
Next Topic:4A TPS? Which wire supplies power?
Current Time: Sat Oct 24 19:43:51 UTC 2026
Total time taken to generate the page: 0.0058608055114746 seconds
