Toymods » Tech & Conversions » 7mgte stock manifold...can it make power?
V8_MA61
icon12.gif  7mgte stock manifold...can it make power? Fri, 10 December 2004 06:06 Go to next message
Would the stock turbo manifold off a 7mgte allow me to get around 350ish hp?
Would a ct26 support this sort of power or would it need to be upgraded? How much would i be looking at to upgrade it to this potential?
intercooler wise - do i need a huge one to flow around this power or will an off-the-shelf item do the job??
7mge injectors...are they big enough for 350ish? or will i need bigger ones?
2.5" exhaust with only one resonator..is that enough for this power?
what kind of psi would i need to be pushing to get this kind of power?
7mge-t is the plan of attack...it seems to much easier than supercharing it Razz
is there much more i need to change? How much would i be looking at roughly to do the above?
computer - would a stock one be enough or what do i need?
last question...anyone got any of the above bits cheap
[Updated on: Fri, 10 December 2004 06:07]
Chris Davey
sunny coast, qld
Re: 7mgte stock manifold...can it make power? Fri, 10 December 2004 06:31 Go to previous messageGo to next message
V8_MA61 wrote on Fri, 10 December 2004 17:06
I think it would need to be highflowed for that amount of power.
With the price of aftermarket ones these days i don't think it is worth getting a second hand one.
I don't know what size they are? 350hp you should have 6 350cc injectors or thereabouts. I didn't think the 7m-ge's were that big though if the 1g-gte only has 245cc ones.
That is all i can help with Smile
V8_MA61
Re: 7mgte stock manifold...can it make power? Fri, 10 December 2004 07:30 Go to previous messageGo to next message
yeah i thought the 7mge ones were about 300 Confused
V8_MA61
Re: 7mgte stock manifold...can it make power? Fri, 10 December 2004 07:48 Go to previous messageGo to next message
how about intake manifold?
people100
Rocklea qld
Re: 7mgte stock manifold...can it make power? Fri, 10 December 2004 09:34 Go to previous messageGo to next message
id be using 7mgte injecters as there is a big difference between them and thats why the turbos have bigger ones...Id just chuck the gear on then wind it up...or better yet just by a 7mgte and shove it in.
V8_MA61
Re: 7mgte stock manifold...can it make power? Fri, 10 December 2004 10:40 Go to previous messageGo to next message
people100 wrote on Fri, 10 December 2004 19:34
yeah thatd be ideal if i hadnt've rebuilt the motor 13000km ago...
people100
Rocklea qld
Re: 7mgte stock manifold...can it make power? Fri, 10 December 2004 12:34 Go to previous messageGo to next message
sell it...i doubt its gonna matter if you have not rebuilt it to turbo specs...unless the 7mge and 7mgte are the same bottum ends which i doubt
V8_MA61
Re: 7mgte stock manifold...can it make power? Fri, 10 December 2004 12:38 Go to previous messageGo to next message
bottom ends are identical bar oil squirters for the pistons (thats fixable with a bigger oil cooler and if needed a better oil pump)
And the pistons themselves..being the NA has higher comp ones.
TD42T
Mildura
Re: 7mgte stock manifold...can it make power? Fri, 10 December 2004 13:30 Go to previous messageGo to next message
A word of warning!
What ever you think it is going to cost you to force feed a GE, triple it and add some.
Been there and still doing it.
Marty
V8_MA61
Re: 7mgte stock manifold...can it make power? Sat, 11 December 2004 07:51 Go to previous messageGo to next message
what are you converting? A 7m?
quest
u.s.a. south
Re: 7mgte stock manifold...can it make power? Sat, 11 December 2004 12:46 Go to previous messageGo to next message
u don't have to *guess* at anything a boosted 7m can do in any form - just hit up the u.s. mk3 supra forums and swipe a combination. Everything up to 10sec full weight airconditioned 5speed daily drivers!
7mGE works excellent under boost also. Conversion is dirt cheap in the u.s. as u can get a mani/ct26/440s at throw-away prices... gte pistons too if u wnat them. A remarkable underrated powerplant.
wilbo666
Re: 7mgte stock manifold...can it make power? Sun, 12 December 2004 04:50 Go to previous messageGo to next message
*cough* finish one project at a time? Razz
350hp -> ~260kw, is that what sort of power you are chasing at the engine or wheels btw?
I don't think you will be able to get that power (engine) with a stock ct26, 7mgtes are only 240hp stock. I'm not sure tho!
7mge injectors are 295cc, the rule of thumb apparently is hp=cc/5, so each injector at max can supply 59hp, so total with the stock injectors you would max out at 354hp.... close...
ECU will be something you'll have to think about, you'll need to change the ignition timing (regraph the dizzy is an option), or maybe look at adapting the DLI (distributor less ignition) off a 7mgte? Also changing fueling....will need a rising rate fuel pressure regulator....Maybe look at running the complete 7mgte ECU setup (suspect wiring nightmare)? Or look at aftermarket options.... $$$$$$$$
Seems like a lot of work, and looks like it will almost require a full 7mgte in parts to make it happen as what I see as 'easily' (I use the term lightly) Smile
YelloRolla
On your mum!
Re: 7mgte stock manifold...can it make power? Sun, 12 December 2004 06:22 Go to previous messageGo to next message
Intake manifold ports are rather large and should quite easily cope with 350rwhp.
V8_MA61
Re: 7mgte stock manifold...can it make power? Sun, 12 December 2004 07:41 Go to previous messageGo to next message
i was referring to 350bhp...im not after huge numbers...thats what the ma61 is for Smile
Stenno
Re: 7mgte stock manifold...can it make power? Sun, 12 December 2004 14:06 Go to previous messageGo to next message
quest wrote on Sat, 11 December 2004 23:46
LMAO!
10 second 5 speed daily drivers? who are you kidding?
Time slips and video please.
Underrrated? for what, blowing headgaskets and big end bearings? No offence but they're not underrated, they're just not that great.
you'll need more than a better oil cooler to offset the oil piston squirters - they squirt oil onto the underside of the piston, having a better oil cooler is not going to get around not having these - Toyco put them there for a reason.
350rwhp or crank HP? if it's at the crank you shouldn't have any issues obtaining this sort of power on a stock CT26 however you will be pushing shit up hill - a high flow or a replacement turbo (internal wastegated GT40) is the best path to take.
Best of luck, easiest and cheapest option is to find a GTE motor though, but that's just my opinion Smile
[Updated on: Sun, 12 December 2004 14:07]
quest
u.s.a. south
Re: 7mgte stock manifold...can it make power? Sun, 12 December 2004 19:47 Go to previous messageGo to next message
here, laugh at this... found it in under 60 seconds.
http://www.supraforums.com/forum/showthread.php?s= 487362b0f8b2b2475469c11fb7ccce4e&threadid=2029 26&perpage=25&pagenumber=1
If those puerto ricans can get daily driven 3tc/w58 corollas into the 10s, what makes you think a 7m is such a challenge ? Wake up.
..and here, found in 11sec. At least 4 other 10sec dailys mentioned
http://www.supraforums.com/forum/showthread.php?s= 487362b0f8b2b2475469c11fb7ccce4e&threadid=2449 58
why don't you tip in that thread and laugh at 'em... I don't see what's so amusing, maybe they will.
I've witnessed a mk3 and a mk2 (both 7M/5speed street cars) bust off 10sec ETs within 3 runs of each other at an event. One sprayed tho. Did I record it or ask for a copy of their timeslip for you ? No
A buddy of mine daily driven mk3 runs 11.8 boosting a bone stock 7mGE! He did retorque the stock headbolts. One would sound like a fool teeling him or those fast 3tc boys, "ooohh wait, you need squirters".
I've seen 1 and 2jz spin rod bearings. Do they suck ? Most OLD turbo motors suffer from this. Freshen it.
If you can't get past a 7m head gasket, you're too stupid to be modifying cars.
Don't you see that folks like you who laugh at the 7, is where the underating comes from ?
Like I said before, hit up the supra forums. There are lots of stock ct26 dynos and track times.
Here is a $450 upgraded ct putting 469 ft-lbs tq to the ground.
http://www.jblmk3.com/id97.htm
Its a common upgrade milestone to snack on until you're ready to 'play hard'
Kyosho
Wollongong
Re: 7mgte stock manifold...can it make power? Sun, 12 December 2004 22:19 Go to previous messageGo to next message
V8_MA61 wrote on Fri, 10 December 2004 23:38
Be cautious with the higher compression
Most turbo cars run a lower compression for a reason... It avoids pinging and over stressing the blocks...
I'd be mostly worried about pinging the motor then anything though.
Re: 7mgte stock manifold...can it make power? Mon, 13 December 2004 00:45 Go to previous messageGo to next message
quest wrote on Mon, 13 December 2004 03:47
Ummm, unless its mentioned somewhere else on the forums, all those cars above are 7MGTE's, not 7MGE-T's.
BIG difference.
Re: 7mgte stock manifold...can it make power? Mon, 13 December 2004 01:13 Go to previous messageGo to next message
quest wrote on Mon, 13 December 2004 06:47
Stripped drag Corolla ~ 700kg.
Fully loaded MA70 ~ 1600kg.
And now some wise words from a true American hero:
http://members.optusnet.com.au/gianttomato/1GGTZE/mrt_jibbajabba.jpeg
[Updated on: Mon, 13 December 2004 01:15]
nudes
Sydney/Wollongong
Re: 7mgte stock manifold...can it make power? Mon, 13 December 2004 09:15 Go to previous messageGo to next message
Maeso Says
11.4 @130 mph daily driven street tire mk3
Hey guys just want to share the last track run on my friend 7m.
The car has only been tuned on the street so don’t ask for hp numbers.
This test run was with drag radial and @ 26psi.
We plan to tune at the dyno and boost up to 32 psi
The next run after dyno tuning will be with slicks so we hoping to run 10.6 or better cause this last run with the drag radials the car was spinning tire until 4th gear. This is a daily driven street ma70!!!! With stock 5 speed AC and complete interior
why all the scepticism? are people that bored or just arrogant?
GT, you drive a brown MX23 that beats GTR's.. why then do you find it so hard to believe there are fullhouse poopra's running 10's and 11's..
drag racing is ghey.. i'd rather a camry with sorted suspension than a fullhouse drag *something*.. meh each to their own..
Back on topic.. after having the 7mge in the cressi i would just buy a 7mgte and do a metal headgasket and headbolt job on it..
the money that you lose on the selling and purchase of the 7mge/7mgte will more than compensate/pay for the fuckaround of converting the 7m to turbo..
[Updated on: Mon, 13 December 2004 09:48]
V8_MA61
Re: 7mgte stock manifold...can it make power? Mon, 13 December 2004 13:52 Go to previous messageGo to next message
christ people arent we getting a little off topic?
ALL i want to know is the quickest way to get 350 BREAK HORSE POWER..i think ive mentioned that 4 times now.
I was sure a ct26 could slap that out, and the stock motor would be fine with no major stress... Confused
quest
u.s.a. south
Re: 7mgte stock manifold...can it make power? Mon, 13 December 2004 15:12 Go to previous messageGo to next message
>>"Stripped drag Corolla ~ 700kg."
nice try gianttomato. Those things run 7s and 8s, not 10s.
Read what I said... "daily driven street turbo rollas". They weigh considerably more than a u.s. spec stock te72 or ae86.... dunno where you're getting 700kg from
Re: 7mgte stock manifold...can it make power? Mon, 13 December 2004 17:42 Go to previous messageGo to next message
Yep, there's a plethora of daily driven 7 second Corollas. I see them in my neck of the woods everyday, just like those daily driven fully loaded 10 second MA70s.
Let me guess, you haven't done physics yet at high school?
The biggest worry about USA invading other countries is that they are spreading stupidity, not democracy.
quest
u.s.a. south
Re: 7mgte stock manifold...can it make power? Tue, 14 December 2004 07:04 Go to previous messageGo to next message
They run 7/8s. STRIP. DRAG. Who said anything about street driven ? You're retarded to even suggest that.
If you don't think 10sec full wt daily driven 3tc corollas or 7m mk3s exist... Who cares. Then stick to the "woods"... a perfect breeding ground for close-minded fools. Must suk to be u.
>>"Let me guess" ...well, if u want to... you're no good at it.
On the usa comment...after reading some of your posts, why would I expect any better from you ?
sorry guys
Re: 7mgte stock manifold...can it make power? Tue, 14 December 2004 07:40 Go to previous messageGo to next message
quest wrote on Tue, 14 December 2004 18:04
It would appear you did, a couple posts up. Here, let me refresh those few neurons you have that somehow pass for a brain.
quest wrote on Tue, 14 December 2004 02:12
Please fuck off from whence you came.
Stenno
Re: 7mgte stock manifold...can it make power? Tue, 14 December 2004 11:03 Go to previous messageGo to next message
Jeeez these Mk3 owners still get worked up so easily, always good to see.
Blame Canada.
V8_MA61
Get a 55mm comp wheel and have the backside cropped and you'll make good numbers with the right tuning.
A stock GTE will be fine once the obvious is sorted however a GE has the issue of the higher compression to worry about, or more so limit the amount of boost you can run on pump fuel.
Re: 7mgte stock manifold...can it make power? Tue, 14 December 2004 13:06 Go to previous messageGo to next message
Maybe if I duck down the shop and grab me a slab of red tarax, I, too, can join in later?
Jag7799
Re: 7mgte stock manifold...can it make power? Tue, 14 December 2004 13:33 Go to previous messageGo to next message
just shut up.. stop thinking off track and finish the ma61, this topic should be deleted for that very reason!
I reckon your engine block will rust away before you finish the conversion...
quest
u.s.a. south
Re: 7mgte stock manifold...can it make power? Tue, 14 December 2004 15:34 Go to previous messageGo to next message
>>"It would appear you did, a couple posts up. Here, let me refresh"
No fool. This is EXACTLY what I posted, don't try to twist it;
"If those puerto ricans can get DAILY DRIVEN 3tc/w58 COROLLAS INTO THE 10s, what makes you think a 7m is such a challenge ?"
Then some asshole responded, making this stupid pointless comparison;
Fully loaded MA70 ~ 1600kg."
"Stripped drag rolla" IS NOT A "daily driven 3tc/w58 corolla"
Worlds apart in function and performance
>>"Please fuck off from whence you came"
classic! do you write your own material ? Good luck on your hi school physics exams... still won't do a dumb fvkr like you any good tho
wilbo666
Re: 7mgte stock manifold...can it make power? Wed, 15 December 2004 01:38 Go to previous messageGo to next message
quest wrote on Wed, 15 December 2004 02:34
*cough* considering he's a doctor, I'm going to go out on a limb and guess he must have done pretty well on his high school physics exam Very Happy (on that note are you old enough to have done your high school exam yet Razz).
hehe, a suggestion? don't flame the regulars Smile
Jag7799
Re: 7mgte stock manifold...can it make power? Wed, 15 December 2004 02:12 Go to previous message
wilbo666 wrote on Wed, 15 December 2004 12:38
or, if you do.. call them a girl or something
Previous Topic:where to buy cheap silencer ?
Next Topic:Making 3K Go Harder
Current Time: Thu Oct 22 18:56:00 UTC 2026
Total time taken to generate the page: 0.0073060989379883 seconds
