Toymods » Tech & Conversions » need help to fix trueno steering
Big T
need help to fix trueno steering Fri, 10 December 2004 09:17 Go to next message
hey peoples. well just had a little off in my trueno and it seems that the left wheel has been nudged back about 2cm or so.
consequently, the steering wheel cant be turned all the way to left anymore as the wheel rubs on the arch underneath. i can get
almost 1 turn before it touches. anyone have a diagnosis for this and what would be involved in fixing it. i want to do the work
myself but need to know what parts i might need 1st. the car has camber tops and they were knocked way outta line but as far
as i know, camber tops cant make the wheels move backwards can they? i hit a curb at around 20-25km/h at around a 45 degree
angle or so. i had a look at the shock and it doesnt seem to be bent but the lighting wasnt that good so i'll have to check later as
well. any help or info would be appreciated. cheers.
eddie.
[Updated on: Fri, 10 December 2004 09:29]
EVOSTi
cambo
      no
Re: need help to fix trueno steering Sat, 11 December 2004 00:11 Go to previous messageGo to next message
might have bent a castor rod. go get a wheel allignemt and they will tell you what parts are bent. then stop thinking your takumi when its wet.
Matt-AE86
Re: need help to fix trueno steering Sat, 11 December 2004 02:29 Go to previous messageGo to next message
i doubt the shock would bend, more like the castor/tension/radius rod and control arm, have a look at those 2 things and like EVOSTi said, go for a wheel allignment.
Big T
Re: need help to fix trueno steering Sat, 11 December 2004 12:44 Go to previous messageGo to next message
dont suppose anyone knows if i can replace the castor rod and control arm with ones from a ke70?
ae95
Re: need help to fix trueno steering Sat, 11 December 2004 12:58 Go to previous message
i had a car that hit a curb in the front left
bent the shock, strut, tie rod, castor rod, crossmember, swaybar and chassis
Previous Topic:supercharge or turbo
Next Topic:can anyone tell me does S2000 good for drifting?? why? thanks a lot
Current Time: Fri Nov 20 15:55:36 UTC 2026
Total time taken to generate the page: 0.0056900978088379 seconds
