Toymods » Tech & Conversions » anyone got info on this car???
1ggte89
anyone got info on this car??? Fri, 10 December 2004 15:30 Go to next message
just searching the forums i found this but i cant remember where. GRRRR Sad If anyone has anymore info on the car or know the owner? I would like to know a bit more on the car like if its changed following parts >> fuel pump, fuel regulator, injector size ?? wat computer its got? also what other mods its got to make this much kw
"the car produces about 250-260 kw (you dont need to upgrade from the gen 3 turbos thay can produce 18 psi all day if you upgrade the massivly restrictive turbo intakes and give each turbo a descent size inlet with its own air filter, so the turbo's arnt fighting with each other for air, which they are standard!. it is also important to put as big as possible exaust pipe (i used 4") for about the first 80cm then into 3" for the rest this allows the turbo's to spin more freely with less back pressure.
bigger turbo's will only give you more lag.
the gine produces good power up to about 7500 revs, it will rev harder but there is no real point. i am running a gen1 engine with gen three stuff so its basically a gen 3 now."
[Updated on: Fri, 10 December 2004 15:31]
1ggte89
Re: anyone got info on this car??? Fri, 10 December 2004 15:33 Go to previous messageGo to next message
I was thinking of doing this than do a laggy single turbo conversion i was only worried about turbos blowing and i like the idea of twins. i just need more info on the engine
dcving
newcastle nsw
Re: anyone got info on this car??? Fri, 10 December 2004 20:00 Go to previous message
somehow i find that very hard too believe, 250kw with standard gen 3 turbos, thats a lot of fucking power for a baby 2l Confused
Previous Topic:tyre pressure?????
Next Topic:ST202 Wiring digrams
Current Time: Sat Oct 24 19:03:13 UTC 2026
Total time taken to generate the page: 0.0050950050354004 seconds
